Question about HP OfficeJet 6110 All-In-One InkJet Printer
Scanner Failure(Turn Power Off & than On again)
When I power on my HP Office jet 6110 All in One fistof all its scanner comout and than start going back word slowly slowly and after it goes back than a sound came like (trrrr trrrr trrr trrrr) than after some time a meassage starts appearing on its only small screen
Scanner Failure(Turn Power Off & than On again). I have contacted my HP dealer but he has said that nothing can he do for that problem. But he also said me that when the scanner is going back to its place and it reaches under the shade( at it original place where its been satnd before ths problem) unplug the power cable and than after some time plug it again. It works for some time but know it works only 1 in 30 times. Plz help me . No repairer in pakistan has said that he can solve this problem plz. do some thin send some images of the thing or IC's or chips which are wrong in it so i can show it to them and they will solve th problem.
waitin for reply with my heart ali_arsd@hotmail.com
  • jskpnk Nov 13, 2008
    Same problem. When turning unit on the scanner starts up and then goes backwards and then the unit starts making lots of noises. Then it shows scanner failure on the lcd screen.
  • Anonymous Jan 11, 2009
    "chug chug chug chug"
    The best I've got out of this is by plugging it into a strip plug, and flipping the switch off, then back on again after about a half hour. The strip plug built into my computer desk has individual switches for each device plugged into it, which makes things easy (even though I only plug in the printer to this outlet).
    Strangely enough, after being off for a few days and turning it back on I'll get the problem again! And this fix doesn't always work, but at the very least the strip plug is easier than pulling the cable out every time :(
  • 28 Answers
Fiend your solution direct from hp. Here is your solution...
http://www.hp.com/printer/prob676ijt65/solution
806
Posted on Feb 28, 2009
  • 33 Answers
The issues you are getting are common when the scanned board has or is failing and the only way is th replace the scanner assy but its not worth it at all to repair it will cost more to repait then to replace Im sorry to say
Posted on Nov 16, 2008
How do I solve the "scanner failure power off and on again" message for an h.p. 6110 officjet all-in-one printer/scanner/fax?
Hi Paul,
Scanner Failure usually results in Hardware Failure. However there is one step you can try. Try connecting the printer directly to wall outlet or any other power outlet and the issue should be resolved.
Regards,
Sean
Apr 19, 2013 | HP OfficeJet 6110 All-In-One InkJet...
HP office jet 6110 all-in-one Scanner Failure message cannot be erased. When power is switched off/on makes load grating noise and Scanner Failure message reappears. Copier function will not work either.
Print head sticking needs oil on shaft that its slides on. Open cover and put a drop of oil on each side print head Shaft cut it back on and see if this helps .may half to do this 2 or 3 times to get the oil on to bearings . They dry out over time. Good luck
Aug 12, 2010 | HP OfficeJet 6110 All-In-One InkJet...
HP office jet 7310 all in one. when trying to fax it says scanner failure. Turn off power and restart. This accomplishes nothing. Suggestions?
This means that there is an internal failure of some kind (e.g. the scanner is stuck). Be sure that the shipping lock has been removed and try again. HP is very good about support, try contacting them through their website or by phone.
Good Luck!
Feb 05, 2010 | HP OfficeJet 7310 All-In-One InkJet...
Scanner failure message
the main system is faulty same thing happened to me.
Aug 14, 2009 | HP 7210 OfficeJet All-In-One Printer
My Office Jet 7310xi scanner failure
Does it scan from either the doc feeder or from the flatbed itself?
Can you COPY a page?
Are you using the buttons on the printer, or do you work from HP director?
Mar 29, 2009 | HP Officejet 7310 All-In-One Printer
I keep getting a scanner failure error
Let's try this. Turn power off, unplug the cord from the surge strip or wall socket. Leave unplugged for about 30 minutes, then plug back in and turn on. Hopefully this will fix your problem. Good luck.
Mar 19, 2009 | HP OfficeJet 7130 All-In-One Printer
HP office jet 6210 scanner failure error
have you tried to reset the printer?
(Take the power cord off hold # 3and then turn the printer on.)
That is an initial position problem
Parts are no longer available for this model from HP...
Jan 16, 2009 | HP OfficeJet 6210 All-In-One InkJet...
Scanner failure, while booting up, blocks all other functions.
no you can not disable your scanner
you ust have to repair your scanner
if you have any warranty then go for it
or visit any technical person who can check cables and scanning tube of your scanner
Nov 17, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Hp office jet 6110 all in one
THE Office Jet 6110xi has the problem is the scanner carriage having a problem when it looses power. The carriage does not "see" the signal it needs to indicate to the scanner carriage has reached the end of the scan deck -- I open the scanner top (remove screws, lift ONLY several inches leaving the front "clips" or "clamps" connected so the rear part of the top deck lifts up).
I have wiped the glass and the scanner carriage.
THE BEST THING THAT SEEMS TO WORK IS TO MAKE SURE THE THIN PLASTIC INSERT BETWEEN THE GLASS AND THE PLASTIC DECK --- WHICH IS NOT SEEM FROM THE TOP SCANNING DECK BUT ONLY FROM THE UNDERSIDE WHILE HOLDING UP THE DECK --- IS PROPERLY SEATED SO THE SCANNER CARRIAGE "SEES" IT.
ALSO HAVING WORKED IS SOME COMPRESSED AIR BLOWING IN THE SCANNER CARRIAGE AREA. I PRESUME SO DUST GETS IN THERE AND THE AIR REMOVES IT.
This happens almost every time the scanner/printer looses power, so I usually try to avoid unplugging it or shutting it off!!!
Finally, do not give up. This can be fixed. Sometimes it took 2 minutes, sometimes it took an hour of cleaning, wiping, blowing air into it.....
M
Mar 03, 2008 | HP OfficeJet 6110 All-In-One InkJet...
HP OfficeJet 6110 All-In-One InkJet Printer Logo
81 people viewed this question
Ben Johnson
