Question about Toshiba Satellite M115-S1061 Notebook
Toshiba I tried to run a Scandisk -> right mouse click on the drive -> properties -> Extras -> Scan Disk, correct? It does not work. I heared that there is a Scan Disk from Microsoft would that help? What else can I try?
    Brigadier General:
  • 6,966 Answers
You can try opening a Command Prompt ( Windows key + R, type "CMD" less the quotes). Inside the Command Prompt, type chkdsk E: /f
assuming that the Hitachi HD is E
Posted on Nov 13, 2008
My keyboard and mouse pad freezes any time i switch on my laptop and sometimes works when i restart
try uninstalling a few unnecessary programs then click start run type cmd then type chkdsk/r/f this should schedule to happen on reboot which will scan for and attempt to recover bad sectors and automatically fix any corrupt files on your hard drive or
click startcontrol panel administrive tools,computer management ,disk management right click on your drive select properties click tools you should see click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now,start should schedule this task when restart
do not do anything while the chkdsk utility is in progress any input will damage your computer
then you should test or replace all leads make sure they are securely seated and are not bad/faulty that are attached to your (((motherboard to your hard drive))
defragment your hard drive will speed up your computer
scroll to the bottom toolbar (bottom of screen) right click you can select task manager applications also processes you will see whats running on your computer you might have virus slowing your computer also select users you will see who is using your computer
make sure you have the correct keyboard and mouse selected
you might have to uninstall your keyboard and mouse then restart your computer and reinstall them make sure that you have there drivers backed up on a disk before uninstalling them
click start control panel,keyboard select hardware you will see which keyboard it is this will also apply to your mouse
also select properties,general you will have options to troubleshoot,driver roll back uninstall ,update driver
or click start control panel administrive tools computer managent device manager scroll to keyboard you could see a yellow question mark? right click to install drivers
don
Feb 07, 2011 | Computers & Internet
Keeps saying it is in use when it is not while trying to remove Also it keeps showing drive G even though I dont want it or to take up more space on the drive. To be honest, It is a complete pain
Thats fairly typical behaviour for the ScanDisk USB Drives.
Don't worry too much about it being busy, it could be AV, a corrupt file on the USB or any other number of issues.
The G Drive is a piece of software that the ScanDisk is trying to run to install software, again, don't worry too much about it.
You can delete the partition and reformat the USB key. That should remove the mounting software, but make sure that you have copied off the data you want off the USB onto a PC or another USB key.
Jan 23, 2011 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
My laptop keeps saying that i need to backup because my c drive needs repair what do i do
ScanDisk is a Windows utility which detects and corrects errors. Windows XP introduced a significant change to ScanDisk. The utility was integrated into the operating system. You should run ScanDisk whenever you notice a hard drive is not performing well and also on a regular basis to fix errors as soon as they happen.
jQuery('.intro .thumbnail').each(function(i,e){ jQuery(e).find('img').one('error',function(){ jQuery(e).remove(); }); }); Difficulty: Easy Instructions
  1. 1 Open "My Computer" in Windows XP.
  2. 2 Find the icon for the hard drive you want to run ScanDisk on. You can run ScanDisk on the system's primary hard drive and also on any secondary hard drives or external hard drives. Right-click on the icon for the hard drive and select "Properties."
  3. 3 Choose the "Tools" tab from the hard drive properties window. The ScanDisk utility can be activated from the Error-checking box at the top of the Tools tab. To begin, click the "Check Now" button.
  4. 4 Note the two check boxes displayed. You will want to choose the "Automatically Fix File System Errors" box. This will perform a basic fast scan of the drive, which will take only a few minutes.
  5. 5 Put a check in the "Scan for and Attempt Recovery of Bad Sectors" box for a more thorough scan. With this checked, Windows XP will take 10 hours or longer to run ScanDisk depending on the size of your hard drive. Run this if you have noticed a problem with the hard drive's performance. For regular checks, run the basic check most of the time and the longer check only occasionally.
  6. 6 Hit the "Start" button to start ScanDisk.
  7. 7 Wait for Windows XP to finish running ScanDisk and view the report. ScanDisk will tell you what errors it found and fixed. Click the "Close" button when are finished viewing the report.
Read more: How to Run ScanDisk in Windows XP ' eHow.com http://www.ehow.com/how_2126653_run-scandisk-windows-xp.html#ixzz1BXNDbxHd
Jan 20, 2011 | Lifetime Toshiba Satellite P505S8980...
I did a complete recovery on my computer and it was taking two days. It kept saying, 'applying setting " but never did So I turned the computer off. What should I do know.
Dec 06, 2010 | E-Machines eMachines Desktop PC
How to run scan disk
if you are using Windows OS, open the Computer or My Computer icon, then right-click the drive where you want to run scan disk and click Properties. Click the Tools tab, then click Check Now under Error Checking. You can then select the option to automatically recover bad sectors and repair errors before the actual process is started.
Sep 12, 2010 | Computers & Internet
Verbatim 8G USB memory storage stick not working
There could errors in the drive. You should either run a scandisk on it or format it altogether. Either should get it back up and running is it is a genuine device.
1. To check for errors/scandisk right click on the icon of the memory stick, select properties. Under the properties menu look for Error-checking and select check now. The check disk menu pops up. See that Automatically fix file system error box is checked. Then click on start.
2. If you decide to format the memory stick just right click on its icon and select format. But see that you move you vital files from it first else you will loose them.
Sep 04, 2009 | Verbatim VER95327 USB Hard Drive
I do not know how to use a scandisk --How do you get the file on and how do you put it on a new pc so that it works?
scandisk is for checking and correcting the errors (bad sectors) in a disk . To start scandisk 1. Right click on the specific drive and go to its properties. 2. then Goto the Tools menu tab and then click on "Check Now" button and then mark all the checkbox and then click on Start.
Jan 02, 2009 | Computers & Internet
Every time i insert the memory card my camera freezes up and i have to take the batteries out in order to get it to cut off or function until i remove the card.
plug your camera, with card inserted, into your pc and run a scandisk to it.. Right click the drive and then properties, then scan disk. Select fix all and let it run. If that doent work, then try a new card. They are very inexpencive now adays.
Dec 21, 2008 | Aiptek ISDV2.4 Flash Media Camcorder
1. how do i do a scan disk and defragmenter on vista? 2. how do i add to the tool bar, double space, print, etc.
Start, Programs, Accessories, System Tools, then Disk Defrag.
You can also right click on the My Computer icon on your desktop and click explore. This opens a divided folder. In the right hand column either right click the C: drive and choose Properties or depending on your settings I can single click that same icon and a Properties Icon will slide into view at the very top of the window near the Tabs area. When the Local Disk C: Properties window appears you can click the Tools tab which let's you pick either Disk Defrag or Scandisk. This is better since you can acces both of these utilities and the Backup utility from the same tab also. Scandisk will also run for about 5 seconds then tell you it cannot operate now but will allow you to schedule it for the next startup.
Nov 12, 2008 | Gateway Computers & Internet
Toshiba Satellite M115-S1061 Notebook Logo
53 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
