Question about HP OfficeJet 7310 All-In-One InkJet Printer
Cant receive fax
Sending works ok
    Problem Solver:
  • 14 Answers
Assuming that all your setting are correct and you have a dedicated line or distinctive ring, it sounds to me like your PC Fax board may be defective. This boards are found on the left hand side of the printer toward the rear and are fairly easy to remove and replace. Fax pc boards can also be really expensive, but here is a site that may have the product available at a reasonable price. Printerfixer.net
Posted on Nov 14, 2008
Why cant I send a fax
I share a informative links please visit and check it your error options.
Read More... Cannot send fax using all in one printer and Interpreting Error Codes in Fax Communication Error or Fax History... and If any more Help.. HP Printer Support
Thanks,
Sep 08, 2014 | Office Equipment & Supplies
Cant send or recieve fax
Might be silly question but is it setup to auto transmit and receive? And have you tried to operate it manually? + take out the inline filter fax machines operate on volume'db' to soft and it can't hear, to loud and it can distort sound.
Dec 28, 2013 | HP Office Equipment & Supplies
Hp 8500 printer/fax machine will no longer receive a fax in color but can send in color. it used to work fine both ways. What can I do to fix the problem?
If the person who is sending the fax cant send in color, then you would not be able to receive the fax in color. Just make sure you choice the option to received the fax in color. Ask someone to send you a fax in color and just received in color.
Feb 17, 2013 | HP 8500 Premier All-In-One InkJet Printer
How can I get a FAX Confirmation printed out on the HPJ4680?
If you require printed confirmation that your faxes weresuccessfully sent, follow these instructions to enable fax confirmation beforesending any faxes. The default fax confirmation setting is Off. This meansthat a confirmation report is not printed for each fax sent or received. Aconfirmation message indicating whether a fax was successfully sent appearsbriefly on the control-panel display after each transaction. NOTE: You can include an image of the first page of the faxon the Fax Sent Confirmation report if you choose On Fax Send or Send &Receive, and if you scan the fax to send from memory To enable fax confirmation
1.Press the (Setup) button.
2.Press right arrow to select Print Report, and then press OK.
3.Press right arrow to select Fax Confirmation, and then press OK.
4.Press right arrow to select one of the following, and then press OK. Off Does not print a fax confirmation report when yousend and receive faxes successfully. This is the default setting. On Fax Send Prints a fax confirmation report for every faxyou send.
OnFax Receive Prints a fax confirmation report for every fax you receive.
Send& Receive Prints a fax confirmation report for every fax you send andreceive
Jan 10, 2011 | Office Equipment & Supplies
C7180 can't send or receive fax? this worked a
press setup button. scroll to advanced fax setup. press ok. scroll to ecm press ok. select off. then press ok. then press cancell button to go back to main screen. now try to send and recieve fax.
Dec 19, 2009 | HP Photosmart C7180 All-In-One InkJet...
SHARP UX-A1000 - sends all BLACK page (to all
Noisy line? is all that strikes true when you ensure me it makes great photocopys, but then you receive OK, very strange, All the mechanisms for doing a local copy is the same as sending a fax the difference is the conversion to phone noise so it has to be electronic, I;d guess lightning/power surge, cant think of much else....sorry
Nov 04, 2009 | Sharp UX 510 Plain Paper Thermal transfer...
Cant receive fax
FIRST OFF. IF YOU PLUG A PHONE INTO THE JACK DO YOU GET DIAL TONE? IS THE WALL JACK PLUGGED IN TO THE RIGHT JACK ON THE MACHINE? NEXT GO IN TO THE MENUE SET UP FOR FAX. GO TO THE SECTION WHERE YOU WILL SEE EASY RECEIVE AND EASY SEND, ON BOTH OF THEASE PRESS SET OR OK THIS SHOULD NORMALLY DO THE TRICK, IF ALL FAILS, THEN YOU MAY NEED A PHONE BOARD CALLED A NCU BOARD. GOOD LUCK BROTHER SR TECH
Jan 27, 2009 | Brother IntelliFAX 2800 Laser Fax
My fax sound but dont received any fax
hi,
check whether the auto answer is turned on...
either u have the button on the front panel of the printer itself "auto answer" or u will have it in the fax menu...
press the menu button and scroll down to fax setup or advanced fax setup, make sure the auto answer option is turned on....
thanks and regards
agnel
Mar 19, 2008 | HP OfficeJet 7310 All-In-One InkJet...
HP OfficeJet 7310 All-In-One InkJet Printer Logo
29 people viewed this question
Seeker5211
Seeker5211
