Question about GE Profile JTP56 Electric Double Oven
Electric Oven doen't heat
I have a GE in wall double oven (model JTP56). It is controlled by an electronic keypad. The upper oven works fine. Neither the broiling or oven element heat on the lower, but the light comes on. I swapped the heating element from the upper to lower oven, and the problem remained with the lower oven, so I think the element is OK. I am thinking of replacing the keypad / controller, but it costs ~ 200 and I'm not sure if thats the problem since the upper oven works fine...
  • 9 more comments
  • Anonymous Mar 13, 2014
    Oven does not heat evidently heating elements are not getting g power. All else seems to be nowmal (clock, light, all controls)
  • Anonymous Mar 15, 2014
    No heat from lower element on a #9119249180 Kenmore Oven
    The upper smaller oven works fine the bigger one does not
    Checked everything I could do still not working
  • Anonymous Mar 16, 2014
    My oven is not heating up. The electronic board is working but no heat.
  • Anonymous Mar 18, 2014
    upper oven temp cannot be controlled
  • Anonymous Mar 20, 2014
    heating element needs replaced.
    Have whirlpool electric cooktop/oven (accubake). The lower heating element in the oven stopped working. How can I troubleshoot.
  • Anonymous Mar 29, 2014
    broil section of oven heats but the lower section does no
  • Anonymous Mar 31, 2014
    Oven element for a classique wall oven model number CL604W. unable to find a new element
    both ovens not heating think both elements are broken , I can fix this myself but I am unsure what elements to purchase ?
    President:
  • 878 Answers
Cdkd, there should be a TC0, on the back of the oven. Thermal cut out. You want to check to see if it is open. You will have to pull the oven out enough that you can remove the back panel cover and check it. The lower and upper oven should have one. It's a very cheap part to replace. If this TCO fails, no heat. Check this first before buying a new board. Catriver..post back.
Posted on Dec 27, 2006
Cdkd: did you find the answer to your problem? I am having the same problem.
What is a fo code on ge doulble wall oven
It is more than likely the touch pad is bad. It could be the electronic control or worst case both. Touch pads are notorious for giong bad. i would look there irst.
Oct 07, 2014 | GE Profile JTP56 Electric Double Oven
Upper oven problem,
The Keypad (membrane) switches seem to be malfunctioning, this is very common on ovens these days especially if the unit has been self cleaned often. If you replace the membrane switch the unit should have all its functions again.
Dec 23, 2007 | GE Profile JTP56 Electric Double Oven
F7 on double wall oven
Hi
Thanks for using FixYa. Error F7 on your oven means that the keypad is shorted or stuck and to resolve this issue you’ll have to replace the Electronic Range control (ERC). Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Aug 23, 2010 | GE Profile JTP56 Electric Double Oven
Double oven. Top is digital. It has started
You have a stuck keypad or a bad electronic oven control. Try pressing all buttons at random several times each to unstick a faulty pad. If that does not work the EOC must be replaced.
Oct 06, 2009 | GE Profile JTP56 Electric Double Oven
The upper and lower oven will not turn on there is power to it and clock and oven lights work there is an FO red light that comes on and beeps and flashes
Built In Oven Fault Codes
F0 or F1 - Failed transistor in control - If code cannot be cancelled, replace the Electronic Range Control (ERC) or touch pad
Sep 21, 2009 | GE Profile JTP56 Electric Double Oven
Bottom oven doesn't heat after running self-clean cycle
Usually, when an oven won't heat, it's because the bake element is burned out. The bake element is the black, pencil- thick tube at the bottom of the oven. When the oven heats, the element glows red. This element has an expected life-span of several years. It may last for only one; it may last for many more. When the element burns out, you need to replace it.
Aug 17, 2009 | GE Profile JTP56 Electric Double Oven
GE JTP56 double oven controls OK top OK bottom no heat
have you inserted the business card as described in the solutions?
Jun 26, 2009 | GE Profile JTP56 Electric Double Oven
Top oven doesn't heat.
We had this same problem in our lower oven and found the solution the night before Thanksgiving. With 26 people coming for dinner, I desperately need both ovens. (Turn off the breaker for the oven before you do this.)
My husband took the control panel off of the upper oven and found a wiring diagram. In the text, it said there was a manual reset for each oven in the access panel for each one. He opened the access panel for the lower oven and found the reset button in the middle of that area. He said it was a black circle with a red button in the middle. After reseting, we turned the breaker back on and everything works great!!
Nov 23, 2008 | GE Profile JTP56 Electric Double Oven
GE Profile JTP56 Electric Double Oven Logo
472 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Oloyede Monsuru
Are you a GE Oven Expert? Answer questions, earn points and help others
