Question about Kenmore 44103 Side by Side Refrigerator
Defrost timer My Kenmore model 62272100 MFG in 09-01 seems to stick in off positionafter defrost mode. Just tapping the casement with the defrost timergets it running till the next defrost cycle. I bought a new timer. Theoriginal part # 2188376, Spec FL-3001-00. The new part # 483212, SpecFL-3001-00 has the flying lead which i hooked up to 2nd connection#"1", same problem so i tried 1st connection #"2". Same problempersists, I tried another replacement timer with same result. Mightthis not be the timer? Please help -Tim
  • 958 Answers
SOURCE: Kenmore Refrigerator 596.72913200 refrigerator is cold and freezer is cold but nothing is frozen
hi lussed,
your problem is still poping up even though it was resolve already. i guessed you should rate a technician in this form as to delete the work from the list of jobs to do.. i am on the way to solve it but you had it solve with a real technician.
can you just rate me?...thanxs...
drcool299
Posted on Jun 25, 2008
  • 105 Answers
SOURCE: Kenmore C978-66792-1 fridge: defrost ices and stops fan
It should just be your ice maker wires and wouldn't be the issue with this fridge
Posted on Feb 10, 2009
  • 531 Answers
SOURCE: defrost timer location on Kenmore model 106.56542400
carry control board part#2149705
Posted on Apr 06, 2009
Sea Breeze
  • 4654 Answers
SOURCE: Where is the defrost timer kenmore side by side 596.52679200
Adaptive Defrost Control will be your timer, Good Luck, Sea Breeze
Posted on May 29, 2009
  • 363 Answers
SOURCE: replacement instructions for ice maker in
I have found service manuels at appliancesfactoryparts.com
Posted on Jul 17, 2009
Model number BFFF54170W. The fridge keeps freezing everything. There is frost at the top of the back wall all the time but things only seem to freeze over the night time and sometimes the noise changes and...
ur defrost terminator is bad and is not going into defrost cycle? and this will stop the fan from circulating the cold air. the heat is only suppose to last up to 20-30 minutes then back into defrost mode? if the defrost timer is bad heres a trick u can use that may get u back into defrost mode, locate the defrost timer in ur fridge usually at top center. then under the timer u will see a tiny slot or hole. if u stick a small screw driver into that hole and turn slowly clockwise till u hear it click? i, it will now go into defrost and u should hear the fan and the compressor go off , hope this helps let me knoiw if u have any more questions, lastly I suspect its not ur timer but ur defrost terminator> meaning is will not allow it to go into heat defrost. its easy and relatively inexpensive.
Mar 14, 2015 | Frost Refrigerators
We have a top freezer Kenmore refrigerator which is at least 12 years old. It is cooling intermittently. It will cool everything just fine for three or four days and then it will defrost completely.
That sounds like your defrost timer is beginning to failm moving slower and sticking into the defrost cycle longer than it should. WR9X520 Defrost Timer
The defrost timer can be found inside and behind the control panel where you adjust temperature. Item 648 in this diagram is your defrost timer=> HERE Let me know should you have questions I will be here to answer them, Thanks Sea Breeze
Nov 15, 2012 | Kenmore Refrigerators
Liebherr KD 900 fridge freezer bought 2001. Both the freezer and fridge are losing temperature, as though it is defrosting and then clicks back on and seems to regulate itself again. This has happened...
The defrost timer sticks in defrost mode and then comes out of it. I've been out of the service industry long enough to not be able to tell you on your model where it is located. Defrost timers on frost free refrigerators are a very common problem.
Oct 11, 2017 | Liebherr KES3660 Stainless Steel...
I hear fan running but it seems to be stuck in defrost mode
Yes, the defrost timer often will stick...you will need to replace it...
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 15, 2010 | Refrigerators
Cooling problems kenmore elite 52293100
The defrost timer is faulty and keeping it in defrost mode.
You will need to replace this.
Jun 02, 2009 | Kenmore Refrigerators
Freezer is not cooling properly
Look inside the fresh food section behind and inside the control panel for a defrost timer and circuit board. Let me know when and what you find. Please unplug first, Thanks, Sea Breeze
E. Cold Control & Defrost Timer/Automatic Defrost
Control
These parts can produce a snapping or clicking sound
when turning the refrigerator on and off. The timer also
produces sounds similar to an electric clock.
Mar 27, 2009 | Kenmore 21.7 cu. ft. Top Freezer...
Refrigerator stops getting cold
Hi!!! You seem to have a bad defrost timer.Just replace the defrost timer. Good luck..Look for frost on the freezer section back panel..Its a sign of a bad defrost timer..
Jan 03, 2009 | Kenmore Refrigerators
Where do i find the def-timer on a whirlpool model#et25pkxxw01
hi,
the timer is located between the freezer and refrigerator. please look at item number 4 on the drawing. that is the timer.
i'm sure this will answer your question.
tnx 4 using fixya,
drcool
Sep 11, 2008 | Whirlpool Refrigerators
Bottom freezer works; Top fridge too warm
The defrost timer is about 6 inches square and about 2 inches thick. It could be located under the box, in front or back. Some models of Whirlpool and Kenmore locate it behind the cover over the light inside the box. Westinghouse is often inside the cooler compartment, in the top. Some Gibson boxes put it in the back, about chest high. It's often hidden, but every self-defrosting refrigerator has one, except for a few models of Whirlpool and Kenmore with factory-installed ice makers — these models have an icemaker which also has the defrost timer built into it. The timer will have a stem that protrudes, or may be flush, which you can turn using a large blade screwdriver. Mark the position with a pencil, then turn it until it "clicks." This should start the defrost mode. The defrost mode will continue for 10 to 30 minutes, depending on the design. If after 20 minutes, the refrigerator has not restarted, or the timer stem has not moved, the timer is bad. When replacing the timer, you must use the correct one. There are about a dozen different configurations with even more types of connections. I suggest you order the part by make, model number, and serial number of your refrigerator to make sure you get the right one. Depending on your brand, and where you purchase the part, the price may be from $20 to $40 for this part.
You can test the termostat,just see if the fridge goes on and off..
If it goes off then the defrost heater sould go on.
The best way is to replace both the timer and thermostat...
if a evaporator gives any problems then the fridge wont cool down.
Hope this helps..
Regards.
Wouter.
Sep 11, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore 44103 Side by Side Refrigerator Logo
82 people viewed this question
Top Kenmore Refrigerators Experts
Sal De GO PATS
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
