SAMSUNG R40PLUSS COULD NOT FIND THE FILE ''FLASH.OCX''
LAPTOP WILL NOT START UP SOMETIMES AND HARD DRIVE WILLNOT RUN,PLUSS SCREEN REMAINS OFF/BLANK
  • zainudin Nov 28, 2008
    LAPTOP ACER FIRST ON OK, ONCE GOES TO ENERGY SAVING MODE AND YOU TRY TO START IT BACK TO ACTIVE IT BY ON PUSH BUTTON AND IT INDICATE ON(GREEN IND) BUT THE SCREEN STILL BLACK . IT ONLY CAN BE SOLVE BY RESET IT ( PUSH BUTTON FOR A FEW SECOND UNTILL OFF) IS THAT A GOOD PRACTICE?
  • 4,806 Answers
The system 32 folder in the windows directory is corrupt, if you can get your machine started, back up all of your data straight away before the system crashes "DO NOT TURN OFF THE COMPUTER UNTIL BACKUP IS COMPLETE" then you'll have to do a recovery either by disk or recovery partition, consult the laptops user manual for the recovery instructions
Posted on Nov 13, 2008
Will not boot...only blank screen with blinking cursor. how do I fix it
You have hard drive issues or windows files are corrupted, remove hardware and reseat it back in place, sometimes this will get the hard drive working, if this fails! set the boot order to DVD CD and try and run the recovery disc, if no change! it means the hard drive has issues and may have to be replaced.
Mar 05, 2012 | Gateway nv Computers & Internet
I'm running windows 7 on a Toshiba L455 and I keep getting a prompt that says; can not find "flash.ocx"
Flash is a programming language that many publishers use to create animations, games, and interactive programs for the web. Flash is also used for programs run locally on a users computer. To use these Flash based programs and web applets, the end-user must have Flash Player installed. One component of Flash Player is a file called "flash.ocx." If this file is missing or damaged, you may get an error message.
There seems to be two root causes of this error. A description and solution for each follows:
  • You receive the error message "Cannot find the file flash.ocx" every time you start your computer or each time you open your web browser (such as Internet Explorer). This is usually the result of a missing "flash.ocx" file caused by an incomplete installation of Flash. Here's how to remedy the problem:
    1. Download the Flash Player uninstallrom Macromedia. Save it somewhere convenient.
    2. Run the downloaded program and allow it to finish.
    3. Once the uninstall completes, restart your computer.
    4. Visit the Flash Player website and download/install the latest Flash Player version.
    5. That's it!
  • You receive the error message "Cannot find the file flash.ocx" at seemingly random intervals or when starting a specific program (other than your web browser). First, perform steps 1-4 of the previous solution. This will insure you have the latest version of Flash Player installed. If you still receive the error message, continue with the steps below:
    1. Navigate to the folder "C:\WINDOWS\system32\Macromed\Flash\". In this folder you will see a file named "Flash9f.ocx".
    2. Make copy of the "Flash9f.ocx" file in the same folder as the original (copy the original, then paste the copied file into the same folder).
    3. Rename the newly made copy to "Flash.ocx".
    4. If the previous steps don't eradicate the error messages, change your screen saver to one of the defaults that are included with Windows (such as "3D Text").
if the problem still persist please let me know.
Apr 15, 2011 | Computers & Internet
Error message- flash.ocx not found
http://www.ocxdump.com/download-ocx-files_new.php/ocxfiles/F/Flash.ocx/6,0,79,0/download.html
Jan 03, 2010 | Dell Inspiron 1525 Laptop
Black blank screen Lenovo 3000 N100
You say the laptop all of a sudden flashed off.
How old is the laptop? You may have suffered one of two things? First of all, if the hard drive will not boot back up, even after using the recovery discs, then that would explain it powering off. I have seen this happen on old desktop hard drives.
Next, try to get the transformer or adapter tested. It may not be putting out enough amperage to run the laptop.
Sep 01, 2009 | Lenovo 3000 N100 0768 - Pentium Dual Core...
Instillation problem
Close everything and try this....
<Start>
<settings>
<Control Panel>
<Administrative Tools>
<Computer Management>
<Disk Management>
Once you get there, your drives should list out along with their capacities and drive letters.
See if the MyBook shows up and if it does, it most likely just needs to have a drive letter assigned to it. Do that, click ok and reboot your machine.
I have about 4TBs of MyBooks sitting on my desk. Some of them I've had to manually install. Some of them just auto install.
Don't trust these things as "sole" back-ups though. They're not very reliable and Western Digital will make no efforts to recover lost data on your drive should it crash....
Good luck. Hope this helped you..
Jan 13, 2009 | Western Digital My Book Essential Edition...
I have a total video player but can't start
Flash is a programming language that many publishers use to create animations, games, and interactive programs for the web. Flash is also used for programs run locally on a users computer. To use these Flash based programs and web applets, the end-user must have Flash Player installed. One component of Flash Player is a file called “flash.ocx.” If this file is missing or damaged, you may get an error message.
  • You receive the error message “Cannot find the file flash.ocx” every time you start your computer or each time you open your web browser (such as Internet Explorer). This is usually the result of a missing “flash.ocx” file caused by an incomplete installation of Flash. Here’s how to remedy the problem:
    1. Download the Flash Player uninstaller from Macromedia. Save it somewhere convenient.
    5. That’s it!
  • You receive the error message “Cannot find the file flash.ocx” at seemingly random intervals or when starting a specific program (other than your web browser). First, perform steps 1-4 of the previous solution. This will insure you have the latest version of Flash Player installed. If you still receive the error message, continue with the steps below:
    1. Navigate to the folder “C:\WINDOWS\system32\Macromed\Flash\”. In this folder you will see a file named “Flash9f.ocx”.
    2. Make copy of the “Flash9f.ocx” file in the same folder as the original (copy the original, then paste the copied file into the same folder).
    3. Rename the newly made copy to “Flash.ocx”.
    4. If the previous steps don’t eradicate the error messages, change your screen saver to one of the defaults that are included with Windows (such as “3D Text”).
Fixya!
Chris (ziraffa)
Jan 11, 2009 | Adobe Photoshop 7.0 for PC
Could not find flash.ocx
download the latest version of flash from www.adobe.com and you should be good to go.
May 24, 2008 | ASUS P5PE-VM Motherboard
Freezing then blank screen
you have a loose connection, good luck....
Jan 08, 2008 | Samsung X15 Notebook
Computers & Internet Logo
157 people viewed this question
David Payne
David Payne
