Question about Thermador SEC272BPSS Electric Double Oven
Probe light won't go off so can't use oven. Tried plugging in probe but no luck. Tried airing out oven but no luck. Wife is going to kill me if I don't fix this before the weekend! Help
  • 2 more comments
  • Lannie1670 Nov 24, 2007
    Probe light will not do out so unable to use the oven. Called technical service. They recommended turning off the oven at the circuit breaker so that the oven will reset to manufacture settings. This did not work. Called back again and they recommended turning off the circuit breaker and cleaning the probe with a dry cloth (suspect moisture is setting off the probe light). This again did not work. Now it is day 3 and turning off the circuit breaker did not clear up this problem. Does anyone know how to solve this problem. PS. I don't even have a probe. Model# SEC302
  • PVLarry Dec 08, 2007
    I have the same problem, turned of electric, did not help, probe light still on and cannot start the oven. does anyone have any other ideas, my wife is on my case, and Christmas coming is not going to help matters.
  • kolef88 Nov 28, 2008
    Same problem with Thermador double oven. Probe light goes on by itself, and I can't turn it off. Then I can't use the upper oven. It usually happens at the worst times like Thanksgiving and Xmas, when there are a lot of dishes being cooked at once. I suspect that it might be moisture getting into the jack inside the oven which the probe plugs into. If there were a way to block off the jack, it might solve the problem.
  • newportbeach Feb 11, 2009
    Exact same thing is happening with my oven. Probe light came on while I was roasting veggies at 425 degrees. I can't get it to go off.
4 Suggested Answers
SOURCE:
IB4G2008
  • 3587 Answers
SOURCE: Temp probe indicator stays on
sounds like your probe connection may be shorted. Can you inspect the probe itself, and perhaps do a test for continuity with an ohm meter? Also, you might be able to disable the probe in the menu settings, and run it on manual, just for a test.
Do you still have the user's manual for this unit?
Posted on Feb 13, 2008
priyabrat
  • 123 Answers
If you’ve accidentally switched the oven control on your GE oven from Fahrenheit to Celsius (or vice versa), it can seem like an oven control problem; the keypad will accept some temperature selections and not others. Easy enough to switch back to the way you want it– this excerpt from your owner’s manual explains the technique:
Your oven control is set to use the Fahrenheit
temperature selections but you may change this
to use the Celsius selections.
Press the BAKE and BROIL HI/LO
pads (on double oven models use
the upper oven controls) at the same
time for 3 seconds until the display
shows SF.
Press the BROIL HI/LO pad. The
display will show F (Fahrenheit).
Press the BROIL HI/LO pad again. The
display will show C (Celsius).
Press the START pad.
NOTE: On double oven models the new setting
will be displayed for both ovens.
SOURCE: the probe light will not go off, so I cannot broil
I am having the same problem. Except when I turn on my broiler the E 6 number flashes over and over. I have called a zillion repairmen none of them will work on a Thermador
Posted on Feb 01, 2009
The probe doesn't work on my JT912 GE wall oven
Test Continunity for your Probe, if it has good continuity, then you have a internal issue with the Oven... More than likely, you are going to need a Technician
Apr 10, 2013 | GE Profile JT912 Electric Single Oven
Probe light on convection oven stays on. Clock won't display. Oven still works though.
Sounds like the control board is not communicating correctly with the rest of the unit, consult a professional.
Aug 10, 2012 | Frigidaire 30" Built-In Single Electric...
Probe light stays on so I can't cook
After calling an authorized technician and the thermador support line, neither of which solved my problem, i was told a HARD RESET of the PROBE is all that is required. This problem originally occurred on my Thermador double oven after a power outage and rendered my oven unusable b/c the probe light would not go off -- even though i had never used the probe!
To hard reset the PROBE, turn off the oven at the breaker box, plug in the probe for 1 minute and remove it, then turn the power back on at breaker box, and probe light goes off!! Also, since i didn't have the original probe and to buy a new one would be $80, I borrowed a friend's Thermador probe (different model but it still worked). It cost me $85 for the service visit, 2 weeks of nonoperational oven, and about 5 hours time -- hence the reason i am making this post. It is a golden trick!!
What did NOT work -- turning off power to house again for 15 minutes to reset the OVEN, and disconnecting the probe wires from control panel so probe isn't recognized.
Nov 26, 2009 | Thermador SEC272BPSS Electric Double Oven
Keep getting a message that says 'remove probe' but we don't have a probe in. Hit 'cancel' and tried reducing the temp on the oven when this message came up ('remove probe'). I hit 'bake' and tried to...
You might want to try and use a q-tip and some rubbing alchohol and try to clean the inside of the probe connector in the oven. Some liquids or something might be in it causing the control board to think the probe is connected. Make sure to do this procedure with the range unplugged. Then wait about 20 minutes before plugging the range back in. Hopefully that will stop the issue. If not could be a control board problem.
Nov 26, 2009 | Ovens
My Jenn Air oven is asking me to remove the meat probe. The only thing I did before it asked me to do that was to turn it try to preheat the oven to 350 degrees
you could have a bad probe receptacle. Or a board problem. Kill power to oven, wait 10 min, cross your fingers and restore power.
Oct 26, 2009 | Jenn-Air Ovens
Superba convection oven probe display problem
I had a similar problem today with my KitchenAid Superba wall convection oven (2002 model). I was roasting tomatoes at 225 degrees F for 3 or 4 hours when the control pad changed and showed that the probe was in use (never have I used it and had to look for it). I, too, tried to plug in the probe and take it out, but nothing changed. My worry was that I could no longer use the timed bake function. After trying to reset by turning off the oven at the breaker, with no change, I turned on the oven to 400 F and left it on for 10 - 15 minutes hoping that the high temperature would dry out whatever moisture that must have gotten in the place where the probe connects. Then I turned it off and just waited. After a half hour or so the control pad cleared and nothing showed (that is what you want when the oven is off!). Everything is back to working now.
Sep 08, 2009 | KitchenAid KEBC107 Electric Single Oven
F 10 code when I try using oven
The "F10" error code caused by the runaway temperature.
The first thing I would check is the resistance across the oven temperature probe (oven temperature sensor) terminals at the EOC (electronic oven control) plug.
It will be about 1100 Ohms at the room temperature.
If the resistance at the EOC plug is wrong, then measure the oven temperature probe resistance at the probe plug.
If it's wrong - replace the oven temperature probe. It's better to hardwire it, using a high temperature ceramic wire nuts.
If the readings at the EOC and at the oven temperature probe plug are different - check the wire harness between the oven temperature probe and the EOC.
If there is nothing wrong with the oven temperature probe resistance - replace the EOC.
Please rate and have a great day:)
May 18, 2009 | Kenmore Ovens
KEMS377 Lower electric Convection Oven - no probe, won't work!
"I get a "Door" message when I try to start it. The Message only shows when I try to set the time with one of the function buttons, like and dosent work
Aug 07, 2008 | KitchenAid Architect® KEMS378S Electric...
Thermador SEC272BPSS Electric Double Oven Logo
570 people viewed this question
Top Thermador Ovens Experts
Marvin
Marvin
Sal De
Are you a Thermador Oven Expert? Answer questions, earn points and help others
