Question about Canon PIXMA MP600 all-In-One InkJet Printer
Timing gears on 1994 saturn dohc
The book shows the timing marks and as i set them in the correct position it does not reflect exactly what the book shows,i need an exact diagram of the timing marks for the cam gears if possible
  • tom3845 Dec 07, 2008
    i have same prob with 1993 DOHC timing of cams to crank.
  • 35 Answers
2012 Ford Explorer timing chain links between timing chain marks
the book doesn't count the number of links but it does show that the cam shafts on the left bank both face are in the correct position when the key ways for the sprockets face the 11 o'clock position and for the right hand bank face 1 o'clock position
reference autodata chain and and gears timing publication
you should have a workshop manual besides you as the setting is critical
Dec 21, 2017 | Ford Explorer Cars & Trucks
How to replace the timing belt on a 1994 mazda 929 3.0 dohc 24 valve engine
1994 Mazda MPV timing belt replacement, 6 cylinder DOHC ...
? 3:46
Aug 11, 2011 - Uploaded by rsarp
1994 Mazda MPV timing belt replacement, 6 cylinder DOHC 3.0... engine so the valves would not be bent ...
How to replace the timing belt on a 1994 mazda 929 3.0 ...
4 hours ago - how to replace the timing belt on a 1994 mazda 929 3.0 dohc 24 valve... I have a 2000 Mazda 626 4cyl 2.0 liter DOHC engine replacing the timing belt, what ... 2004 6s, 3l. where is the canister purge valve solenoid located?
Where are the timing marks on a 1994 mazda 929 3.0l - Fixya
4 hours ago - where are the timing marks on a 1994 mazda 929 3.0l - Mazda Cars ...1994 Mazda E2000 Cam Timing Mark Positions to Replace Timing Belt ... on a 1994mazda v6 dohc 24 valve engine How to align the timing mark on the ...
Mazda Timing Belt Replacement
Dec 03, 2015 | Mazda Cars & Trucks
3.4 dohc timing
there are timing marks or notches on the head and a timing (dot) on the cam gear, and also on the crank gear and block.make shure these are all allined before tightning the belt tensioners.
Mar 19, 2014 | 1994 Oldsmobile Cutlass Supreme
Timing mark on crank shaft on a 3.0 DOHC 94 3000 gt having problem finding crank shaft timing mark I don't no how to aline crank shaft up with the cams time
Gear on crank has a dot stamped on it, gear for cam also has a dot stamped on it. when all is put together, the two dots must align with each other at the closest point of rotation.
Sep 27, 2011 | Cars & Trucks
I have a 2000 Mazda 626 4cyl 2.0 liter DOHC engine replacing the timing belt, what are the correct timing marks position on both cam shafts with #1 piston at TDC
I cant find a picture to show you, but if you rotate the engine until #1 is at TDC there should be a timing mark on the crankshaft gear that lines up with a pointer and the cams should have marks that line up also. Most of the time there is a molded line in the cam gear and it lines up with a molded slot in the plate behind the gear at the 12 O'clock position.
Jun 05, 2011 | Mazda 626 Cars & Trucks
What are the timing marks for a Saturn DOHC 1.9L engine?
The are to properly align the position of the crank cog to the cam cogs.
Apr 08, 2010 | 1998 Saturn SL
How do i install a timing chain in a 1998 saturn sl1? is there any websites or videos of this being done?
The best idea would be to get a Haynes manual from the local auto parts store. The number one thing is to mark the gear/pulley and the block. just use a grease crayon, and draw a straight line from the gear to the block. that way you can align the gears back up with there correct position. also before you make the mark, the #1 cylinder needs to be at the TDC (top dead center) position. I hope this helps Please rate this Thank You
Mar 02, 2010 | 1998 Saturn SL
I have a 1994 eagle talon i replaced the water pump and put on a new timing belt and i can not get the timing right i have tried everything i know what could i be doing wrong? I have made sure the number...
I'm looking at the manual (68030 Haynes) and it shows that if you have the DOHC you make the 2 marks onthe camshafts meet in the center.
That would be at the 3 o'clock position for the left one, and 9 o'clock position for the right one. the crank sprocket and oil pump sprocket align exactly with the timing marks.
NOW, on the SOHC single cam pulley, crankshaft and oil pump pulley all are to be aligned with their index marks, centered, and the balance shaft is to be with the weighted side down to prevent vibration.
I've done the SOHC and the marks are fairly centered when instlalling. Once you've got the belt on in either engine, you should rotate the engine in the normal direction for 2 full revolutions and recheck the timing marks at all positions, readjust, rotate and recheck until set on the marks.
Good luck,
Feb 21, 2010 | 1994 Eagle Talon
Need to know how to line up timing marke dohc mystique 1989
Get the haynes book at the autoparts store or your local library. Show you exactly how to do it.
Nov 29, 2009 | 1998 Mercury Mystique
Canon PIXMA MP600 all-In-One InkJet Printer Logo
67 people viewed this question
old marine
old marine
