Question about Kenmore 22422 Top Load Washer
Washer stops and must be restarted flashes F51
It will stop during the wash or rinse agitation and flash F 51. This problem appears on all the wash cycles except the Express Wash, it even does it on the clean cycle. I have to stop and start it several times up to the spin cycle to complete a load.
  • Anonymous Mar 25, 2014
    The other cycles after a certain time, stops during the cycle and the start buttons flashes
  • 62 Answers
There is a updated wiring harness and sensor on the the bottom of this tub on the motor. It needs replaced
Posted on Nov 15, 2008
How di I stop the F:51 from flashing where the time left for a load to be completed stopping the load in the washer to wash, rinse and drain?
If its a Whirlpool machine, F51 has something to do with whats called a rotor position sensor, It tells the machine that the bowl is or isn't turning. Check and make sure the bowl hasn't jammed up.
Jan 01, 2015 | Washing Machines
Why does my washer stop in cycle
Raise and lower your lid six times to reset timers.
Sep 30, 2017 | Speed Queen CTSA0AWN Front Load Washer
Little bit of Water goes in drum does not turn or agitate buzzes and stops working. F 51 flashes?
The F51 error is a RPS (rotary position sensor) board failure where the control board looses contact with the RPS during the machines operation. The RPS uses hall effect sensors to determine the speed and direction of the drive motor, allowing the control board to constantly monitor the motors operation. Because this error is a communication error and not a mechanical error with the motor itself (that would be and F52 error) we can limit our trouble shooting to the three items that make up the RPS circuit, the control board, the wiring harness, and the RPS itself.
Jan 16, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
Stops during wash cycle
my cabrio agi washer will stop constantly during the wash and rinse cycle and it will say F51 and dL
Sep 17, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Stops during rinse cycle
Dear customer,
              We recommend the following when a washer's cycles dont advance..
  1. If the washing machine fills with water and begins agitating, but the timer does not advance, the timer probably needs to be replaced
  2. If the timer does not advance while the washer is in a spin cycle, the timer probably needs to be replaced
  3. If the timer does not advance during the rinse cycle, check whether water has filled the tub, if not, it is likely cold water related. Check the cold water supply valve, check the supply hose for kinks, check the filter screen and check the water inlet valve
For details on how to self test these parts plz refer to http://www.acmehowto.com/howto/appliance/washer/washer.php
Plz rate this solution.. thank you..
Apr 09, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Stops in middle of wash cycle and F51 codes keeps flashing
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Good news for Oasis F-51 sufferers! Sears will replace the electronic control board (the F51 prob) for free, in warranty or not. Serial #s for the Bad Board are: CS48 - CS52 or CT01-CT49. Call Sears at 800-847-9083.
You hv to rate me ‘very helpful’, or the call won’t get thru!!
Mar 20, 2009 | Kenmore Elite 45986 Front Load Washer
Washer full and then stops and gives a beep while flashing F 51
On Kenmore F51 means Motor RPS Failure, the motor is not spinning or the motor sensor detects a fault.First unplug the power cord for one hour or so to check if it is a jammed sensor, and see if reset.
Dec 06, 2008 | Kenmore 24032\24036 Top Load Washer
F 51 flashing, washer stopped
Suz, F51 is a rotor position failure code. Try unplugging the unit for 1 minute and then restart. I see a lot of this on the Oasis. You should be able to turn the basket freely by hand. If not have someone check to see if something is caught between the tub and basket. If that is ok, then someone will have to check the sensor itself. This can be a tough job for someone who hasn't done it before. You have to tip the washer back, drop the rotor and motor to get at the sensor. Sometimes just scraping the contacts on the sensor will cure this problem, sometimes the sensor has to be replaced. If it's under warranty, then I would call for service. If not, and you want to try to fix it yourself, just add me as one of your buddies and I can walk you through it. Catriver.
Feb 03, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore 22422 Top Load Washer Logo
188 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
