Question about Amana AOGD2750 Gas Double Oven
Fan stays on
The fan runs continuously. Came down this AM and the oven fan was running. Can't get it to stop. Any ideas? Thanks
0 characters
1 Points
Owen fan always run, after plug owen in. How to stop it or reset it?
Your Fan thermostat has failed, now the cooling fan will run forever trying to cool the broken part... Look for the thermostat in the wiring diagram that is with the oven, meter it for continuity, and if it fails, use the model number to order a new part from a local part store- your model number represents nothing here in America or I would tell you the part #! Range Stove Oven Thermostat 318578506
Jun 25, 2016 | Electrolux EOB6630 Ultrafan Electric...
How do I fix a continuously running upper oven fan
Without knowing the make and model, this is a guess, the fans usually run for some time after switch off, to allow cooling I am guessing this carries on until you isolate the mains. If so you have a thermostat problem. It would be easier to de-fine if there were more information.
Oct 31, 2014 | Ovens
Why does the cooling fan on the oven continue to run?
Never heard of a cooling fan in an oven.they are usually used for fan baking, which speeds up cooking.
Sep 19, 2014 | Ovens
Why does the fan run on for so long after the oven is switched off?
There is a thermostat that controls the fan, until the oven cools to a preset level the fan will continue to run to cool things down.
Nov 19, 2010 | Smeg Ovens
Oven will not stay on .I believe it may be the timer
You have to ensure that the clock is set correctly with the time and it is in manual mode and nothing else is set on it.
Also that the background cooling fan has to be running as the oven overheat devices will kick in. This fan continues to run for about 10 mins, once the fan oven/top oven/grill is switched off. When it is running there should be a gentle draft of air coing out of the gap between the top and bottom oven doors.
Do you hear any relays operating when the fan oven turns off?
Sep 13, 2009 | Stoves 720EF Electric Double Oven
Bosch HBN745 Single Convetion Oven - Fan won't stop & still maintains heat
Sounds like it is the thermostat that is faulty.
Go to your browser bar and type in
Then in the search box type in fitting thermostat to oven
Click on appropiate video and follow instructions, this should help with your prob.
Plz rate my solution.
Dec 29, 2008 | Bosch HBN 745 Stainless Steel Electric...
Fan runs for hours after use
The fan is in place to cool the electronics it will run after the unit is off it is possible you have a bad sensor on the fan circuit leaving it to run too long
Apr 05, 2008 | GE JTP15 Electric Single Oven
Amana AOGD2750 Gas Double Oven Logo
18 people viewed this question
Top Amana Ovens Experts
Michael Thomas
Michael Thomas
Dan Webster
Dan Webster
Are you an Amana Oven Expert? Answer questions, earn points and help others
