Question about Dell Precision M70 Notebook
DELL PRECISION M70 SERIAL PORT
HI,
The serial port of my computer does not work.
I test it using the hyperterminal an jumping the 2 an 3 pins.
In order to have another COM port install a USB-SERIAL adapter but it only works when the utility program is running in windows.
I have 5 old PLC'S that can only be reprogrammed using DOS but i can't enable the communication.
I hope you can explain me what can i do to fix that problem.
PD: Sorry if my english is not very good.
Dell precision m70 administrative password is is locked. ehat can i do
Use a program called Kon-Boot
it will bypass all Windows security altogether
Apr 16, 2013 | Dell Precision M70 Notebook
How to reset my dell precision m70 to factory settings
need the windows disk and serial code then you need to boot up your computer and as soon as it begins to turn on press the corresponding button for boot devices this will bring you to a list showing you hard drive CD drive and other peripherals , insert the windows disk and then use the arrow keys to select the CD drive from there just follow the basic next,next,agree installer then i would suggest installing the drivers then all your programs hope i could help =]!
Mar 04, 2012 | Dell Precision M70 Notebook
Precision m70 real slow poor performace
1.you will need to optimize your drive
2. you may have a virus
3. hard drive may be playing out or full
4.not enough RAM ( random Access Memory)
Jul 14, 2011 | Dell Precision M70 Notebook
How can I download sound in my precision/m70 pc? my pc has failed to produce any sound ,even the pc begining sound.
Please download the Audio driver here. And then uninstall and reinstall the Audio driver in the Computer.
Hope this will help you. Good luck!!!
Sep 20, 2010 | Dell Precision M70 Notebook
How to break bios password for dell precision m70 laptop
The only way for you to remove BIOS password is to remove the CMOS battery inside the laptop. You can go to support dot dell dot com.
Cheers!!
Sep 02, 2010 | Dell Precision M70 Notebook
Serial port does not work?
most likely, serial port is faulty. things you can try: update chipset driver, bios, reset BIOS settings, then test serial device through hyperterminal. if the device response through hyperterminal,
Aug 30, 2010 | Panasonic Toughbook CF-51 Notebook
How can you reset a Precision M70 Laptop bios password
For that you need to reset bios password.
There is 2 way (1) Reset bios password with cmos cell and jumper settings.For that you need to open back cover of laptop then find motherboard pull cmos cell from motherboard for 10 minutes then reattach it into it's position.There jumper near cmos cell named clear_cmos it has 3 pins 1-2-3 put jumper in 2-3 position then power up then again put it into it;s original position 1-2 then all password RESET.
(2) you can RESET bios password with software download it from below link.
Click here
Click on above link download software there is instruction how to reset bios password.
Let me know if you need further assistance.
Thanks for using FixYa.
May 07, 2010 | Dell Precision M70 Notebook
Will windows 7 work on my m70 laptop
Hi
Thank you for your query
Your laptop does have the minimum spec for Windows 7, however I would recommend that you upgrade the memory from 1GB to 2 GB as it will be quite slow.
If you havent already upgraded the memory you currently have is 1 GB 533 MHz DDR2 SDRAM (2 X512MB modules), you will need to upgrade this to 2 X1GB 522MHZ DDR2 SDRAM
I hope this has been helpful.
Feb 26, 2010 | Dell Precision M70 Notebook
Dell Precision M70 - Ethernet Port not recognised
if the laptop is wifi enabled there is no need o connect it through the Ethernet cable it will just pick up the signal and you will have to put in the pass code. Even if you want to connect by Ethernet cable you should be able to just plug it in and get on the internet.
if the problem is you don't know the pass code it should be on the original modem manual.
May 04, 2009 | Dell Precision M70 Notebook
Gobook IX250
Hi. I use the 9 pin port with a Cisco rollover cable to access the console port of routers and switches. Using a terminal emulation program such as HyperTerminal. It allows me to configure the routers and switches. I believe that it can also be used to connect to old modems. I hope this helps, Nelson McKinnon.
Feb 29, 2008 | Itronix GoBook IX250 Notebook
Dell Precision M70 Notebook Logo
134 people viewed this question
Brian Sullivan
Brian Sullivan
joecoolvette
joecoolvette
