Question about Jenn-Air JMV8000 Microwave Oven
Taking the door apart on Jenn Air Microwave
I am taking the door apart and got the black frame off, but I am having trouble with the next part to come off. How do I take it apart?
Thanks,
Neil
  • ngoldman Nov 13, 2008
    I have the door opened and I pried off the frame, but the next part of the door I am unable to figure out how to remove it.
  • Jenn-Air Master
  • 19,396 Answers
Follow the diagram here.
Open the door and unscrew the hinges, part number 14 and 13 in the diagram.
Posted on Nov 13, 2008
    Sergeant:
    Novelist:
  • 196 Answers
Actually what problem u r having that u have to open the oven .can u explain.
Door won't stay shut, microwave will not start
Contact the maker or Google the model number for "parts"
That part likely will require the unit to be taken apart to replace it.
Jun 16, 2012 | Jenn-Air Microwave Ovens
How to remove the outter door frame on the GE Microwave
http://www.repairfaq.org/sam/micfaq.htm
for both queries this site would help somethin i think.. tpugh information is very huge please see if it is useful for u
Dec 25, 2007 | GE Advantium 120 Convection/Microwave Oven
Jenn air microwave loose door
Most if not all of these units have a safety switch--can't get at it from the outside---if unit is taken apart it often is snapped into a plastic holder and prevents the unit from working if door is open.
If it is loose or not engaged completely the unit will do what you are describing.
Jun 15, 2012 | Jenn-Air Microwave Ovens
Hi, i have a dirty window , have cleaned both sides without touching it. think its between the glass and the liner. can' find my manual. can i take the bake of the door glass off some way to clean...
Hello, Thank You for using FixYa. I will be helping you today. It is hard to take apart without breaking it! It is held together with all plastic clips and they break! But you can by putting a putty knife in the inside door seam all the way around and pry the clips down to pop the door apart.
Thank You and please rate my answer if it was helpful..
Jun 27, 2011 | Jenn-Air JMV8196 Microwave Oven
Jenn-Air JMC7000 Microwave stop working
I have the same unit and age the JMC7000 everything appeared normal on the display and countdown etc...But it would not heat,I trouble shooted the problem and discovered it was a faulty door switch I replaced it and it works like new again.I ordered the part from www.repairclinic.com it's an easy fix.and costs a few bucks...
Dec 19, 2008 | Jenn-Air JMC7000 Microwave Oven
JMV8186AAB microwave oven
You can download Jenn-Air/Whirlpool owner's manuals and installation instructions here.
Dec 15, 2008 | Jenn-Air JMV8186AA Microwave Oven
Replacing outer glass and stainless steel door on my jenn-air microwave oven
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
Or you can watch a YouTube video (not a video I made) here that demonstrates how it's done.
Aug 30, 2008 | Jenn-Air JMC8130DD Microwave Oven
Sharp R-930CS Microwave
Check to see the turntable it is seated properly. Try to spin it by hand. If it moves easily, it is not in the right place.
If seating it properly does not solve the problem, you'll need to take it apart to see what the mechanical problem is caused by.
It could be as simple as a clogged gear. Or it could even be a broken gear or bad motor. A visual inspection should provide clues.
Be careful. Disconnect it from the AC before taking it apart and do not operate the microwave disassembled as microwaves are harmful to humans. It can cook them!
Mar 24, 2008 | Jenn-Air JMC7000 Microwave Oven
Jenn air microwave oven door handle
You can find helpful exploded view diagrams for the similar model M438 here: http://tinyurl.com/gv383
The model M437 is not listed, but the M438 is, and it should be similar enough to guide you. Just don't count on the part numbers being the same.
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the screws you need to remove.
We're happy to help and we appreciate your thoughtful rating of our answer.
Mar 24, 2008 | Microwave Ovens
No power on Jenn-Air JMC 7000 ADB Microwave
I have a different Jenn-Air built in microwave & oven combination but I'm sure my solution will work for you as well.
My microwave was plugged into an outlet located on the top of the oven. This outlet has a "circuit breaker" that tripped while we were using the self cleaning feature on the oven. You just need to reset the breaker button right next to the wall oven outlet. Why it tripped is a mystery since the microwave was not in use at the time. Bad design.
Of course, getting to the reset button is your only challenge. You need to pull the microwave and oven out of the wall/cabinetry in order to get to it. The unit is heavy so you will need help. Or, call a certified repairman and they should be able to do this for you in 30 minutes or less so the service call should not run you more than @$85 if it is no longer under warranty.
I would also suggest you contact Jenn-Air to complain about this issue and seek reimbursement from them if necessary.
Dec 18, 2007 | Jenn-Air JMC7000 Microwave Oven
Jenn-Air JMV8000 Microwave Oven Logo
59 people viewed this question
Top Jenn-Air Microwave Ovens Experts
William Miller
William Miller
Are you a Jenn-Air Microwave Oven Expert? Answer questions, earn points and help others
