Question about Nuova Simonelli Premier Maxi Espresso Machine
Nuova simonelli mac cup red light
Red light came on and nothing works any more . Can fill the resovoir by pressing the button but the water leaks from one of the expresso heads(above the head itelf.)
Any suggestions
thanks
  • yonizam Nov 28, 2008
    no alimenta el agua automaticamente cuando funciona la bomba gracia
    President:
  • 1,618 Answers
It sounds like the thermostat on the boiler nest to the element tripped. Fill machine with water until you can see the level about half way, then open the right side of the espresso machine, you might be able to get to thermostat from the top of machine (make sure it is unplugged) then press the red pin on the boiler between the 2 wires, that should reset the thermostat, if it does not then it will need to be replaced. As for the water on the top of the group head, is there any way you can post a pic of the top, because simonelli made a few different head and I want to give you the correct advise.
Posted on May 14, 2009
More info
Sounds like either the gigleur on the top of the machine is blocked, or the blockage might be in the flowmeter gigleur.
Apr 01, 2014 | Nuova Simonelli Mac 2000 I Group Espresso...
Troubleshooting Nuova Simonelli espresso
The water sonoled
You have to despatched it ,clean it you will find small break's there
Mar 23, 2014 | Nuova Simonelli Mac 2000 Espresso Machine
The auto fill led light flashes and the boiler shuts down. after about 15 min and doing nothing to the machine it restarts itself and works fine. it does this 2 to 3 times a day
The machine cannot get water in a timely manner, check the water filter is there is one on the unit it may be time to replace it, and second check the level probe it may need to be cleaned also.
Oct 07, 2009 | Nuova Simonelli Mac 2000 Espresso Machine
Mac cup V commercial Nuova Simonelli will not **** water and will not build pressure
First check the reset thermostat on the right side of the boiler below the level probe, make sure there is water in the boiler before resetting.
Sep 25, 2009 | Nuova Simonelli Oscar Coffee Maker,...
Old 1996 nuova simonelli mac digit no pressure or heat
There is a reset thermostat on the right side of the machine above the element, check to see if it tripped. If it did make sure there is enough water in the machine and when turning it on, open one of the steam valves and turn off the cup warmer. Leave the steam wand open until it hisses or small amounts of steam or air will vent out.
Feb 11, 2009 | Nuova Simonelli Mac 2000 Espresso Machine
Nuova Simonelli Mac 2000 - Boiler continues to fill up
I had the same problem of the boiler filling up all the way with water and the water was coming out of every hole in the machine. Turn the machine off, drain the boiler completely,
MAKE SURE VALVE #2 is CLOSED, this is the one under the drip pan all the way to the left. Turn on the water supply to the system and turn the system ON. The cup warmer on top will come on and stay on for anywhere between 10 to 20 minutes..... let it be,,, do not turn it OFF,, it will go off automatically. That should do it!
Hratch
Jan 21, 2009 | Nuova Simonelli Mac 2000 Espresso Machine
Pump keeps running and excess water goes into the cup tray
check the level probe on side of boiler may not be facing down as it should or need to be replaced.
Nov 16, 2008 | Nuova Simonelli Oscar Coffee Maker,...
Nuova Simonelli Premier Maxi Espresso Machine Logo
349 people viewed this question
Top Nuova Simonelli Coffee Makers & Espresso Machines Experts
J.D. Browning
J.D. Browning
Andrew Taylor
Andrew Taylor
Gil Shultz
Are you a Nuova Simonelli Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
