Question about Hape Woodyclick Construction System, Car Transporter
Battery light on continuesse and indicators not working
1stly 2day whilst driving my battery light came on and stayed on. the vw transporter is taking a charge and the light goes off again when the ignition is turned off. 2ndly last week the indicators stopped working and it isnt the fuse. thanx
Its the alternator
Posted on Nov 15, 2008
Hello, the front left indicator is not working neither flashing at all. The rear left indicator just stays lit and does not flash. The right indicators work fine. I have bought the correct bulbs and...
Concentrate on the front indicator.
With a meter check you have an intermittent supply with the ignition on and left indicator selected.
If its ok, it will be an earth (ground) problem. Check using a temporary earth wire from the indicator unit to the chassis.
If no voltage found at indicator bulb, trace the supply cable back to source.
Sep 23, 2017 | 2007 Yamaha Ybr 125
Hi I own a 1996 VW Transporter 1.9td. The alternator has recently been replaced. The problem is that when it is started the battery light stays on and the oil warning light flashes. This does go away if...
Hi. I had this too after new alternator. It didn't like it. Had alternator tested and all ok. Auto electrician fitted an ordinary bulb in circuit using a feed from reversing light switch and tucked it away in battery box. It fools the system and works perfectly. He did explain
Nov 11, 2010 | 1997 Volkswagen Eurovan
The ABS light stays on whilst driving on a Honda CRV
Hello. This indicates that you have a bad sensor or a problem with the antilock braking system [ABS]. If your brakes no longer pump themselves when you make a quick stop you know that the antilock braking system is not working. If they still pump, the problem is more likely in sensor to the ABS system. Joe
please rate my answer as very helpful. Thank you.
Apr 20, 2010 | 1997 Honda CR-V
Hi I drive a 2006 Vw Transporter 2.8 TDI, the glow plug light
You've probably solved this by now, but just in case... it's your particulates filter clogging up and needs 'regeneration' by VW techs. They take it on the road and with the aid of a laptop on the pax seat, inject fuel into particulates filter and 'burn it out' it'll cost you 200 quid at a vw dealer.
Feb 21, 2010 | 2004 Volkswagen Eurovan
Hi i have a vw transporter T5 (05) and the central locking has stuck leaving the indicators on mid cycle?
The problem is probably a high resistant connection to the comfort module under the drivers seat (the little black box).
i had the same problem what i did was
disconnect the battery
look under the seat and you will see two sets of wires feeding the comfort module wrapped in a cloth tape individualy then together. carefully strip the tape back about 6-10 inches from where they are taped together to expose the wires.
you should find a spliced connection on the red blue wire (probably coroded). you'll have two red blue wires feeding up from the floor and one feeding on towards the comfort module.
i cut the connection off getting rid of the corrosion, stripped back the wires then re twisted and soldered them together making sure all wires made a good connection to each other. then re wrapped them in insulation tape.
re connect the battery
tried the key in the door which worked then tried the fob which also worked problem solved in 10mins.
Dec 21, 2009 | Volkswagen Eurovan Cars & Trucks
VW Transporter T4 cuts Out whilst driving
hi the van keeps cutting out when driving and is scary when ur stearing locks at the same time wot is wrong it only dose it at dunctions or round abouts it is a 2011 1 mounth old
Aug 18, 2009 | 2001 Volkswagen Eurovan
VW POLO-52 plate EPC light on dash
My Polo had a similar problem and the brake light switch at the brake pedal was replaced. Then the computer was reset and the EPC light issue was resolved. It has something to do with the engine management, when sensing the light switsh being activated, retarding the power of the engine.
Oct 28, 2008 | 2001 Volkswagen Golf
Indicators heating wipers not working vw passat
Driver side front indicater not working but buzzer sounding inside.
whilst middle indicater is flashes the back driver side one stays constantly on and the front not flashing.
Oct 16, 2008 | 2005 Volkswagen Passat
Hape Woodyclick Construction System, Car Transporter Logo
140 people viewed this question
Top Hape Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Hape Toy Expert? Answer questions, earn points and help others
