Question about Mitsubishi WS-55907 55" Rear Projection Television
Our local dealer's repair guy came and said the tube is leaking.
The liquid has gotten on some of the tubes I believe. He also stated the parts are not available. Can you help me/him find the parts?
I hav a ws-55907 if you would like make an offer on parts let me know.
evilcaligrl04@aol.com
Posted on Dec 16, 2008
2006 MV Agusta F4 1000 S leaking fuel
Hi, Rudy if it is leaking out the vent tube you need a new gas cap otherwise the answer to this question is way above my pay grade for this situation I would call my local dealer or reputable shop's service/parts department and inquire about any possible quick fix, answers, or parts inquiry. If necessary, transport your bike to the dealer or shop and have a professional technician take it for a test drive, if it is in running condition, and give you a written estimate of repairs and answer any specific questions you may have about your problem.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
Fuel tank leaking gas
https://www.topspeed.com/motorcycles/motorcycle-reviews/mv-agusta/2006-mv-agusta-f4-1000s-ar2902.html
MV Agusta F4 1000 Workshop Manual
OEM Spare parts for MV Agusta motorcycles
http://mybikemanuals.com/mv-agusta/mv-agusta-1000-owners-manuals
Nov 03, 2017 | 2006 MV Agusta F4 1000 S
Leaking from a tube like object under the front of frig. It looks like a small pinhole in the bottom of tube. Can I take part off and replace
Here is a link to Whirlpools User and Part Manuals=> sea_breeze_21.jpg From the drop down choice choose Consumer and paste or write ED5VHGXMB10 and then click search.
And below is a link to Point and Click=> sea_breeze_6.gif I believe your water supply line has a pinhole in it and you should shut off the water at its source to pevent any electrical shorting. Here is a front view of your refrigerator=> ED5VHGXM10
I believe it is either the tube filter inlet or the tube filter outlet=> 8201597 or 2255153 You may find locally, If you need me please let me know, Thanks, Sea Breeze
Dec 11, 2010 | Whirlpool ED5VHGXM Side by Side...
Water leaks from plastic perforations @ fill zone when washer off
I believe this is the part you're looking for:
http://www.fisherpaykelparts.net/product/420833/420833-Spray-Fill-Assembly/
It looks like it will run you $27.95 (+s&h probably)
F&P's site says that this tube is broken from overloading the machine
Dec 31, 2009 | Fisher and Paykel GWL11 Top Load Washer
Coolant leak on steel tube on the front of the engine Need to know the name of the part needed.
Hi ,in those engines there could be a few diffrent metal tubes ,your best bet would be to stop by a shop or a parts store and ask one the guys to take a quick look and see which one it is ,then you can go to your local dealer or a wrecking yard and get a replacement one ,good luck to you!
Aug 08, 2009 | 1999 Pontiac Sunfire
MELTED PLASTIC TUBING WITH CLAMPS AND ENGINE DRY
Hi, Dgibbs0214 for this situation I would call my local dealer or reputable shop's service/parts department and inquire about any possible quick fix, answers, or parts inquiry. If necessary, transport your bike to the dealer or shop and have a professional technician take it for a test drive, if it is in running condition, and give you a written estimate of repairs and answer any specific questions you may have about your problem. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
Yamaha YZF600 YZF600R 1994 2007 Service Repair Manual PDF Download Manuals...
OEM parts for Yamaha
Yamaha YZF600RP Owner Manual
prody71 html Performance Products YZF600 Thunder Cat
Yamaha YZF 600 R6 06
May 03, 2009 | 2003 Yamaha YZF 600 R thunder cat
2005 Chrysler Pacifica-Air conditioning leak
The 05/04 Pacifica did not come with an elbow tube on the drain line for the AC drip pan. As you drive, the air flow into the tube pushes the condensate water back into the pan which is inside above the passenger floor board, the drain line is under the hood on the firewall. I spoke with the parts guy at the local Chrysler dealer, he sold me a drain tube for the 06 (~$10) and I installed it, wasn't too hard to do from the top if the engine is cold. The elbow slips on over the drain tube. Make sure to point the tube down. It only took one trip to start seeing water drip out of the tube and the floorboard started to dry up and almost three years later, the floorboard is still dry.
Apr 09, 2009 | 2005 Chrysler Pacifica
Blue fluid leak
There is no blue fluid in a refrigerator.
Something external or a add on is causing the blue fluid.
Mar 13, 2009 | Kenmore Refrigerators
I don't know what kind of oil pan I need for a 2000 volkswagon jetta 2.0 engine
The oil pan is aluminum and can be damaged easily. As far as i know, it is dealer part only. Check with your local part store and dealer for availibility. Also, the oil pan uses a sealant, not a gasket. If you repair it yourseslf and get parts from dealer, the whole tube of sealant is too much. If the whole tube is used, the oil pick up tube may get plugged.
Mar 03, 2009 | 2000 Volkswagen Jetta TDI
Need new green picture tube
If the repair center is an authorized Samsung service center, they should be able to get hte part for you. I don't have parts listings for Samsung sets, but the part numbers should be available from Samsung directly. Since you know the problem, try another service center that is associated with Samsung. Not all independent servicers can get parts from all manufacturers.
Dan
Jul 09, 2008 | Samsung PCL5415RB 54" Rear Projection...
You dont need a new tube. What you need is to repair the seal on your old tube and replace the CRT coolant fluid. There is a coolant chamber attached to the tube with long bolts with springs on them that contains coolant to prevent your tubes from getting hot. Yours may just need tightening, but I would replace the seal just to be safe as thecoolant can and will destroy your circuit board if its allowed to continue to leak on it.
Jan 15, 2008 | Samsung HCL4715W 47" Rear Projection...
Open Questions:
Mitsubishi WS-55907 55" Rear Projection Television Logo
64 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
