Question about IdentityGuard Cross-Cut Shredder
Replacement part for model 9210PL
How do I get a replacement for black plate that is located on the under side of the shredder?
One pin on the side has broken off.
Roy Cooke
  • 58 Answers
This is how a got my hard to fine gear!
Contact Michael Business Machines for your local dealer 1-800-223-2508
Good luck, Tom
Posted on Mar 27, 2009
Where can I find a spare plate which directs the ice into the ice container. The plate has a little pins on each side. My one pin broke off, so the ice isn't pushed forward.I stay in Cape Town. Piet
Hello Pieter van Deventer,
Start by putting your make & model on a search line...
add the word "SPARES" out of deference to your
(non USA) location (here we say parts (and even AMAZON carries these "sweepers")).
Hit return and a ist of part RETAILERS will magically appear.
Hope you find what your are looking for...
Over here the HEAD of the ice makers are typically sold as a unit and depending on the MAKE & MODEL start at about $100 USA
https://www.bing.com/search?q=replacement+ice+maker+head+units&form=EDGEAR&qs=PF&cvid=5030c722c77d475f8e0f45f4547d95b7&pq=replacement+ice+maker+head+units&PC=DCTE
Watch the repair VIDEO
http://www.appliancepartspros.com/frigidaire-replacement-icemaker-5303918277-ap3160597.html
Dec 17, 2016 | Refrigerators
I have stripped a nylon gear on this shredder I borrowed from a riend
then go buy the friend a new shredder . there are no nylon gears available HERE
Sep 21, 2015 | Shredder Office Equipment & Supplies
Source for gear for fellowes 301101 DS-1 paper shredder
Replacement Parts - Paper Shredders Can I get my Fellowes paper shredder repaired or purchase parts for it?
The majority of Fellowes personal shredders (small shredders that can fit under a desk) are repairable and will have parts available. If you would like to check your model shredder to determine if parts are available, please click the "Ask a Question" tab above, and advise the model of shredder, the shredder's serial number and a description of the part needed. The serial number will be located on the bottom side of the shredder head below the bar code.
*** Please note: If your shredder is still within the warranty period, we ask that you do not open your shredder until speaking with a Fellowes Representative, as opening the unit may void your warranty.***
Fellowes office/commercial shredders (large shredders that cannot fit under a desk) are repairable and parts will most likely be available. Please do not try to repair the shredder yourself or you will void your warranty. Models included in the office shredder line are 125i Series, 225i series, 325i series, 380 series, 420 Series, and 480 series.
If you would prefer to have a local servicing dealer provide repair service to your office shredder, and would like to find a dealer in your area, please see the below link to search for a dealer by zip code.
http://www.fellowes.com/Fellowes/site/support/support_authorizeddealers.aspx
To order replacement parts, or if your model shredder is not listed, please click the "Ask a Question" tab above to ask us about your shredder. *** Please be sure to include your serial number from your shredder for the fastest service ***
Our office hours are 7:00 AM to 7:00 PM, Monday through Friday Central Standard time.
Jan 22, 2015 | Fellowes Office Equipment & Supplies
Broken prong at one end of safety interlock switch (plastic plate)must replace
Just in case someone comes across this in the future looking for an answer like I did. I jerry-rigged a solution to keep my Tech Solution TS-4500 going as I'm in the midst of a major shred job. Here's how I jerry-rigged a replacement pin for the flap:
1) I straightened a coated paperclip.
2) Wrapped the two ends together in duct tape, fitted to the size of the insert on the top of the shredder that the pin goes into.
3) Snipped off the excess paper clip at the opposite end of jerry-rigged pin, so there isn't more metal inside the shredder than necessary. (Leave enough to attach to the flap [See next step].)
4) Duct-taped the paperclip to the flap to keep it in the correct position.
5) Inserted the hard plastic pin into its slot and then the jerry-rigged pin into its slot.
The flap is able to swing up and down, and I've had no problems using the machine and the machine has had no problems knowing when it's full and auto-stopping.
Jul 07, 2014 | Tech Solution TS-4500 Shredder
How to replacefront leaf springs on toyota hilux dualcab4 x4
undo the 2 small retainer studs from the pin-plate. Place a nut on the thread of the pin and do up partway Ensure that the vehicle is placed on stands with the wheels just touching the ground so as to relieve all tension in the springs. Hammer the nut on the pin . It will also help if you use a pair of stilsons on the plate twisting while hammering. The plate will move out revealing a large hole on one side . When the pin moves freely remove the nut and hammer on the plate. As to the front swing shackle remove both nuts and with a bar between the spring and the hanger hammer the plate and pins out. undo the spring u- bolts and remove the spring Note-1--- do one side at a time as it retains the location of the front axle for spring replacement. Note--2---Hilux springs are bad for sagging so have an extra leaf fitted under main leaf Note--3-- do not use eurothane bushes as they will crack the chassis in adverse conditions.
Apr 27, 2013 | Toyota Cars & Trucks
Still cant find ECU
the ECU is located on the passenger side floorboard underneath the consold and carpet
Feb 14, 2009 | 1992 Honda Accord
IdentityGuard Cross-Cut Shredder Logo
241 people viewed this question
Top Identity Office Equipment & Supplies Experts
jasbo
jasbo
Are you an Identity Office Equipment and Supply Expert? Answer questions, earn points and help others
