Question about Mantis Tiller
Mantis Tiller My Mantis Tiller will not start. It was at least starting before but would not stay running. Now it will not start at all. I am looking for someone to guide me on how to adjust the high and low idle screws to the proper adjustment so it will run.
  • Anonymous Mar 23, 2014
    runs but but cuts cuts out after short period
  • 163 Answers
Check the fuek lines for hole and leaks, check the fuel filter and clean if necessary. remove the carbuerator and inspect the gasket; it should be soft and flexible, if it seems hard or brittle replace it. clean the carb with carb cleaner sray (available at any local auto parts store) and compressed air. make sure you get inside the small fuel rail holes. check the primer bulb for pin holes and seating/sealed properly. if that doesn't work have the carb repaired at a service center or replaced.
Posted on Nov 30, 2008
How to adjust a aisen carburetor for a mantis tiller/cultivator
Take it apart and blow and clean it out. Needle may be stuck.
Mar 08, 2016 | Mantis Garden
Mantis tiller 7222e
Hi anon, if it's starting your 2/3rds of the way there. You have fuel and spark. Try and clean the air filter first and if that fails to keep it running then check that the choke isn't staying out. If all thats ok then it may be the carb gaskets.
Jul 09, 2014 | Mantis 2-Cycle Tiller
No color on the carb adjustment screws?
look for H and L cast on carb. body near screws
May 22, 2012 | Mantis 2-Cycle Tiller
Mantis tiller starts but will not stay running
Carburetor problem. Two stroke engines use oil mixed with gas. Old fuel or setting over the winter will cause varnish and sludge in the Carburetor. Start by buying a can of carburetor cleaner and mixing a new can of fuel.
1) Dump the old fuel and check replace it with new.
2) Remove the air cleaner.
3) Pump the prime bulb 3 or 4 times, set the choke, spray the insides of the carb with the cleaner and then try and start it . It should sputter and run for a few second but chances are it will take a few sprays to clean the jets
Jun 06, 2010 | Mantis 2-Cycle Tiller
Tiller won't stay cranked
the carb needs a thorough cleaning
May 04, 2010 | Mantis 2-Cycle Tiller
We have a Mantis electric cultivator that won't start. it's only a couple of years old
Electric tiller, and it will not run ?
I would check the cord that you plug into.
You must remove the plastic housing, by removing the screws.
Next look at the plug, is it in good shape, has anything been pulled out of it ?
The motor brushes should also be inspected.
Please let us know, we repair all Mantis equipment.
Jan 27, 2010 | Mantis Electric Mini Tiller/Cultivator
Mantis tiller sv-4 echo engine no spark from coil mantis 2cycle tiller i got it running tryed to start it 4hrs latter same old problem wont start, plug wet with gas wont start. coil was checked by shop...
Sounds like it's flooding either from over choking or the inlet needle in the carb is leaking. Have you removed the plug and blown out the cylinder and plug with air and then tried to restart? Be careful not to keep cranking with the choke pulled out. When it 'hits' ONE time, move the choke halfway in and crank again
May 31, 2009 | Mantis 2-Cycle Tiller
Trouble starting old Mantis tiller 9012 - don't have a manuel -
Mantis has the owners manuals in pdf format available for download on its website. The tillers are here (I hope the link to the tiller group works...if not, just go to the main site and look for "owners manuals" link.
Also, you can call a number and get a representative who usually can help at the numbers listed there, find authorized service people if its not something you can do yourself, order parts and find detailed schematics in the owners manuals. My dog actually ate mine. LOL. But they are free, the owners manuals, unlike other places that charge you for them like they were a "part".
http://mantis.com/owners_manual_library-swell2_tiller_engine.asp?cat=8
May 16, 2009 | Mantis Tiller
My tiller won't stay running
this is a two cycle with a walbro carb - probly need to remove carb to flush and put new diaphrams in
Oct 06, 2008 | Mantis 2-Cycle Tiller
Mantis Tiller Logo
1,563 people viewed this question
Top Mantis Garden Experts
paulfvincent
Jim Parker
Jim Parker
Mike Squire
Are you a Mantis Garden Expert? Answer questions, earn points and help others
