Kenmore Elite HE3 water problem
My washer is 5+ years old. I am having a problem with my clothes no longer getting cleaned. I never noticed the water level before, but now that I have a problem I have been checking to make sure it fills. No error codes, clothes get wet, but no noticeable surplus of water. I read that others have added water (up to 8 gallons per load) to their washers to increase cleaning efficiency. What do you think of this? Is it safe? Are there alternatives, other things I can check that may be causing the problem?
  • Anonymous May 19, 2009
    My sons and husbands white undershirts still smell of perspiration after going through a whitest white cycle. I started to watch how much water was in the tub and could not see any at all. Lots and lots of water spraying into tub none staying inside? Can not get technical assistance from SEARS...been hung up on often. If anyone can tell me how much water should be visible while washer is in the wash cycle I would be grateful.
  • 5,911 Answers
These washers are designed to use less water (about 5 to 7 gallons) per washload as opposed to the standard 35 gallon capacity of top loaders. That's why they are considered High Efficiency washers. They use less water, less electricity to run, and spin at a higher rate to extract as much water from your clothing as possible. That's also why the use of HE detergent is mandatory with these units. The detergent is formulated to be used with washers that use less water. If you are using standard detergent you are, in affect, putting a higher concentration of soap in the washer, because it is formulated for use in a 35 gallon capacity tub. This can cause the premature failure of gaskets, seals and the drain pump, as well as, leaving residual soap in your clothes. Now...I'm not accusing you of improperly using your appliance. I'm merely giving you information that a lot of consumers just don't realize.
I don't know how others have been adding water to the wash tub, unless they stop the unit and pour water in the tub. I personally would not recommend it, because you're deluting the detergent in the process. The detergent has cleansers and suspenders that help clean your clothing and help suspend the dirt away from your clothes. Adding water would only reduce the cleaning ability of the detergent you are using. Also, take note of the HE detergent you do use. Some of them are double (2X) and triple (3X) concentrated. Which means you only have to use a little to do the same job.
I personally own one of these washers and have never had a problem with getting clothes clean by using HE detergent with the current water per load capacity. I hope this helps you. Let me know if you still have questions.
Posted on Nov 14, 2008
I have a kenmore elite HE3 washer. I was getting the sud error and then eventually F02. I cleaned out all the drain lines and pump filter trap and this did not help. I've now replaced the pump
I endevor to purchase a new unit. I've had the same electrical issue with the "F" variable coming up for EACH cycle. I've pressed the Pause/Cancel button and attempted to resume the cycle. While that did work, again, the "F" would come up and the cycle disrupted. I think I will end up paying quite a bit to have it serviced. My washer is 7 years old and I've had it serviced twice to date. I intend on purchasing new in the New Year, a Samsung or LG.
Nov 24, 2012 | Kenmore Elite HE5t Washer
I have the Kenmore Elite Gas Dryer (not steam). I
Take pantyhose around the inside and see if it catches.
Pay particular attention around the drum/door area.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jun 11, 2010 | Kenmore Elite HE3 Steam 8674 Dryer
I have a Kenmore Elite HE3 Tearing holes in my clothes
Are you using HE ( high efficiency ) detergent?
If you are using regular detergent the machine may be sensing all those bubbles and may be working longer to get rid of them.
Try using a net/lingerie bag for delicate clothes.
This type of washing machine works by sensing when the clothes are saturated then it will start to tumble back and forth, and it will continually drain out the dirty soapy water and bring in clean soapy water, then spin out and go into the rinse cycle..
It's all done by the machine sensing when it's time to go to the next cycle.
I am wondering if you are maybe using too much detergent.. Only use the max of 3 tablespoons of HE detergent if you have hard water and 1 tablespoon if you have soft water.
Hope this helps.
Sep 09, 2009 | Kenmore Elite 45986 Front Load Washer
My Kenmore Elite HE3 washer doesn't get the dirty laundry clean. It redeposits the dirt on the clothes, causing brown stains. I had a Sears rep look at it when it was new (5 years ago), and he said it was...
Brown stains are likely from the felt seal. The adhesive used from the factory disintegrate over time, and when you replace the felt - use some silicone instead.
Apr 08, 2009 | Kenmore Washing Machines
My Kenmore Elite he3 is no longer drying clothes.
Hi
Please, the heater seems not working "
27593276.jpg My Kenmore Elite he3 is no longer drying clothes", what I need to check or do? thank you.
Mar 30, 2009 | Kenmore Elite HE4 Electric Dryer
Kenmore Front loader washer doesn't spin clothes as dry as before
The out-put pump is possible clogged up and not moving the water efficiently, also check the pully belt is tight
Dec 14, 2008 | Kenmore Elite 45986 Front Load Washer
set the washer to fill. open the lid and depress the lid switch. might be in the rear of the cover or on the side. watch to see where the water level comes to. once the tub is filled, the water height switch operates the timer motor for the different cycles.
Sep 10, 2007 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
120 people viewed this question
Top Washing Machines Experts
