Question about Minolta EP1030/1030F CS/PRO Copier
Minolta EP2030 exposure lamp timing wrong
I have an old Minolta EP 2030 CS Pro copier with 2 paper trays, automatic document feeder, sorter and no duplex. It recently gave me an error code of C0410. I was able to determine that for my machine, the code resfers to "exposure lamp timing wrong" and was able to get rid of the code by pressing the reset button on the board in the back of the machine. The exposure lamp timing continues to be wrong, though. When the machine is first turned on, you hear the normal ticking sound of warming up while waiting for the ready indicator light to go on. But then, the ticking continues and the exposure lamp keeps going on for about 1 second at regular 20 second intervals. If you try to make copies, the machine shuts itself off and the C0410 code comes back on again. Pressing the energy saver button stops the exposure lamp from going on, but of course, also prohibits you from making copies. The exposure lamp was replaced about a year ago. Is there any simple way to reset the exposure lamp timing and fix this problem? Also, I don't know if it means anything or not, but there is a board on the rear of the document feeder with LEDs in a row which blinks regularly. The machine is over 9 years old and I always had a service agreement with Konica Minolta, but they wouldn't sell me a new agreement because of the age of the machine and finances just don't allow for a new one. Thanks for your help!
  • nodu17 Nov 14, 2008
    Thanks for your help. I know that I can call in a repair service, but all are pretty expensive where I am (Paramus, NJ) and I'd hate to make a large investment in paying for a technician to come in, spend lots of time and then tell me that the machine is not worth fixing because its old. I guess it's a matter of finding the right person.
C0410
Posted on May 17, 2010
    Problem Solver:
  • 17 Answers
"Exposure lamp timing wrong" simply means that the lamp is coming on at a time when it should not be coming on. It is not a problem with the lamp itself. It is most likely a power supply problem. There is probably no simple fix.
Just because Konica Minolta no longer will sell you an agreement does not mean that you cannot get the copier serviced. There are plenty of independent repair agencies that would love to service your copier, unless you are in a really remote location.
The EP2030 was one of the last Minolta analog copiers, and parts are still readily available.
Posted on Nov 14, 2008
Minolta cs pro 2030 C00 CODE SHOW PLZ HELP
Missing two numbers on the end of the 00 is it 0070 or 0000?, 0000 is main motor drive 0070 is toner bottle issue.
Mar 03, 2015 | Konica Minolta EP 2030 3000 Toner 2-410...
Where can I download service manual for Minolta pro ep 2030. Free if possible
i can download it for you send me an email to forward it to you
Jan 31, 2011 | Minolta EP1083 CS/PRO Copier
Ep 2030 error code c06
Exposue lamp, does the lamp come on under the glass at all. Open close the front door, if that code comes back your exposure lamp is gone. Thats the bright ligh that comes on while making copies.
Jul 16, 2009 | Minolta EP1030/1030F CS/PRO Copier
NO LIGHT NO MOVEMENT INSIDE.
If there is no light coming from the lamp in the scanner and the carriage is not moving this is a serious problem. It could be that the main board is bad. Typically the exposure lamp is just burnt out but if the carriage is not moving something more serious is not working. Just to verify open the document feeder on top and press the start key. You should get an error code if the lamp does not work.
Jan 19, 2009 | Minolta DI-2010F Copier
My Minolta ep 1030 shows C04
Verify exposure lamp or  lamp's fuse.
Jan 14, 2009 | Minolta EP1030/1030F CS/PRO Copier
How to use
Does the copier have a duplexer? Automatic 2-sided copying (duplexing) was an optional feature for the EP2030. If there is a drawer in the lower section of the copier labeled "duplex" then your unit has this feature.
To use it, simply select 1>2 (for single-sided originals) or 2>2 (for 2-sided originals) on the "Orig>Copy" section of the control panel (toward the left side).
If your copier is not equipped with a duplexer, the only way you can make 2-sided copies is to copy the first side and then load the copies back into the paper tray or the manual bypass on the right side of the unit.
Note the the copier copies on the bottom side of paper fed from the paper trays, and the top side of paper fed from the manual bypass.
You can download a .pdf file of an operator's manual for this copier from the Konica Minolta website.
Oct 22, 2008 | Minolta EP1030/1030F CS/PRO Copier
PAPER FEED
you can disconnect the sorter.if that's all you need
Oct 16, 2008 | Minolta EP1083 CS/PRO Copier
Document jams ep 4000
Ceck the rubber rollers on the doc feeder. They are probably real soft and mushy. If so they need to be replaced!
Dec 14, 2007 | Minolta EP4000/5000 CS/PRO Copier
Meaning of code C04 ( EP 2030)
minolta cspro1054 turns off once you turn it on and code is c
Nov 15, 2007 | Minolta EP1030/1030F CS/PRO Copier
534 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
