Question about Brother Office Equipment & Supplies
Question: Is there a way to stop incoming faxes temporarily?
    Genius:
  • 2,120 Answers
Scroll through the menus and set MANUAL MODE, You will have to press START to receive a fax.
Posted on Nov 14, 2008
How do i print a fax stored in lexmark x5495 if a fax is sent and does not print out, is it saved anywhere for me to retrieve
When an incoming fax is stored temporarily in the printer's memory, chances are, one of your cartridges has low ink level. To retrieve stored faxes, current state of printer must be on the instance when the fax is temporarily sent to printer's memory. Replace your low-ink cartridge without navigating away from the Fax function. Once you have replaced the cartridge, press Ok button to continue printing the fax.
Jun 21, 2011 | Lexmark X5470 All-In-One InkJet Printer
I want to retrieve a fax sent to me last year
I'm afraid your printer does not have the capability of retrieving faxes sent last year.
The only time you can retrieve faxes is when you get "low ink level" notification while a fax is coming in, where the incoming fax is temporarily stored in the printer's memory. You'll be asked to replace the low ink cartridge (without navigating away from the fax function) then hit Ok to receive the incoming fax. Other than that, you won't be able to retrieve previous faxes.
Apr 10, 2011 | Lexmark X5650 All-in-One InkJet Printer
Incoming faxes do not show time or date
function-7-4-start-9-start-2-start-stop
this should print the time and date on the paper
Jan 22, 2009 | Panasonic Panafax UF-595 Plain Paper Laser...
Trying to cancel incoming fax on panafax uf-8000
there is a feature called junk fax that will stop all incoming faxes
Jan 08, 2009 | Panasonic PanaFax UF-8000 Laser Fax
On a brother fax how do you set it to not go to fax mode on incoming calls
Depending on the model of fax some have switchs on the key board and some have switch in the set up menu. There are usually 3 or 4 answer modes. One for FAX or automatic receive, MANUAL to allow you to answer the phone and many have an ANSWER MACHINE mode to allow you to hook to ansering machine...What kind of fax do you have.
Aug 01, 2008 | Brother IntelliFAX 560 Plain Paper Fax
Not recieving only in memory
My good friend:
The only reason why your unit stops printin faxes is because the toner cartridge is nearly empty. Th e unit will then try to conserve the remaining toner for printing and copying. Follow this steps to program the unit to print all faxes, even with toner low:
When the toner cartridge is nearly empty, the machine shows
the “[Toner Empty]” message and continues printing except
incoming faxes. In this case, incoming faxes are saved in
memory.
However, you can set the machine to print incoming faxes, even
though print quality is not optimal.
1 Press Menu until “Machine Setup” appears on the display.
2 Press the scroll button ( or ) until “Ignore Toner”
appears on the bottom line and press Enter.
3 Press the Scroll button ( or ) to select “On” or “Off”.
Select “On” to ignore the [Toner Empty] message.
Select “Off” to stop printing incoming faxes when the
message appears. This is the default setting.
4 Press Enter to save the selection.
5 To return to Standby mode, press Stop/Clear.
Be blessed
Jun 15, 2008 | Samsung SCX 4521F All-In-One Laser Printer
75 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
