Question about NetGear (IM-WG511T) Wireless Adapter
Can't see any wireless networks in the area, but I know there are many
I have a Netgear WG511T wireless PCMCIA card in a vpr Matrix laptop. The card is recognized by the laptop and the drivers get installed (the default ones), but the card's led blink alternate indicating that is trying to connect, but no connection. I downloaded the last drivers from the site (ver 4.0.0.140) but still the same problem. My router is DLink DI-524 and I know it works since I'm using it right now another latpop that's connected to it. Also, my other laptop sees many wireless networks in the available list while the Netgear card can't see any (so it's not just a problem of my router or the Dlink-Netgear mix unless all the other networks in my range are DLink routers...) I have no idea what else to try, or if there's anyway i can diagnose the card... it is working somehow (at least as the laptop is concerned) but it just can't connect to anything...
  • 1 more comment
  • Laura Aguiar Nov 17, 2006
    The connection is configured to get an IP automatically and i tried giving a static address and it did not work.
    The problem happens before that. I mean, if i plug the card and see the status is always trying to connect (searching for networks) but never finds any. If i see the list of available networks in the area is empty so the problem is that the card scans the wireless frequency (or whatever) and does not see anything, it is not a "connection" problem (like it finds the network but can't get the connection to work)...
  • ddoherty64 Nov 20, 2008
    my wireless card is a wg511T and it only has a single light blinking and i try to connect it but nothing works do i need to get a new one or what would i do to connect it to the network
  • Anonymous Feb 25, 2009
    i have a d-link router. All of a sudden it doesn't recognize my secured network. How can I reestablish connectivity?
    President:
  • 2,961 Answers
Can your other laptop see the laptop with the problem. First check that it is being given an IP address in your router and set to obtain IP address automatically. You may need to give the wireless card an ip address and DNS address yourself within the same range as the others; this way you know the addresses are correct. Just check that your problem laptop has the same network group name, right click my computer>properties>computer name and check the workgroup name is tha same as rest of your pc's. Keep trying you'll win in the end!
Posted on Nov 17, 2006
  • andrew pester
    andrew pester Nov 17, 2006
    I would uninstal the drivers again and start from scratch, also worth trying Windows wireless Zero Configuration instead of the wireless cards utility.
SOURCE:
The pc said the setup needed to be reset. i uninstalled the etgear and now i dont know how to reinstall. i dont have the cd. product is netgear 108 pc card wg511t
Go to the web site below and download your driver, then simply run the setup installer by double clicking on the .exe, it will then install your software and driver.
Feb 16, 2010 | NetGear WG511T 108 Mbps Wireless 802.11g/b...
Do you have a recommendation on which PCMCIA card to purchase for an Inspiron 1100 PC?
Check out this one, SUPER-G WIRELESS PC CARD WG511T from Netgear retails for $59.99, you may find a good deal for it on ebay.
Dec 28, 2009 | Dell Inspiron 1100 Notebook
When I install it says Card unplugged when it is firmly plugged in
i have netgear wgr614v7 and a broadband connection working without security code, when i tried to configure to put a wep i reset the netgear and now it is not working . what should i do to have a connection via netgear and with security password
Dec 04, 2009 | NetGear WG511T 108 Mbps 802.11b/g Wireless...
HP dv6000 and NetGear WG511T
try other PCMCIA slots...actually there 2 of them in every laptop.
Aug 10, 2008 | NetGear WG511T 108 Mbps Wireless 802.11g/b...
Wg511t on thinkpad 1400
Make sure that the router and the wireless computer has the same wireless settings. That is assuming that the wireless adapter has been correctly installed on the computer.
If you have questions just ask me and ill answer you as soon as I can.
Apr 13, 2008 | NetGear WG511T (ASKU23063) Wireless...
WG511T network card problem
WEP and WAP mmmmmm.
So WEP is Wireless Encryption Protocol and WAP is Wireless Application Protocol. WAP is used in cell phones so i am presuming you actually mean WPA?
If so....
The wg511t provides the highest available level of industry standard 128-bit WEP encryption, and it’s
upgradable to Wi-Fi Protected Access (WPA) security.
Here are the instructions to enable WPA.
http://kbserver.netgear.com/kb_web_files/n101675.asp
WPA is set from the router so if it is not supported on the router it is not supported on your card.
It is router dependant.
What router do you have.
Let me know if this is helpful at all.
Feb 29, 2008 | Computers & Internet
Netgear
You dont need your wireless adapter to setup your laptop however if you are going to setup or use your laptop to connect to a wireless connection you need your wireless adapter
Jan 22, 2008 | NetGear (IM-WG511T) Wireless Adapter
Netgear WG511T
You can download the software from here.
Dec 16, 2007 | Computers & Internet
Wireless network setup
Based on your post, you currently have a working Netgear WiFi Card installed in your laptop. What you want to do is remove it from the laptop and install the said card to your desktop.
For your desktop to be able to accept the NetGear WFi card which is a PCMCIA Cardbus device, you need to install either:
1. a USB Adapter for PCMCIA as shown here; or
2. a CardBus/PCMCIA to PCI Adapter Card available here.
Either one will work. Of course you need to install the necessary drivers for the NetGear MA701NA in your desktop which is available from the CD installer that came with the NetGear or online here.
Considering the cost of the USB adapter or the PCMCIA to PCI card, you may want consider buying a PCI WiFi card or USB WiFi dongle.
Hope that this be of some help/idea. Pls post back how things turned out or should you need additional information.
Good luck and kind regards.
Nov 15, 2007 | NetGear (MA701NA) 802.11g/b Wireless...
NetGear (IM-WG511T) Wireless Adapter Logo
192 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Mike
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
