Question about HP Office Equipment & Supplies
Hp 8000n wrinkling paper - HP Office Equipment & Supplies
Question if you are using plain paper and it wrinkles, but you can print with high quality 100gsm paper
answer the fuser could be on the way out or damaged
Posted on Mar 13, 2009
Hp 8000n is ghosting excess toner on prints. Why?
Perhaps, but first clean up the exposed parts of the printer where the toner may travel before it makes contact with the paper. Also, the fuser may need to be cleaned or replaced. Post your problem directly with HP on the HP website.
Feb 16, 2013 | HP LaserJet 8000n Printer
We have a Laser Jet Pro CM1415. It wrinkles linen envelopes when printing. Is there a quick fix (adjustment etc.)? It prints slick envelopes OK.
that printer is really not designed to print on those envelopes but the wrinkling is usually caused by to much moisture in the envelope or paper stock. When the printer heats the print stock to bond the toner to the paper in the fuser unit the moisture evaporates and causes the paper to wrinkle. Don't know of a fix for it other than use different print stock.
BuddyMc
16 Years HP tech
Aug 10, 2011 | HP Office Equipment & Supplies
What does the error message "out bin full" means
This error indicates that the sensor that detects when too much paper is stacked in the output bin to allow more paper to exit. This flag sometimes sticks and a quick check is to make sure that nothing has become jammed where the paper exits the printer. Most common cause is the flag getting jammed because someone has remove the paper the wrong way. I have never seen the actual sensor fail.
Jul 06, 2011 | HP LaserJet 8000n Printer
HP LaserJet P3005 printer prints wrinkled paper
2 reasons:
1. Was there a paper jam prior to this problem? It could be that the paper was pulled out and a small bit of it is stuck on the pins that guide the paper from the heat roller. If no torn jammed paper prior to this issue, then check out 2.
2. the heater/roller is damaged and needs to be replaced. I would suggest you take it to your nearest HP dealer to properly diagnose this for you.This would save you unnecessary cost in trying to pull it apart and causing more damage to it.
Good Luck,
Jan 27, 2010 | HP LaserJet P3005n Printer
My printer wrinkled the paper when it is out
Try using fresh paper from a new ****. If still wrinkles might be an issue with your fuser. The fuser is the part that heats the toner onto the paper and if the paper contains too much moisture content (from improper storage methods), this can cause wrinkling effect as well.
Try printing with different types of paper and from manual tray to isolate problem. If it occurs all the time, most likely bad paper or bad fuser.
Jan 16, 2010 | HP LaserJet 4200 Printer
CLJ8550n poor print quality and wrinkled paper
this is usually not caused by the paper tray. this problem is usually caused by the fuser assembly. check your paper path. dead cycle the printer, shut the printer down before the paper enters the fusing area, check for wrinkles. remove all paper, print again, check the output, wrinkles, replace the fuser.
Feb 03, 2009 | HP Color LaserJet 8550n Printer
Paper crinkles
This is what I've seen with wrinkled pages in these machines.
Usually only happens with letter size paper.
At some point a leaking toner was used in the machine the excess toner works its way toward the fuser and builds up on the guide where the paper enters the fusing assm.
You can try to clean the toner thats built up or replace the fuser.
Hope this helps
Jan 13, 2009 | HP LaserJet 8000n Printer
HP LASERJET 8000N
there could be a problem in one of your drum, (4 pCS) to isolate w/c is w/c pls do this:
-print one of each color, M,C,Y,K(black)
- once you have identified that one of each is giving you problem pls replace the affected drum
- IF you printed all colors and still having the same line the problem is in the fuser section most likely the fuser roller or the pressure roller is either dirty or damaged.
-if it is dirty clean with alcohol while it is hot, gently rub (be careful it is hot) or cloth damped with oil will removed sticky toner adhered on its surface
cheers, dont forget to mark this pls
Aug 11, 2008 | HP LaserJet 8000n Printer
Paper completely wrinkled
NONERIGHTNOW, HP makes great laser printers, the commercial LaserJets typically last 8+ years without much more than an occasional maintenance kit to keep them going. The 1000 series printers are quite another story, they are designed for the low end printer market and just can?t take hard usage over time. The typical culprits with paper wrinkling are heat from the fuser or paper problems. -In the paper tab of the printer driver make sure the correct media is selected. This controls how hot the fuser gets which also causes paper curl/wrinkling. -Buy some fresh HP grade paper, improper humidity, coatings and storage can also cause problems. -Try a new HP cartridge. If you still have no success starts a print job and turn off the printer while the paper is feeding. What you want to do is try to freeze the wrinkling process so we can identify what area is causing it. Post this information. Also open the rear, straight through door; also let us know what happens. Let us know how it goes and please don?t forget to rate this posting.
Jan 19, 2007 | HP LaserJet 1300 Printer
123 people viewed this question
Ben Johnson
