Tascam 38 Reel to Reel playback/record problem
My Tascam 38's VU meters intermittently acknowledges signal input when in "INPUT" mode. The channels that do register signal on inputs in "INPUT" mode sometimes do not playback in "SYNC" or "REPRODUCE" modes; there appears to be no signal from the channels on which I just recorded OR some channels play back in one mode and not the other OR the VU meters acknowledge a signal present but I can't hear it's output. What seems to be the problem? Thanks guys.
  • Anonymous Jan 10, 2009
    Selective meters operate intermittantly
  • patrick484 May 11, 2010
    Do all of the meters operate intermittantly, or selective ones?
You seem to have a faulty oscillator.
Posted on Dec 19, 2008
Behringer connect
Try taking direct feeds from your 8 mic channels by connecting leads from the insert jacks to the inputs of the recorder. In order to not interrupt the signal path on the mixer channel push the jack all the way in and then pull out gently until you feel it click. Then you should get a direct signal going to the Tascam and still have control over the level via the fader.
Apr 01, 2014 | Behringer XENYX X2222USB Mixer
I have a teac 2300s tape deck. My problem is when i press the rec / pause or rec play the 2 meters slam to the right. They don't move while recording,but the deck will record and playback. Putting the...
The leads to the VU meters have shorted out. The fact that it only happens when you push "Record" sounds like part of the mechanism is actually causing the short.
Jul 15, 2017 | Pioneer Rt-1011l Reel To Reel Tape Deck...
I installed my tascam mk2.under Cubase LE4. Midi tracks work good.In "set-up devices" I see the Tascam inputs and outputs.Monitor VU-meter is not moving in this audio track and consequently there is no...
Have you clicked the little "monitor" icon (looks like a speaker) on the armed audio track so that it goes orange? Once on, you should see a signal on the VU meter (assuming the line in has a good signal etc). Once recorded, turn the monitor off again to listen to the track with all the others.
Jan 26, 2010 | Tascam US-144 Sound Card
Denon receiver AVR-3300: Unstable source selection
Go over here: http://denon.custhelp.com/cgi-bin/denon.cfg/php/enduser/std_alp.php?p_sid=1NlVrsDj
I have some Denon components myself and had some problems. Ask them here, and within a day you should have solution for this problem.
Probably you have to reset the device to factory settings.
Jul 22, 2009 | Denon AVR-3300 Receiver
My AKAI GX 636 records but can't hear anything on playback (had recorded tape play on another reel to reel) plus the VU needles don't move when you try to play a recorded or pre-recorded tape
Trace the wires from the head to the amp section. Put your finger on where they join (during playback) and see if you can get a buzz. If you can't on either channel, look for something that might be common to both channels. Either a switch, or a pre-amp IC, as being the cause of the fault.
Jul 18, 2009 | Audio Players & Recorders
When i record my vocals its only in one channel why!
It seems that the recording input source is provided as "Line In" whereas you need to select the "Mic In".
This is because the "Line In" is a stereo input and expects input for both right and left channels whereas the "Mic In" input is a mono input which is the same as our default condensed mic device is.
By the way, you would be able to see the graphic VU meters while recording, weren't they displayed that the recording is done only for one channel ?
Always use VU meters for checking the levels for recording, they are available with almost all recording softwares.
Hope this helps.
Thanks
Mar 31, 2009 | Sony Acid Music Studio 7 Full Version for...
TASCAM 80-8 DECK NO VU LIGHTS NO REEL MOTORS CAPSTAIN MOTOR RUNS VU METERS THUMP WHEN SWITCH /MAIN POWER IS DEPRESSED
the machine vu lights were dim the reel motors ran then the lights got dimmer and the reel motors stopped its quite old now but never let me down . best regards kirk
Dec 07, 2008 | Tascam Audio Players & Recorders
Vocal effects on Tascam 2488 MK 2 portable studio
Hi again,
The easiest way to record using an external Lexicon effects unit (without an external mixer) is to connect your mic onto one of the 2488's inputs and assign that input to a channel strip (track). You should have the 2488 sends (output) going to the Lexicon's inputs. Then connect the Lexicon outputs back into another set of inputs on your 2488 and assign those inputs to two empty channel strips (tracks).
Then you will have to take that channel that has your mic input assigned to it and press send and set the levels there to send the signal out the sends (to the Lexicon).
Now you have a channel strip assigned to the mic input which contains your dry signal, and you have the two inputs returning from the Lexicon which contains your wet or effected signal.
You then have some options. You can control the amount of effected signal you hear while recording by adjusting the faders of the two wet tracks and you can either record the dry signal or the wet signal (or both) onto separate tracks.
Typically when recording the singer will want to hear an effect (say reverb) on his voice, but the engineer wants to record only the dry track at recording time (because effects can always be added later, but they can't be taken out). To accomplish this you would use the setup above, but only arm the mic input track for recording. In this way the singer hears the reverb, but only the dry vocals get recorded and the engineer can add reverb to that track again later as desired (and mix it back with the dry vocal etc).
On the other hand if you want to record only the effected signal you would simply arm the two channels to which the inputs coming back from your Lexicon are assigned for recording. This will get you a recording of the effected signal only.
Hope this helps you do what you are trying to do.
Cheers.
bd.
Aug 30, 2008 | Tascam 2488 Portastudio Multitrack...
Tascam 22-2 no sound
Yes you need to hook it up to an amplifier and speakers through RCA cable on the back. And or you can use headphones if there is a headphone jack?
Also make sure there is something recorded on the reel tape in the first place. You can do a test recording of something like a CD from your CD player or record something, then play it back, make sure you turn the record input volume knob up and make the RCA connections on the back of the reel unit and connect to your playback source you want to record. When you playback the reel tape, the db meters should be moving on the front of the reel deck, if they move then you most likely have some sound recorded on the reel tape.
If you still can't hear any sound and the db meters are moving, then check all your connections again and volume output knob on the reel deck. Hope this helps?
Sep 26, 2007 | Quantegy 456 Tape Reel(1/2 in. x 10 1/2...
314 people viewed this question
 Grubhead
Grubhead
