Question about Philips 50P8341 50" Rear Projection Television
Bad power supply P/N 313503710471
My TV model # is actually 50P8342.
I'm looking for a cheaper replacement power supply P/N 313503710471. A TV repairman quoted me $495 to repair, parts and labor. I would like to keep the TV but that is too much to repair it. I need help finding a cheaper repalcement part, even a used one I think would work.
  • Philips Master
  • 19,396 Answers
$495 to repair is good.
The original replacement is $469.75 : 313503710471
Refurbished part is $228.83 : 313503710471
Posted on Nov 13, 2008
My asus has restarting showing at all time
Restarting usually is an indication of a faulty power supply.. Either the actual power supply, or bad capacitors on the motherboard. Look at the motherboard at look for bulging, splitting or leaking capacitors. The are little cylinders sticking up all over. The should be cylindrical with flat tops and bottoms. If they are bulging, split or leaking, then you have a bad motherboard. You could just replace the caps, but usually the cost of a replacement board is cheaper, and faster than trying to find replacement caps of good quality.
Nov 21, 2014 | ASUS Computers & Internet
Delayed video and sound when turning on the tv. sony flat screen model 97
Good day!!!!
That problem is usually cause of faulty capacitors on the power supply board..
Just follow this instruction to fix your TV..
1. Open the back cover of your TV.
2. Look at the power supply board..Its normally connected to the power cord..
3. After that,,try to look at the actual image of capacitors if it is bulged on the top so that you can easily determine the bad capacitors..
4. After that,,try to replaced the bad capacitors using soldering iron and soldering lead..replaced the capacitors only with the same type ratings and value..
5. Some of the capacitors not bulged so its better if have a capacitance meter
Jun 19, 2012 | Televison & Video
The tv wont turn on but keeps turning on and off byitself continuosly but not suceeding
Good day!!!
Jun 07, 2012 | Samsung Televison & Video
My 32
YOUR TV POWER SUPPLY WENT BAD. YOU NEED TO REPLACE THE CAPACITORS OR THE ENTIRE POWER SUPPLY. IT IS CHEAPER TO REPLACE THE CAPACITORS.. THAT ARE BURNED OR BULGED ON TOP.. ITS EASY TO IDENTIFIED THEM.. YOU CAN GO AT WWW.BESTDIRECTORYSOLUTIONS.COM ON TV SOLUTIONS AND LOOK AT THE PICTURES OF BAD CAPACITORS HOW THEY LOOK.YOU CAN ALSO GET A REPAIR INSTRUCTIONAL PACKAGE FROM THEM, REQUEST BY MAKE AND MODEL.
Mar 02, 2012 | Hitachi Televison & Video
No power tv 21 in model sharp
Good day!!!!
Commonly that trouble is cause of faulty capacitors on power supply board...
Please follow this step on how to fix that problem on your own..
  5. Some of the capacitors not bulged so its better if have a capacitance meter..
I hope this solution will be helpful...
Thanks for using fixya...
Nov 28, 2011 | Sharp LC-19SB14U 19 in. LCD TV
My 19 inch technica lcd tv won't stay on
Good day!!!!
Aug 26, 2011 | Televison & Video
Was turning on and off before it would stay on. now it won''t even turn on
This is a power supply board problem.
I fixed this problem by replacing the board. The model number for my board is EAY42539401. It cost me $55 plus shipping. A Google search for the board model number should bring up a few suppliers.
I recommend fixing it yourself if you can (all you need is a screwdriver). Replacing it yourself is MUCH cheaper than having it repaired. I purchased it from ModusLinkPTS.
http://www.moduslinkptstvboards.com/EAY42539401-P10344.aspx
Oct 12, 2009 | Vizio VP322 32 in. Plasma TV
I HAVE A PHILLIPS MODEL 50P8341 REAR PROJECTION TV THAT COMES ON ,THE RED POWER LIGHT BLINKS FOR A SECOND AND THEN CUTS ITSELF OFF
Try the power supply. Look on the one in your TV for the part number ; mine is PH3501705441. I ordered one from partstore.com and it was less than $60 shipped. Hope this helps, mine works fine now........and I have a 50P8342 chassis PTV 916
Dec 10, 2008 | Philips 50P8341 50" Rear Projection...
Bad Power supply P/N 313503710471
Without verifying that it is in fact the power supply you could be buying a part that may not resolve your issue. If you've had your tv for a while consider replacing it. New tvs cost a fraction of what they once did and you can purchase a refurbished unit for a considerable discount.
Apr 18, 2017 | Philips 50P8341 50" Rear Projection...
Philips 50p8342 problem
I have tv proyection philips model 50p8342, it is blinking red color on the power switch botton four times and then pause then another four time continuosly.
Aug 15, 2008 | Philips 60P8341 60" Rear Projection...
Philips 50P8341 50" Rear Projection Television Logo
203 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
