Question about Uniden DCT646-3 Cordless Phone
Restarting of samsung d900i problem
Cant get into menu,when pressing menu button it freezes for 2 seconds and restarts,any ideas how to solve this? thanx
  • 212 Answers
Use from this reset code : *2767*2878#
first back up your contacts
Posted on Aug 13, 2010
Where is the reset button on the kindle fire?
According to eHow.com: " E-Reader Soft Reset
  • 1 Open your Kindle's Menu while on the Home screen. Do so by pressing the Menu button, or the onscreen Menu icon for Kindle Paperwhite owners. Select the "Settings" option.
  • 2 Choose "Menu" again from within the Settings menu. This displays a different menu than before.
  • Sponsored Links
  • 3 Choose the "Restart" option. Wait while your Kindle powers off and on again.
E-Reader Hard Reset
  • 1 Charge your Kindle e-reader before performing a hard reset. Charging helps ensure your problem isn't related to the device having a low battery.
  • 2 Hold down the Power button for 20 seconds. The screen will change after a few seconds, but continue holding the power button for the full 20 seconds before releasing.
  • 3 Wait while your Kindle restarts.
E-Reader Factory Reset
  • 1 Press your Kindle's Menu button. Select "Settings" from the menu.
  • 2 Open the menu once more from within the Settings window. Select "Reset to Factory Defaults," or "Reset Device" if you're using a Paperwhite.
  • 3 Select "Yes" in the confirmation window after reading the warning. Wait while your Kindle restarts and restores.
Fire Soft Reset
  • 1 Hold the Power button down for three to five seconds. A Shutdown window appears.
  • 2 Tap the "Power Off" button in the Shutdown window. Wait for the Fire to shut down completely.
  • 3 Press the Power button to turn the device on again.
Fire Hard Reset
  • 1 Plug your Kindle Fire in and give it time to charge before performing a hard reset. This helps ensure your issues aren't related to having a low battery.
  • 2 Hold down the Power button for 20 seconds. The Kindle Fire will shut down.
  • 3 Press the Power button to turn the Kindle Fire back on.
Fire Factory Reset
  • 1 Swipe your finger down from the top of your Kindle Fire's screen, presenting the Quick Settings menu.
  • 2 Tap the "Settings" option and select "Device."
  • 3 Select "Reset to Factory Defaults," then tap the "Reset" button. Wait while your Kindle Fire restarts and restores.
Read more : http://www.ehow.com/how_6122863_reset-kindle.html
May 10, 2015 | Tablets & eReaders
Samsung galaxy S2 mini keep restarting itself...i can t get to the menu to write codes or restore factory settings...it just resstart over and over again.....the button is not blocked and i tryed some...
Press volume up & down & power - when the phone vibrates IMMEDIATELY press the home button and after 2-3 seconds release the power button... What you're going for is that the phone tries to restart with volume up & down & home button pressed...
Press and hold both Volume UP and DOWN + POWER ON / -->( HOME ).
Select Factory reset with Volume Down button and press Power to reset. All data will be lost!
or
Turn off S6500. Press and hold POWER + ENTER button for reset menu.
Mar 07, 2014 | Samsung Galaxy Cell Phones
Samsung sch-u340 wont start up
1.Check the device's battery level for at least two bars of strength.
2.If the battery level is low, charge the battery.
3.If the issue is not resolved, remove the back cover.
4.Remove the battery.
5.Wait 10 seconds.
6.Press and hold the W key.
7.While pressing down the W key, re-insert the battery.
•The device restarts and after approximately 15 seconds, the 'Recovery' screen appears
•Release the power button but *continue holding the home button*, for another 30 seconds.
Step
Thanks
Aug 07, 2012 | Samsung SCH-u340 Cellular Phone
Every time my friend trys to start home it gos to the loading screen then freezes his system and restarts its self with the 3 beeps. It used to work fine but it only started recently
Hopefully this will help solve your problem:
1. Press and hold down the power button located at the front of the PS3 console, until you hear a first beep, then eventually a second – before the console shuts down, then let go of the button;
2. Now press and hold the button again until you hear a first beep, then a second beep then eventually a quick double-beep, then let go of the button;
3. The TV screen should now display a six option menu, where you can select what’s required, i.e. `Restart System`, `Restore System` etc. `Reset System` should only be used after other attempts with the other options, as your game saved data may be lost. If you play Modern Warfare 2 online, then this won’t be affected as your data is saved on the Sony Server.
4. During any of the above actions, your best having your handset controller connected to the PS3 via the USB cord, which includes pressing the `P` button when required (located between `Start` and `Select`).
These actions should help solve `freeze` problems and others such as update errors etc – which restrict you starting up or playing your console.
Don’t hesitate to contact Sony UK if required, who are very helpful. Their UK number is: 0844 7360595
Good Luck!
Jun 30, 2010 | Sony Playstation Home
Mercinaries 2 world in flames for PS3 freezes while loading. This is a second new disk and it does the same thing at the same spot after setup of the software.
You can try the steps below. Its from PlayStation Forum:
1. Turn off Playstation®3.
2. Hold the power button down; the system will turn on and turn off once again.
3. Once the System has been shutdown, re-press you finger until you hear 2 consecutive beeps
4. When you hear the 2 beeps take finger off power button.
5. You will be prompted to plug in your controller via USB and then hit the PS button
6. The Recovery menu will pop up.
The current Recovery Menu supports:
• Restart System: Restarts the PLAYSTATION®3 System.
• Restore Default Settings: Reset all system settings back to default.
• Restore File System: Checks for corrupt/missing system files.
• Rebuild Database: Rebuilds the OS for the PLAYSTATION®3.
• Restore PS3 System: Fresh restore; Deletes everything and starts from Scratch.
• System Update: Update the PLAYSTATION®3 System
If the above steps still does not solve the problem, then I think will have to update your Ps3.
Update your PS3 (in the settings menu the 1st option).
Go on the internet browser on the PS3 then go on the menu press triangle then on one of them there are delete cookies and the delete the others as
well as cookies.
You could also try this as well: put the PS3 on then press the eject button (with no disc in) then hold it and switch the PS3 off at the back with your finger on the eject button still holding it, then put it back on and the fan test should be working this may cool it down. It might be over heating.
But if your problem is not still solved, then maybe you should call sony for further assistance.
I wish you good luck
May 11, 2010 | Video Game Consoles & Games
Ps3 freezes before getting to main menu!!
Try Accessing the Ps3 Recovery Menu
Turn off Ps3
Once the system has been shutdown, re-press your finger until you hear 2 consecutive (quick) beeps
You will be prompted to plug in your controller via usb and then hit the ps button
The recovery menu will pop up
Recovery menu
* restart system
* restore default settings
* restore file system
*rebuild database
*restore ps3
*system update
Now I was not sure which one to choose. I clicked restart system and that did NOT work so I clicked restore ps3 and lost everything but it DEFINITELY WORKED!!
Nov 02, 2008 | Sony Playstation 3 (PS3) Console
Ipod second generation
just wait for it to shut down ipods sometimes freeze up
May 05, 2008 | Apple iPod nano 3rd Generation
4gb nano ipod hangs
try letting the power run right down then recharge. It works for my 2 gig
Dec 25, 2007 | Apple iPod nano
D900i Speedial & Pedictive text
Hi there, got the answer for your second problem , you can change the word you have wrote by pressing the 0 button!
Dec 21, 2007 | Samsung SGH-D900 Cellular Phone
Samsung Yepp YP-T9
Try to reset the device.. just press and hold the MENU button and the A/B button at the same time hold it for about 5 seconds until the device turned off. Hopes this helps.
Aug 27, 2007 | Samsung Yepp YP-T9 Digital Media Player
Uniden DCT646-3 Cordless Phone Logo
73 people viewed this question
Top Uniden Lands Phones Experts
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
