SOURCE: Could Anyone Tell Me, How To Unlock Region Free A BDP-S300 Player??
http://www.stegen.com/product_info.php/products_id/1019?osCsid=daccaf0338a597dd1985e0ad70ac277a
SOURCE: DVD stuck in sony blueray player bdp s300
Step1There are a few ways to get your dvd/cd drive release itself. The first thing you should try is shut your equipment completely off for a couple of minutes allowing it to cool down. Once you turn it back on try to press the release button on your equipment. Step2If that does not work try to use a very thin flat tip screwdriver. Insert in on one of the sides of the dvd/cd drive and try to pull it out softly while pressing the eject button simultaneously. Do not force it out but give enough pressure while pressing the eject button. Step3More than likely inserting a screwdrive should release the dvd/cd drive. You can also try a butterknife as well just don't use to much force. Something else to check for is to make sure the power is acutally on for the device. If you are trying to open a drive that is not even on it will never open up for you.
SOURCE: How can I unlock the region code for my Sony BDP
go to esupport.sony.com for latest firmware upgrade.
SOURCE: Code to enter on remote
I have the same problem with the Sony SBD-s360 blue ray and the Verizon Fios remote. Not codes work and I tried over 1000 search codes with no luck. Verizon needs to replace the remote with a later model
