Question about Honeywell Programmable Thermostat Heater
Program manual for honeywell thermostat model T8700C1005(1)
Need manual or just instructions on how to program. manual for Model # RTH2310B 5-2 style, can't find it on the Honeywell site. Thanks!
  • 1 more comment
  • Anonymous Nov 16, 2008
    You need to supply an instructional manual of how to program the thermostat 5-2 day program
  • mcmahonj Jan 01, 2009
    I purchased the rth2310b and then pulled the old thermostat off the wall and am now afraid to open the rth3210b box in fear that this is not the right model for my furnace and air conditioning. I was looking for the wiring diagram on line. Not to be found. Thank you Honeywell.
  • sym9 Jan 21, 2009
    Looking for T-stat wiring info, pix, schematics, manuels, etc. for a HW Mod: RTH2310.
  • 833 Answers
Go here: http://yourhome.honeywell.com/Consumer/Cultures/en-US/Products/Thermostats/
Posted on Nov 13, 2008
  • 34 Answers
Try holding the up and down arrow, down, at the same time, see if the time or temperature starts flashing. also the cover should lift up so you can change from heat to cool, there should be a program button or a set button to hold down. all you should have to do is adjust the time and temperature for the 4 settings during the week and the two on the weekend. should be really easy, let me know if you need some more help
Honeywell rth2310b 5-2 day is not working. light stays on and buttons dont work, how can i fix it?
Honeywell has a help line They have access to all of their codes and understand your problem. Google them for the phone number.
Sep 01, 2014 | Honeywell RTH2310B 5-2 Day Programmable...
Operating manual honeywell rth2310
Honeywell has the manual for the RTH2310 programmable thermostat on the product page: http://yourhome.honeywell.com/home/Products/Thermostats/5-2-Day-Programmable/RTH2310B.htm . The direct link to the English/French version of the operating manual is http://customer.honeywell.com/techlit/pdf/PackedLit/69-2229EF.pdf .
I hope this helps.
Dec 13, 2011 | Honeywell Programmable Thermostat Heater
How do I set the temporary or permanent override feature on the Honeywell RTH2310B model thermostat?
To set the temporary override, press arrows up or down to desired temp. This will keep temperature
at temporary setting for 2 hours then return to programming. To permanent override press MODE button until schedule period number disappears (number inside little house on stat). Then adjust temp with arrows. Press the MODE button again to cancel override and return to programmable.
Jan 25, 2011 | Honeywell Programmable Thermostat Heater
Installed a RTH2310B to replace an older model honeywell. All wires do not match. only 3 do r, w1, and g do and o and e do not. what should i do?
The Honeywell RTH2310B is a standard thermostat and is not compatible with a heat pump system. The terminals O and E are for a heat pump system. I am assuming that the terminals you described that do not match are from the old thermostat. What you will need to do is get a heat pump thermostat. Sometimes it can be hidden within a lot of other descriptions on the front of the box, but it will say heat pump and either 2 heat/1 cool or 2 heat/2cool. You should just need the 2 heat/1 cool heat pump thermostat. Hope this helps.
Aug 17, 2010 | Heating & Cooling
Honeywell RTH2310B Programmable Thermostat
i would check to see if thier is a jumper between RC and RH on the stat if no and the red wire is hooked to RH then you need to add a jumper to RC
Sep 19, 2009 | Honeywell Focus 6300B 5-2 Days...
Wiring for a Honeywell RTH2310B
HONEYWELL WEBSITE:
Go to honeywell.com
Under red welcome sign
Bottom red highlighted box literature/image search
Type in thermostat model number
Click on arrow to right
Then click on the PDF files owners manual / installation instructions
Jan 10, 2009 | Honeywell Focus 6300B 5-2 Days...
Heating & Cooling Logo
2,469 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
