Question about Philips Hopper SV10 Multimedia Projector
Proxima ultralight DS1 service manual
Hi, My Projector is broken but i want to repair it, so i haven't any information for help me. Anybody have the manual o know where to find it?thanks
My Proxima Ultralight SV1 projector no longer projects what's on my Dell laptop computer screen. It's been working normally until this week. It still projects "searching" but seems...
Press Fn key and F8 key to turn On external monitor output in laptop so projector will get video output of laptop.
Hope this will help.
Thanks.
Aug 03, 2011 | InFocus Proxima UltraLight SV1 Plus...
Hi. I am considering purchasing a used Proxima
I wouldn't buy it do to the fact that parts for this projector are rare.
Sep 25, 2009 | InFocus Proxima UltraLight SV1 Multimedia...
Proxaima ultralight x350 light turning off
Hello fellows,
I have the same problem with my projector (Proxima UltraLight X350). I have the firmware v1.34.
On my projector, I found a workarround : if I press the 'top arrow' button on the projector at the message prompt, this one simply disapears and the projector works for hour. The drawback is the red led that don't stop blinking.
Can you cooperate and tell us if this solution worked on your projector ? Please also join the firmware version (found in the service menu, with the lamp life).
Cordially,
Tristan
Jun 20, 2008 | InFocus Proxima UltraLight X350 Multimedia...
Service menu proxima x350 , ASK M3 or Yokogawa D-1200X
you should be able to by the menu button on the top of the machine.
Jan 26, 2008 | InFocus Proxima UltraLight X350 Multimedia...
Proxima ds1 not lighting
hi
replace or clean the Air filters. Run the lamp reset command if you have.if not solved then check ballast unit which ignites the lamp.
try this also, press the poweroff button on the remote control for ten seconds, the lamp will reset to zero, if you run the projector more than 1100 hours earlier.
Viren
Jan 16, 2008 | Office Equipment & Supplies
Proxima Ultralight x350 no valid input source error?
reset the settings to factory default. if that doesn't work, the lamp may not have enough power to stay on. if the lamp doesn't have many hours on it, it's the ballast.
Jan 05, 2008 | InFocus Proxima UltraLight SP1 Multimedia...
Drivers available
You can download all the information you need from:
http://www.askproxima.com/service/m3/m3.asp
Jason
LCMA Insurance
http://www.lcmainsurance.com
Dec 06, 2007 | InFocus Proxima UltraLight X350 Multimedia...
Proxima Ultralight Projector 350x
The filters probably need cleaning. Also check and make sure none of the vents are being blocked.
Nov 20, 2007 | InFocus Proxima UltraLight X350 Multimedia...
Philips Hopper SV10 Multimedia Projector Logo
202 people viewed this question
Top Philips Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Philips Office Equipment and Supply Expert? Answer questions, earn points and help others
