Question about Miele CVA4070 Coffee Maker
I SIGN APPEAR IN THE PANEL
SYSTEM IS STUCK CAN WE DO A RESET
  • sharon_avino Nov 14, 2008
    I unplug for more then half and hours i but it came to the same status again
    then I push the on/off shortly and the system whent to the descale status and continue the process from that for 10 minuts and complit the process
    thank for the help
  • 833 Answers
I assume you've got an error code on the panel. If unplugging the unit for half an hour doesn't fix it, you will need to find out what the code is and then deal with it. Sometimes, if you open the unit, you can cycle connectors and get them running. It is possible to test each item with an ohmmeter. If it is the electronics, it often does not pay to repair.
Posted on Nov 13, 2008
I disconnected my firetv stick to send back.but then i realized i never took my info,password,etc. Out of it.do i need to reconnect it to delete info?
I would absolutely reset the firstick.
Steps To Reset Your Fire TV or Fire TV Stick
  1. On your Fire TV device, click Settings
  2. Scroll over to the right and click System
  3. Scroll down and click Reset to Factory Defaults
  4. A dialog will appear that reads "You are about to reset your Fire TV to its original factory settings. Your sign-in information and personal preferences will be lost". Click the Reset button.
  5. The system will go through the restore process and this can take approximately 5 to 10 minutes. Be patient and wait for your Amazon Fire TV to reset.
Nov 02, 2017 | Computers & Internet
D90 won't work. Blinking Clock in top LCD panel.
First, turn the camera off and then remove and reinstall the battery. Turn the camera back on. If the clock and battery icons still appear, try resetting the clock. If this doesn't work, contact Nikon technical support at www.nikon.com and see what they have to say. It may require a repair but determine if the camera is still under warranty. If so, Nikon may repair it at no charge.
Jun 13, 2014 | Nikon D90 Body Only Digital Camera
How to unlock HUAWEI s7-931w tablet
If your having problem like this I suggest that you perform a hard reset. To hard reset just simply follow this step.
And remember reseting can delete your all access data specialy passwords and code.
To hard reset:
1. Turn off the whole system.
2.Hold together buttons: Power + Volume Down. In several second until logo appear on the screen.
3. Release the buttons. And without asking and without notice System will automaticaly doing a reset.
If this will not succesfull, try to create google account on PC. Then remember all information you've made, the email and password. You said system asking you to sign in to google. Use all information you've got to sign in.
Note: The google method is not working on other tablet, but most of it solve the problem. Then you should go to area where you have an a access of wifi, place where can you connect a wifi. Internet connection is realy realy needed.
Hope it will help.
Jan 28, 2013 | Huawei mediapad 7 s7 931w wifi tablet
Ipod froze
A white screen on an iPod Touch is the sign of a generic error, meaning you won't get a specific error message. Usually when this happens the white screen won't change and the iPod is frozen on that screen. Apple Support outlines a specific series of steps to take to deal with this problem, from turning the iPod Touch off to completely reinstalling the operating system if necessary.
What the White Screen Means The white screen is a sign that a software error has occurred in the iPod Touch. Unless you received an error message first, it's usually something near the root level of the iPod's operating system that caused the iPod to cease functioning normally. Rather than shut off completely, it goes to this white screen to let you know there's been an error. Unfortunately you usually lose unsaved information when this occurs. b> Resetting b> Try turning the iPod Touch off, then on again. This is the simplest way to reset your iPod Touch. If it remains stuck on the white screen, force a reset by holding down the Sleep button (top right corner) for about 10 seconds. The screen will go dark, then the Apple logo will appear. If it turns off and doesn't turn on again, the battery may be too low. b> Restore b> If a manual reset doesn't work and the screen remains stuck on a white screen, you'll need to restore the iPod to reinstall its operating system. Plug your iPod, via its charger cable, into your computer. Open iTunes and click on your iPod, then the "Restore" button on the main screen. b> Problematic Apps b> If you consistently receive a white screen while using a particular app, the app may be faulty or installed incorrectly. Try re-syncing the app to your iPod Touch and see if that solves the problem. Otherwise, you may need to delete the app to avoid the white screen problem.
b>
Jan 27, 2013 | Apple iPod touch
Android vimicro logo stuck on screen
ANDROID Tablet Freezes at Android startup screen
For Superpad VI - 10.1" Android Version 4.03, this worked for me!
1. Press & hold START button
2. When "VIMICRO" appears, Then Press & Hold the MENU button
3. The Android System Recovery <3e> Menu should appear
4. Scroll down using the Volume Key to "wipe data/factory reset"
5. Press HOME Button
6. Scroll down to "Yes - delete all user data"
7. Press the HOME Button
At this point the system will do a recovery and hard start, and will be on "reboot system now
8.Press the HOME Button
Your system should reboot normally, but you will need to enter all new data, as it has been wiped clean.
Apr 03, 2012 | Tablets & eReaders
Sony tv, Red key sign appear on right top of screen on one channel. Cannot switch to any other channel except on/off .
go to the menu and go to the factory settings and reset everything or go to the place they will ask you put the passwor put 0000 and unlock the other channels try both each tv is different
Oct 17, 2010 | Televison & Video
Unable to update my protection after uploading new 2009 Micro Trend Internet Security package using a 64-bit operating system. Error message advises to check my proxy settings. I've done that. System is...
this is the resolution i got from trend micro regarding this error. it worked for me, so i thought i should share: I have reviewed your case and I understand that you are getting an error message that says “Unable To Update Your Protection” when updating the Trend Micro Consumer Product. With regard to your concern, this problem happens if there’s a missing component in your computer’s Registry. Let us configure the registry of your computer using the Registry Editor of Windows. Refer to the following. 1. Click on the Start button or the Windows Orb Button. 2. Windows XP: Click on Run then type regedit on the text field then click on the OK button. Windows Vista: Type regedit on the Start Search above the Windows Orb button then press Enter key on your keyboard. And the Registry Editor window will appear. 3. Click on the plus sign (+) or the arrow sign (>) besides HKEY_LOCAL_MACHINE. 4. Click on the plus sign (+) or the arrow sign (>) besides SOFTWARE. 5. Click on the plus sign (+) or the arrow sign (>) besides Microsoft. 6. Click on the plus sign (+) or the arrow sign (>) besides Windows. 7. Click on the plus sign (+) or the arrow sign (>) besides CurrentVersion. 8. Click on the plus sign (+) or the arrow sign (>) besides Explorer. 9. Click on the Shell Folders. 10. Look for the Common Appdata entry on the right panel. If there’s a Common Appdata entry on the list: - Double click on the Common Appdata entry and the Edit String window will appear. - Windows XP: Type C:\Documents and Settings\All Users\Application Data on the text field under Value Data. Windows Vista: Type c:\ProgramData on the text field under Value Data. - Click on the OK button. If there’s no Common Appdata entry on the list: - Right click on an empty space and options will appear. - Click on New and options will appear. - Click on the String Value option. - Set the name to Common Appdata. - Double click on the Common Appdata entry and the Edit String window will appear. - Windows XP: Type C:\Documents and Settings\All Users\Application Data on the text field under Value Data. Windows Vista: Type c:\ProgramData on the text field under Value Data. - Click on the OK button. 11. Close the Registry Editor window. 12. Restart the computer for the changes to take effect. After doing the suggested solutions, you should now be able to update the program successfully.
Jan 22, 2009 | Computers & Internet
Bottom right red light is on and a message saying system error is on yhe screen (e74)
the led is the hard drive indicator
when does this error appear ?! At boot ?! If so, check all u're cables that are properly inserted (inside the computer) also do a BIOS reset (see u;re user manual) just in case it got stuck ...
Also in u;re user manul u should find what the e74 error means
also try removing u're hard drive, if the error does not appear anymore (a no system disk or disk error will appear though ) then the issue is u;re hard drive or the cables it connects to the comp ...
Aug 08, 2008 | Computers & Internet
Remote won't work tv, and stuck in volume down
you sound like you might be having front button problems. if you take the front speaker grill off then unplug connector ZF and it restores normal operation than the front panel buttons are bad. basically the tv will respond first to the buttons and nothing else until the button is depressed.
Mar 29, 2008 | Mitsubishi WS-65611 65" Rear Projection...
Miele CVA4070 Coffee Maker Logo
107 people viewed this question
Top Miele Coffee Makers & Espresso Machines Experts
just-ice
Michael Galve
Michael Galve
Colin Stickland
Colin Stickland
Are you a Miele Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
