Question about Maytag Neptune MDE5500AY Electric Dryer
Dryer door will not open
I have a Maytag Neptune front load electric dryer that I purchased about seven years ago. The door will not open! What do you suggest we do to get the door open without damaging it?
I just had a tech check my Neptune washer two weeks ago and was told that it would cost over $1,000.00 to repair because the main bearing went out....Needless to say I am very unhappy with this set and I know that they have had a lot of problems with these units. They were very expensive and should have lasted, two people in our household, longer than this.
  • 41 Answers
Only the washer has a main bearing. the dryer only has bearings in the motor and still would not cost 1,000 to fix. did you door issue get fixed? Joe
Posted on Nov 18, 2008
Seven year old maytag neptune electric dryer has a squeak when it is runningand need to know what to fix?
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer2_bing.gif Repair Squeaks, Grinding, Clicking and Knocking Noise
http://www.fixya.com/support/r4416566-dryer_repair_squeaks_grinding_clicking
heatman101
Aug 03, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Matage neptune mah8700aww purchased five years
4 screws takes the front off the washer to find the leak, dryer probably needs drum rollers. If you didnt know maytag went bankrupt for a reason
Jul 28, 2010 | Maytag Neptune MAH5500B Front Load Washer
Dryer makes squicky noise while drying
its the drum glides/slides that support the front part of the drum open the door and push on the door switch and start the dryer and you will be able to locate the noise source easily
Apr 09, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Dryers I have a Maytag electric Dryer, that...
you may have one of ur overheat sensors going out that wont let the elements heat uplike they should they are behind the back cover they are round and very inexpensive u can take the wires off put new one in or u may have a bad element ake the wires off and check continuity thru the element itsself if all that is good take dryer vent off and run with it off 1 load and seee if this cures the problem if it does u had the hose kinked or u have a restriction of lint in the dryer vent going outside hope this helps
Feb 25, 2010 | Maytag Neptune MDE6700A Electric Dryer
How do i open the back door of dryer to check
You access it from the front. Open the door and you'll see 2 screws on each side. Then you can figure it out. Make sure you unplug it!
Maytag Neptune dryer repair in orange county, ca
appliance repair orange county, ca
Feb 07, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Maytag Neptune dryer won't start/
I do not have that specific dryer but try these simple steps.
Maybe they will help you.
1. Shut the electric breaker off to the dryer for about 30 seconds and and back on.
2. Open the dryer door and inspect the switch that tells the dryer the door is closed. work it by hand just to make sure it is not stuck.
3. Spin the timer controls to another setting and see if the other setting will work.
That's all I've got for now...
May 20, 2009 | Maytag Neptune MDE6700A Electric Dryer
Maytag neptune dryer making load noise seems unbalanced
Sounds more like the dryer drum seal is deteriorating.
If the dryer tumbles the belt is intact.
To access the belt.
Open the door.
Remove 4 screws on right and left side of the door opening.
Raise the door on the hinge side and remove it.
Pull the front panel forward and remove it.
From there you can see what to do next.
Mar 10, 2009 | Maytag Neptune MAH5500B Front Load Washer
Neptune Dryer
the belt needs to be replaced. open the front of the dryer, remove the bulkhead and install belt. or call your service guy and have him do it
Sep 04, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Maytag stacked washer/dryer
CHECK THE DOOR SWITCH TO SEE IF THE WIRE ARE CONNECT CORRECTLY. ON THE SWITCH THE WIRE FROM THE BULB SHOULD GO TO N/O IF ALL WIRES ARE CORRECT .THEN YOU NEED TO REPLACE THE DOOR SWITCH
Jan 03, 2008 | Maytag Neptune MLG2000A Front Load Stacked...
Changing the drum rollers on a Maytag MDE4000AYW Neptune Dryer..
The instructions above are perfect for most Maytag Dryers, but the Neptune MDE4000AYW is built differently from most. To open it, undo the two screws that run through the door hinges, and remove the door, then undo the two other screws that are on the opposite side of the doorway. With these four screws out, you can lift the front panel UP and out. Make sure you unplug the dryer first :-)
Dec 01, 2007 | Maytag Neptune MDE5500AY Electric Dryer
Maytag Neptune MDE5500AY Electric Dryer Logo
88 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
