Question about Car Audio & Video
DehP6700 mp restet everytime keys is turned on.
Replaced a 6700mp.I hooked the yellow wire(battery) directly to battery,red wire to ACC and black(grd) to chassis and orange(ill) to yellow.stereo doesn't work.hooked orange to red(acc),stereo doesn't work,all other wires the same.red,yellow and orange together on ACC,stereo works(accidental experiment) now but will not keep preset stations,and it resets itself every time I turn the ignition on.have to search for stations.before I had yellow and orange together,red to ACC etc.the stereo will keep stations as long as the ignition is on but will loose them when I start engine again.I do not get it.any help will be greatly appreciated.so in a nut shell,everything works but I have to start over everytime I start the engine...thank you..steve
  • kilo1zero_7 Nov 13, 2008
    in my over zealous attempt to get it hooked up I over looked the "second" safety fuse I have in the yellow line.why I have it there escapes me.It was blown.everything works as it should now.It is real nice to have a clear head guide you(you guys) after 3 days of off and on frustration.I was ready to resign myself to accept it the way it was.the stereo was stolen and the thieves broke my window and ripped the stereo and wiring out so you can imagine the mess..it's all straight and re directed to it's proper place..again many thanks for pointing me in the right direction with the yellow wire.steve..
    Problem Solver:
  • 6 Answers
First red is ignition or acc (turns off and on with the key) yellow is constant power (always hot keeps memory) orange is illumination (lights up radio) if vehicle doesnt have a seperate illumination wire connect it to the ignition wire. now process of elimination your ground is correct because it worked with all wires to acc your acc works because u had all them connected to it and it worked your problem is in your yellow or constant/memory i suggest u test it again take piece of wire any old thing long enough will do and run the wire directly from the battery under the hood and just run it outside the car through the window and connect it directly to the yellow wire make sure u have a good connection at the battery on the positive side if u have test light or volt meter test the wire before connecting it to the radio if it works then u know there is a problem with the wire from the vehicle (fuse wrong wire bad wire ) if it doesnt work make sure ground is connected tight and that paint is cleaned of the surface where ground connects and that the yellow wire to the radio is tight in the back of the radio.
Posted on Nov 13, 2008
Need a wiring diagram on suzuki raiderj 110. Please. Tnx.
Maybe you can use these codes taken from:
http://www.motorcyclephilippines.com/forums/showthread.php?120554-Motorcycle-Electrical-Wiring-Diagram-Thread
This is a Wiring Harness Guide for Suzuki Smash, Raider J, ShogunR/Pro Motorcycles. It may also be applicable to Hayate, Step, Mola and Raider 150.
CDI
ORANGE - from Ignition +ACC
BLACK/swhite - Ground
WHITE/sblue - to Ignition Coil
BLUE/syellow - to ENGINE Stator side
ENGINE - Stator Single Phase
WHITE/sred - To RECTIFIER
YELLOW/swhite - To RECTIFIER
BLUE/syellow - from CDI sensor
ENGINE - Transmission Gearbox
GREEN/sblue - 1st Gear
YELLOW/sblue - 2nd Gear
WHITE/syellow - 3rd Gear
RED/swhite - 4th Gear
BLUE - Neutral
ENGINE - Rear Side
PINK - Odometer Speed Sensor
ORANGE/sred -
ELECTRIC Start RELAY
YELLOW/sgreen - form Starter Switch
BREAK - Foot pedal
ORANGE - From ignition + ACC
WHITE/sblack - to Break light
BREAK - Hand Lever
ORANGE - from IGNITION + ACC
WHITE/sblack - To BREAK Light
FUEL Sensor
Yellow/sblack - to Console
REAR - Lights
WHITE/sblack - form BREAK foot/hand
GRAY - From Night Switch
BLACK - from Left Turnsignal
LIMEGREEN - from Right TurnSignal
Signal Flasher Relay
ORANGE - from Ignition + ACC
LIGHTBLUE - Signal SW
RECTIFIER
WHITE/sred - From STATOR
YELLOW/swhite - From STATOR
RED/sorange - BATT+/HEAD LIGHT
IGNITION Key
RED - from FUSE
ORANGE - to ACC
HORN Switch
Green - to Horn
HORN
GREEN - from HORN Switch
ORANGE - Ignition + ACC
NIGHT Switch
RED/sorange - From Rectifier
GRAY - To REAR LIGHT/HEADLIGHTThis is a Wiring Harness Guide for Suzuki Smash, Raider J, ShogunR/Pro Motorcycles. It may also be applicable to Hayate, Step, Mola and Raider 150.
CDI
BLUE - Neutral
ENGINE - Rear Side
ORANGE/sred -
BREAK - Foot pedal
BREAK - Hand Lever
FUEL Sensor
REAR - Lights
RECTIFIER
IGNITION Key
RED - from FUSE
ORANGE - to ACC
HORN Switch
Green - to Horn
HORN
NIGHT Switch
CDI
BLUE - Neutral
ENGINE - Rear Side
ORANGE/sred -
BREAK - Foot pedal
BREAK - Hand Lever
FUEL Sensor
REAR - Lights
RECTIFIER
IGNITION Key
RED - from FUSE
ORANGE - to ACC
HORN Switch
Green - to Horn
HORN
NIGHT Switch
Dec 27, 2015 | 2006 Suzuki Stratosphere
2003 chevy venture problems
Yes the battery can be effected (drain) but in any kind of weather, unless you turn the radio off when you turn the engine off. The power wire in either application is connected directly to the battery as opposed to being connected to the ACC terminal which will be switched on and off with the ignition. You should connect the power wire (should be RED in color) from the radio plug to the terminal (marked "acc") on your fuse box located somewhere under your dash board. It sounds as though it's possible that the RED power wire and the YELLOW "Memory" wire have been switched, the power wire should be switched with the ignition and the Memory wire should be connected directly to a Battery terminal (marked as Batt also on the fuse box) or to the battery itself. All of these wires should be labeled with a small tab indicating there connection. Example Red wire marked (+ poss power), Black wire (- Neg Ground) Yellow wire (Memory) and usually 2 Green, 2Grey, 2 Blue, 2Purple as for the Speakers Poss. & Neg. respectively.
Dec 29, 2013 | Cars & Trucks
I had the same problems as the first guy but never got another answer back. I hooked up my yellow wire to my 12v constant boat battery and I got power because I could put in a disc and take it out but the...
Hi:) The yellow goes directly to the battery posative and the red goes to the ACC on the KEY switch if the radio is not connected to the posative ACC wire on the Key switch you will have no Radio at all the yellow is just for the radio's Memory and the CD motor and eject.
Here is a install pdf. site for that radio. http://www.docs.sony.com/release/CDXM10_install.pdf
May 12, 2011 | Sony CDX-M10 Car CD/ MP3 Player
Where do you connect the memory wire on a jvc kd g110 car stero.....what color is the memory wire ?? what does hook red wire to acc fuse mean??? what wire does the red wire on the radio connect to on...
The yellow wire is most likely the memory wire as it needs to be connected to a constant 12 volt source.
"Hook red wire to to acc fuse" means you need to hook into the fuse block under an Accessory Fuse. (ie: something that can't be turned on unless the car is running or the key is in the "Accessory" position)
The red wire is explained above. It does not connect to the harness.
Just remember that the yellow wire needs to be hooked to a constant 12 volts and the red needs to be hooked to a circuit that is only active when the car is running or switched to the "ACC" position.
Mar 02, 2011 | JVC KD-G110 CD Player
I WOULD LIKE TO KNOW HOW TO HOOK UP THE RED AND YELLOW WIRES FROM A JVC KD-R400 CAR STEREO TO THE WIRING OF A 1999 PONTIAC MONTANA
The red should be ACC. Meaning it only supply 12 volts when the ignition is in the acc position or in the on position or when the car is running. It do not supply 12 volt if the ignition is off. The yellow wire is Battery(sometimes called B+). That means it has 12 volts at all times even the ignition is off. This wire is responsible for memory. Get a meter or a test light. Turn the ignition off and find which wires has 12 volts, you caonnect that to the yellow wire. Now turn the ignition key to ACC, and find the wire that has 12 volts, now turn the key off , the 12 volts should go away, You connect that to the red wire.
Nov 25, 2009 | Vehicle Parts & Accessories
After market radio wires causes light issue with light switch
check your ground on the radio......... the feed from the lights will test as a ground and the radio will use this as a circuit and turn on the lights. been there done that what a nightmare
Oct 02, 2008 | 1996 Dodge Dakota
Need to know what the seven wires are coming out of Clarion Cassette player model # PH-890v that came stock on a 83 GoldWing motorcycle. The wires are Blue Green Yellow (about 18 ga. (I know the blue is...
The blue one is switched because it has no power till you turn the key on This setup is on a Gold wing motorcycle with a intercom it is an elaborate setup The yellow wire shows a momentary grd every time you test it then nothing, no grd , no power
Sep 03, 2008 | Clarion Car Audio & Video
Won't turn off or on automatically
You must have the yellow and the red wires tied together on a constant voltage source.
Only the yellow wire should be on a constant voltage source.
The red wire should only get voltage when the ignition is turned on or in the acc. position.
You need to rewire the red wire on the radio.
Let me know if it helps.
Jun 07, 2008 | Kenwood KDC-MP4028 CD Player
Re sent wire diagram gat all messed up
Hi
have we spoke before in previous post?
the red can go to any 12v live peramanent such as wire to clock or other item that has power with ignition off and the same with the yellow if your putting these to the same permanent live say from clock you can join these to together red/yellow to red on clock
the black can go to any metal or neg wire.
This should then have your device working the only problem im looking at for you now is the pink wire as this stops you using the device whilst driving as it goes to handbrake but i need to find out if its live or negative.
You could just wire the red/yellow to live and black to earth then see if it switches on and works if not then let me know and ill see about the pink wire ok
Makes sure you use inline fuses on the live wires so as not to short the device out.
Make sure you know what is permanent live to put the yellow/red wire to.
It doesnt need to be ignition it only says this so you cant use it with ignition off but you can wire it into any live feed from clock or switches so its up to you what to wire it to its just the pink wire im concerned about.
PINK: does it tell you to put it to live or earth on handbrake switch?
let me know ok
Apr 19, 2008 | Car Audio & Video
Panasonic CQ-C1335U CD/RADIO FOR AN AUTO
what kind of car do you have a Chevy by any chance?? Any way that red wire needs to see 12 volts in order for the radio to turn on. But this is the wire that should get power when the key is turned on NOT directly to the battery. By the way, If you wires to the battery make sure that you have a fuse no more than 6 to 10 inches away from the battery. You should no matter what make you have be able to find a constant 12 volt for the yellow wire and a ground for the black in the dash. Hit me back with year make and model and I'll let you know how to find some ignition.
Nov 27, 2007 | Car Audio & Video
Car Audio & Video Logo
349 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
