Question about Sony KP-46S25 TV
Had power surge? When plugging in or turning on the unit I hear clicking. No picture.
The red power indicator light comes on and blinks a few times then ends. I have to press on buttom twice for the same results. Just clicking and blinking but no picture or sound. I don't know if unit is on or off because I have to press the on/off button twice to get the red indicator blinking or the clicking to occur. Are there any solutions? Other than replacing the whole G board. (1-655-349-14 model number)
Mine had the continuous blinking , and sometimes 2 blinks after trying to turn it on again. I was given the tv and after checking it out found two blown T3.15 amp glass fuses on the audio amp. T for time delay. I went to a recycle center and bought two complete chassis for my model kp53s25. I started changing the standby power supply first. Still did the same thing. I changed the high voltage board with the smaller transformer only and leaving the other larger high voltage transformer in the set. I just cut and spliced the single connecting high voltage line between the two high voltage transformers. Still had the same problem. I change the audio board and the set would work until I believe the audio board heated up or had an intermitant short and the tv would shut down. I replaced the full audio board with another and now the tv stays on and is working great. There seems to be a overheating problem with the sony audio board and i may buy a muffin fan to fit over the audio boards large heat sinks for added cooling in the rear right hand corner of the tv . Touching the heat sinks after tv has been on a while is very warm. Find a recycle center as I bought the parts I needed for 10 dollars for two complete chassis. I should have keep the color projection tubes.
Posted on Jan 01, 2012
I have a sony 57 inch hdtv that I purchase in 2005. The tv has performed flawlessly until today. My Timer/Standby red light is on and is blinking and the i.link standby light is currently on and is a...
The Standby/Power light of the TV blinks when there is any internal malfunction in the TV. The self-diagnostic function of the TV will cause the STANDBY light to blink or flash when the television detects an issue. The number of times the STANDBY light flashes corresponds to a specific issue.
Few examples are given below; some of the issues may be resolved without the need for service.
1 blink / 2 blinks / 5 blinks: - This indicates that there may be a power-related problem with your set.
3 blinks: - This indicates that there may be a power-related problem with your set. The set will need to be serviced to allow a technician to determine the specific issue that needs to be repaired. If the power light flashes three times in sequence in a Lamp TV, the lamp cover is not securely attached. Reattach the lamp cover to resolve this issue.
4 blinks: - This indicates that there may be a back light or lamp power problem.
6 blinks: - This indicates that there is some kind of audio problem with your set.
7 blinks: - This indicates that there is a temperature problem with your set. Please check to make sure that the air vents on the sides and back of the set are not blocked or clogged and there is adequate ventilation around the television. We recommend that you check and clean the vents periodically to make sure the set receives adequate air flow. If the problem continues, the set will need to be serviced.
8 blinks: - This indicates that there may be a video-related problem with your set. If the flash sequence is not listed above or the light continues to flash, follow the steps below to perform a power reset:
Try the following steps to check if the issue can be resolved.
Turn off the television.
Unplug the television power cord from the electrical outlet.
Let the television remain without power for 60 seconds.
Plug the power cord back into the electrical outlet.
If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
If the issue continues to occur, service may be required.
Thanks for using Fixya.
Jul 16, 2011 | Sony Televison & Video
When i turn on my tv the little red light blinks. THen the sound comes on but no picture. After a couple of seconds the red light starts blinking again and the standby light comes on and then nothing.
Jul 16, 2011 | Sony KP-51HW40 51" Rear Projection...
Red standby light came on and no picture sound is ok .Next. time tv came on it played approx one hour everthing ok. then the picture gradually faded away . Red standby light came on again. Still no...
Jul 08, 2011 | Sony Televison & Video
Red standby button comes on after power comes on. It blinks 13 times, pauses few seconds, then 13 more blinks
May 25, 2011 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Sony 3 lcd rear projection tv hd w/ wega gate. kdf-e42a10. tv will atempt to turn, shuts down, greem power light blinks 12 times on average. red standby light blinks 4 times. i replaced lamp [ xl 2400...
Mar 02, 2011 | Sony KDF-E42A10 42 in. LCD Television
My Sony Trinitron TV 1999 (KV-32V42) made a strange popping sound and I lost both the sound & picture. When I turn it back on, the two red lights on the front of the TV(standby/Timer light & Stereo...
Feb 04, 2011 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Red blinking light
The red light blibking 6 times indicates that the power supply board has a defective or damaged area. I know this because i had the same problem...bought a damaged tv for parts and replaced the power supply board as the tv would not turn on...wokrs like a charm now.
Jul 24, 2008 | Philips 37PF9631D 37 in. LCD HDTV
Red Light Flashing 6 times
When the lamp fails in this unit, often the thermal fuse opens. The error code is 6 blinks. To replace this part requires a great deal of deal of disassembly.
Mar 29, 2008 | Sony KDF-E55A20 55 in. LCD Television
Sony sxrd kds-r69xbr1
4 red blinks indicates a fan error. usually blowing duster inside the fan blades will cure this. there are 4 fans inside this tv. looking from the back of the tv, the large fan on the left side is usually the culprit...good luck to ya
Oct 16, 2007 | Sony Grand WEGA KDF-60XBR950 60" Rear...
Hitachi 46ex3bc
I have the same problem with mine. i,m pretty sure that it is the built in surge protector is bad. Try unplugging the tv for 30 seconds then plug it back in and turn it on. If your surge protector has not completely gone bad this might work a few times. mine won't turn on at all anymore.
Nov 24, 2006 | Hitachi 46BX01B 46" Rear Projection...
Televison & Video Logo
129 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
