Question about Lasonic DVDP | DVD-7050 5.1CH
LASONIC DVD PLAYER NOT WORKING WITH COMCAST BOX OR SOYO TV
I'm having trouble connecting the LASONIC dvd player to my comcast cable box, which is connected to my 37" SOYO TV. When I attach all the AV inputs to and from the dvd player and cable box, nothing plays. The DVD player powers on and off fine and "plays" via remote, but no audio or video is being displayed on the TV. I changed the TV setting to read both AV1 and AV2, nothing happens. However, when I change the setting to COMPONENT 2 (which is where my cable box is set up to) the cable works fine. The comcast cable box has AV slots in the front and back, I've tried both with no success. I'm wondering if the problem lies in the TV or if there is some other sort of adapter I need to help link the DVD player to the cable box. Do all DVD players work with all TV's ? If not, what can I do. Any help would be greatly appreciated. -Anthony D Some other information: I setup the DVD player to every other TV in the house and it works fine. TV MODEL # Soyo DYLTO37A 37 in. LCD Television Standard Comcast Cable box All electronics are new, purchased a week ago.
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 92 Answers
You have to plug everything to the tv. only thing them are good for is recording to some other unit. like dvd recorders
Posted on Mar 05, 2017
4 Suggested Answers
SOURCE: The player does not recognize the hard disk after converting to NTFS.
check and see if the harddrive settings are set to master. this will solve the problem
Posted on Mar 09, 2008
Sparky2012
  • 102 Answers
SOURCE: I have a lasonic portable dvd player. When I plug
look for a switch to select DVD or Monitor or IN OUT
Posted on Dec 04, 2009
atang1
  • 734 Answers
SOURCE: my lasonic dvd player model
Humidity problem resulting in moisture on the circuits. Drying it out makes it work. Store it in ziplock bag if it was in working condition to avoid moisture on rainy days.
Posted on Mar 11, 2011
How do I hook up a HD satallite dvr to a av reciever dvd player and HDTV using HDMI cables
Things You’ll Need:
  • HD television
  • HD satellite or cable receiver
  • DVD player
  • Stereo receiver
  • AV cables
  • Cable connector
  • HDMI cables
Step1Examine the back of your HDTV. You will see a series of input jacks for AV cables, (typically color-coded white and red for audio and yellow for video), as well as an antenna input and one or more HDMI input jacks. There will likely be a number of them, but each one should be distinguished with a label ("video," "cable" or something similar). Step2Attach the cable connector from the cable or satellite receiver to the antenna input on the back of the TV. Step3Connect the AV cables to the DVD player, VCR, stereo receiver or whichever other component you wish to connect to the television. The cables should line up by color: place the white cable in the white input jack, the red cable in the red input jack and the yellow cable in the yellow input jack. All three cables from each component need to go into the same label input jacks. Usually, they will all line up in a vertical row. Step4Find the HDMI output jack on your receiver or DVD player (some receivers will not have them--they are necessary to receive a high definition signal--but can still play on the TV through the cable connector or AV cables). Attach one end of an HDMI cable to the output jack of the receiver and the other end into the input jack on the HDTV. Step5Turn on the TV. Access the menu with your remote, and follow any instructions it gives you. Your HDTV may require a few additional steps to complete the hookup of the receiver (though not all of them will). Step6Access the "input" button on your TV remote. This will allow you to switch the TV signal to one of the cable connections you have just made. For example, if you attached the HDMI cable to the first of two HDMI input jacks, the TV will flash "HDMI 1" on the screen to tell you that is where it is receiving its signal. Hope that helps..........
Jul 15, 2008 | Televison & Video
How do I connect my Samsung dvd-vr recorder to my non HD tv
Hello
Use an AV cable, connect the devices in between that cable to appropriate input sockets, select the input of your tV to AV. Picture of AV cable is attached.3_9_2012_2_26_16_am.jpg
Mar 08, 2012 | Televison & Video
I'm trying to hook up my Panasonic DVD player (model DVD-S29) to a Comcast cable box but have not been successful. My DVD player only has Audio Out connections, with no audio in connections. I...
the cable in should go to the box and cable out from the box to the TV.These should all be coaxial cables correct?Hook up the DVD player to the TV using the red,white,and yellow cables is also correct.In order to watch a DVD,you have to use the input select button on the remote for the TV ONLY to change inputs.If you have a universal remote for the TV and not the original factory remote provided with the TV,you need to use the menu button located on the outside of the TV.I just searched on my flat screen and was unable to find an input select through the menu button.It may not be possible on this TV if you do not have the original remote and if you own a universal.My universal for one of my older TV's is about 7 years old so I do not know if newer ones have an input select option.If they do not,it is most likely due to patents and royalty payments which these cheap remote makers do not want to pay.Anyhow,let me know if this helps.Just comment here and i will get an auto link to your comments.Good luck! Greg
Sep 19, 2010 | Panasonic DVD-S29 DVD Player
TRYING TO INSTALL DIGITAL SET-TOP BOX WITH DVD AND TV
Hi ccraigo
To answer your question;
Your motorola will connect directly(not through the dvd) to the tv set into one of the input ,(preferably using hdmi or component cables for hd) and the dvd will use a different input,
All you have to do then is switch between which one you want to watch.
Hope this help Cheers
Apr 20, 2010 | Pioneer Televison & Video
I have a Philips DVDR 3575H. using Comcast's
Try this set up-
Use an RCA audio/video cable for this set up (Yellow/Red/White).
Connect from the Video out (Yellow) connection on the back of the cable box to the Video in on the back of the DVR.
Connect the audio (Red/White) cables from audio out connection on the back of the cable box to the "Audio in" on the back of the DVR.
This should still get you a decent picture but not a true HD picture for your recordings.
When you set the timer to record set it to record either E1 or E2 depending on which input you connected the cable box to and ensure that the cable box is tuned to the channel you wish to record.
*** NOTE: If you keep the HDMI cable connected as you have for the cable box and watch normal TV through the HDMI input on the TV you will get HD programming for your general viewing but still have the option to record with the DVR at a lower quality. ***
Good Luck and please rate this solution....
Jan 07, 2010 | Philips DVDR3575H/37
How to connect motorola cable box to samsung dvd/vcr model vr375 to a Westinghouse hdtv with 2 hdmi connections
The DVD-VR375 does not have an HDMI input. The connection should be:
• RED WHITE & YELLOW CABLE from your cable box (AV OUT) should connect to the DVD-VR375 (AV IN 1). Set the DVD-VR375 to AV 1 using the INPUT SEL. button.
• Next, connect an HDMI cable from the DVD-VR375 (HDMI OUT) to the TV (HDMI IN). Set the TV to the proper source.
This connection would allow the recorder to work as a pass through and will let you record TV programs as well as watch your cable channels.
Hope this helps!
Jul 06, 2009 | Samsung DVD-VR375 DVD Recorder/VCR
Philips dvdr3575h/37 Initial setup
Do you have two cable inputs going into your player?
May 01, 2008 | Philips DVDR3575H/37
Audio Problems
well dvd player is only 480 i ok not 720 unless its blue ray so dont even do that coupont cables usallly 480 also with comcast outs do u have hd then use one with hdmi outs ok coxal digtal cable works great also better rcas
Jan 05, 2008 | Olevia LT37HVS 37 in. LCD HDTV
Televison & Video Logo
128 people viewed this question
Top Lasonic Televison & Video Experts
JOHN TOPLISS
NOEL
NOEL
Joe Ball
Joe Ball
Are you a Lasonic Televison and Video Expert? Answer questions, earn points and help others
