Question about Air Tools & Compressors
Air pressure At what pressure does the compressor turn off? Can this be changed?
  • wmd22000 Nov 14, 2008
    Thanks, my problem seems to be a release valve that only goes to about 85#
  • 34 Answers
Most compressors have a shut off switch that will cut it off at 100-150 psi depending on the make and model of the compressor. The only way to change it would be to install a different pressure switch or hard wire it (this is not recommended, over pressurizing can cause the tank to rupture)
Posted on Nov 14, 2008
2 Suggested Answers
lester482529
  • 226 Answers
SOURCE: air compressor not building pressure
YOU MAY HAVE BROKEN OR CRACKED A FEED LINE REMOVE THE COVER LET IT RUN ,CHECK FOR LEAKS
Posted on May 23, 2009
My air compressor will crank and run for 7 to 10 minutes and then die just like you turn the key off.
well you didnt mention what year or model number you got but some of the better IR compressors have a fuel saver mode that if they don't sense any change in load for like 15 minutes they shut off could be what your seeing , or could also be a safety sensor on the seperator tank not seeing any pressure build up (bad or damaged sensor?)
Apr 15, 2014 | Ingersoll Rand Air Tools & Compressors
I have a craftsman air compressor model # 921.16472S. When it got to cut off pressure the bleed valve started blowing. I changed the pressure switch and bleed valve then lowered the cut off pressure. When...
Either the pressure switch is not shutting off when reaching the desired pressure or the pop off is either the wrong one or it is bad. Some blow off at lower pressures for single stage air compressors while others blow off higher for 2 stage air compressors.
Feb 11, 2014 | Craftsman Air Tools & Compressors
My air compressor will start and turn off in around 5 seconds how do I fix this
Sounds like your pressure switch is bad. The pressure switch tells the compressor when to turn on, and off. When the air pressure is low it comes on, and turns it off when it get to the right pressure.
Apr 22, 2013 | Air Tools & Compressors
Changing pressure switch on qrs15
You should be able to adjust the pressure switch inside. There should be a screw that you can turn in and out to adjust the pressure. By turning the screw out, it should lower the pressure.
Jul 30, 2012 | Chicago Pneumatic Qrs15hpd Rotary Screw...
Ingersoll Rand 3 hp air compressor builds correct pressuse but trips rest when called to restart. Changed starter and running capasitors but no change in problem.
You need to check the head unloader.
Compressed air that is trapped over the piston when the compressor shuts off will be evacuated to atmosphere through the unloader valve, to prevent that compressed air pressure from adding load to the start up of the compressor motor, when the pressure switch again calls for air. For example, the last time you did a sit-up, you may have folded your arms over your chest, or if you are particularly masochistic : - ) , even held a weight to your chest. What you were doing is increasing the load against which your muscles have to work to effect the sit up.
Compressed air, captured in the cylinder after the compressor shuts off, would increase the load against which the electric motor would have to work. It may increase the load too much, and the motor may fail to start, or it may pull too many amps and fry a fuse or pop a breaker in the panel.
When the compressor shuts off, the unloader valve operates, it unloads the trapped air to atmosphere, and that problem is solved.
The unloader valve is plumbed somewhere in the line between the compressor and the compressor tank.
It is often part of the pressure switch assembly. It will, in many cases, be opened by the pressure switch, when the air in the compressor air tank reaches the set point and the pressure switch trips the power supply to the motor off, and at the same time, trips the unloader valve to open.
it is normaly on the bottom of the pressure switch it will have a small tube hooked to it
Jan 04, 2012 | Air Tools & Compressors
Henry@I have a coleman model #C65C600V1B103 air compressor. When te compressor shuts off it blleeds air thru a 1/4 inch line thath's attached to the pressure switch. This continues blleding off...
Hello
Check that the pressure switch is installed correctly,meaning there is a in and out.There should be.
If not try turning the pressure switch around or installing it reverse of what it is now.
Also there should be an adjusment on the switch to stop it from releasing at a certin pressure.I think 150psi is max.Set it below.
Aug 19, 2011 | Coleman Air Tools & Compressors
I don't know what that adjustment knob is supposed to do or what the two dials mean.
The knob adjusts the outlet air pressure. One gauge shows tank pressure and the other is your outlet pressure. The pressure is changed by turning the knob (generally counter-clockwise to reduce pressure) Pressure requirements differ depending on the tools you are running. Most air tools will list a Maximum Operating Pressure on them or in the manual.
Mar 21, 2011 | Porter Cable C2002 150 Psi 6 Gal...
Compressor runs to 175psi but trips pressure relief when pressure drops tries to restart motor but motor wont turn blows breaker. changed whole pressure switch have same problem.
The problem is lilkely the check valve between the compressor and the tank -- it is alowing pressure to build from tank to compressor preventing the compressor from turning over. Clean, maybe replace, check valve...
Charlie
Jan 09, 2011 | Craftsman 25 gal Air Compressor 3 12 hp...
Air compressor leaking air
you have a bad check valve ,the little brass valve is working normal
Apr 18, 2010 | Clarke Power Products AC2002A 2 Hp Air...
Compressor hangs up after a few minutes of operation. I have changed both capacitors
Does this occur at the same pressure each time? Maybe the pressure switch is mis-adjusted or defective. Does it restart at the same pressure each time? Does the motor seem hard to turn when the unit quits?. Does the compressor have an adequate level of oil?
Oct 12, 2009 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Air Tools & Compressors Logo
143 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
james allen
james allen
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
