Question about ASUS K8V-MX Motherboard
SK8V Motherboard Powering up no video response.
I have the motherboard all hooked up ram installed and an AMD 940socket chip in. There is no response form the motherboard when power is turned on. Changed the video card. Dnt know weather the issue is the chip or the board.
    Problem Solver:
  • 18 Answers
Do you have a system speaker installed
are there any beeps
have you tried another power supply
Posted on Nov 14, 2008
K7SV266AD Can I use 266Mhz athalon processor with this board, book says 100/133 FSB. If so what processors? Thanks
The Syntax K7SV266AD motherboard uses a VIA motherboard chipset.
It uses a VIA KT266A for the Northbridge, and a VIA VT8235 for the Southbridge.
About the motherboard chipset;
Chip and Chipset are slang terms for I.C.
Integrated Circuit,
http://en.wikipedia.org/wiki/Integrated_circuit
The Northbridge chip handles the faster capabilities of the computer.
It handles the Processor, Ram Memory, and High-speed graphics.
High-speed graphics is AGP or PCI-Express
A graphics card inserted into a PCI slot is Not high-speed graphics.
Neither is Integrated Graphics.
(Integrated Graphics is also referred to as OnBoard graphics.
ON the motherBOARD. The graphics chipset is soldered directly to the motherboard, and not to a graphics adapter card. {Graphics card}
The graphics chipset is a GPU.
Graphics Processing Unit,
http://en.wikipedia.org/wiki/GPU
The Southbridge chip handles the slower capabilities of the computer.
It handles the IDE, and SATA capabilities of the computer.
It also handles the USB ports, Ethernet, and Audio, plus anything connected to a PCI slot, and Integrated Graphics, to list a few examples.
Motherboard Diagram,
http://en.wikipedia.org/wiki/File:Motherboard_diagram.svg
[For further information you may wish to search on Wikipedia,
A) Northbridge (computing)
B) Southbridge (computing)
C) Bus
D) PCI Local Bus
E) AGP (Accelerated Graphics Port)
F) PCI Express
G) Front Side Bus ]
Looking at the motherboard with the Processor to the top, and Ram Memory to the right, the VIA KT266A northbridge chip is below the Processor.
The aluminum finned Heatsink covers it.
The VIA VT8235 southbridge chip is down towards the lower right corner.
Looking at the specs for the VIA KT266A chip we can see,
http://en.wikipedia.org/wiki/List_of_VIA_chipsets#Slot_A_and_Socket_A
1) It supports either DDR Sdram ram memory at 200MegaHertz, or 266MHz.
PC-1600 or PC-2100, respectively.
(DDR Sdram is clocked twice. Therefore the 133MHz Front Side Bus {FSB} support will handle 266MHz ram memory)
2) The Maximum ram memory it will support is 4GB. If you have the motherboard manual, you will know what the maximum amount of Ram Memory is, that the motherboard will support.
3) Will support Processors with either a 100MHz, or 133MHz FSB. (Front Side Bus)
AMD processors are 'Double-pumped'.
The VIA VT266A chip will handle AMD processors with up to a 266MHz FSB.
It will handle AMD Athlon, or AthlonXP, or Duron processors, with a maximum FSB of 266MHz.
http://www.via.com.tw/en/products/chipsets/legacy/kt266a/
The best processor will be an AMD AthlonXP with a 266MHz FSB, that fits in a Socket A (Socket 462) processor socket.
Watch the Voltage used. Look up the AMD processor you have installed now, and see what voltage range it uses. The new processor must use voltage in this range also.
http://en.wikipedia.org/wiki/List_of_AMD_Athlon_XP_microprocessors
For additional questions please post in a Comment. (Upper right of your page)
Regards,
joecoolvette
Jul 04, 2011 | Syntax Computers & Internet
Mother board is hang while formatting.Intel PENTIUM-4 865GV CHIP MOTHER BOARD Motherboard
kindly clean the ram and if there is more then 1 ram in motherboard removed that and try installing with single ram. also check the fan is working fine and .the heatsink in not too heat. chek the media cd also .
Hope this helps. Please rate my response.
Thanks.
Have a good day
Dec 23, 2010 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
My dv6000 will not come on, the lights come on fro about 2 sec. the shuts down. I replaced the motherboard but still will not power up.
You are in for a rough fix. See the HP forum and follow the directions on this web posting. Get a PC geek to help.
http://forums11.itrc.hp.com/service/forums/questionanswer.do?admit=109447626+1269377543004+28353475&threadId=1147659
Search for the date given below:
Nov 22, 2009 16:10:23 GMT Unassigned HOW TO FIX YOUR DV6000/DV9000/DV2000
All the Problems described in the previous posts are Graphics Related..
Faulty Nvidia Chip..Both Intel And AMD Based Motherboards..Though More Common on the AMD..
The symptoms of the Laptop Powering on and Shutting Off Repeatedly..Or.. Powering On and Having No Video...Or... Power Strip Lights Up, Beeps,Shuts Down...Or..No Power At All...Or.. Intermittant Loss Of Wireless/Video Goes In And Out/Touchpad Slows and Freezes..
To Fix this issue, You will need to Reflow The Graphics Chip.
I will Explain In Full Detail As To The Correct Method Below....
HP DV6000/DV2000/DV9000 Compaq v2000 Video Chip Reflow Instructions
First Step Is Complete Disassembly Of All Parts And Components..
Remove RAM, Remove CPU, Of Course Remove Heatsink and Fan assembly.
Mar 23, 2010 | HP Pavilion dv6000 dv6100 dv6200 dv6300...
I have just purchased a AMD Athlon? 64 X2 4400+, 2.2 GHz and installed in a imedia Board: NEC COMPUTERS INTERNATIONAL MS-7168 1.0 Bus Clock: 200 megahertz BIOS: American Megatrends Inc. V3.07 do i need to...
It looks as though my resources were incorrect, as far as the two motherboards having the same processor socket.
(MSI RS480M uses a Socket 754)
What does concern me, is if the motherboard chipset used is the same. This was the stated information.
The motherboard chipset consists of the Northbridge chip, and the Southbridge chip.
Chip, and Chipset are slang terms for IC. Integrated Circuit.
Viewing this motherboard diagram may help explain how the motherboard chipset comes into play,
[You can also type, one at a time, Northbridge (computing), Southbridge (computing), Comparison of AMD chipsets, in the Wikipedia search bar, to gain more knowledge]
The Northbridge chip determines what Processors can be used.
It also controls high speed graphics technology.
AGP and PCI Express being high speed graphics, not PCI.
Determines what Ram Memory is used, and what Southbridge chip is compatible with it.
Let's go back to basics, and see what Northbridge chip is on your motherboard.
Two ways.
One, it looks as though you may be using a tiny program such as CPU-Z, or Belarc Advisor.
If not, I would advise downloading the free, tiny program CPU-Z from CPUID.com
Can you install the old processor, (AMD Athlon 2.25GHz), and get your computer to work, or are you using it now?
After you have CPU-Z running, left-click on the Mainboard tab, and tell me what it states for Chipset. Also tell me what it states for Southbridge.
Second way.
Physically look at the Northbridge, and Southbridge chip. IF, they are not covered with a heatsink.
The Northbridge chip is usually a large chip, and is located close to the processor socket.
Most configurations are like this; Processor socket at the top of the motherboard, ram memory slots to the right, Northbridge chip below the processor socket.
Motherboard designers put the Southbridge chip all over the place. There is no usual spot.
It is my belief at the moment, that your Northbridge chip will not support dual core processors, such as an AMD Athlon 64 X2 4400+
Only Single core processors.
Once I know what Northbridge chip you have, we can determine what your CPU support is.
Jan 23, 2010 | Systemax Dual-Core AMD Athlon 64 X2 4400+...
Smoke smell from pc after ram change
yep, your mobo is fried, DDR2 and DDR do not share quite the same pin payout. Toasty Mobo, but on the plus side now you'll be able to buy one that has better driver support.
And kudos for hiring an assistant who shoehorned RAM into a slot it did not fit in and firing it up.
Dec 24, 2009 | VIA ASUS SK8V MB, 8T800/ SATA/ RAID/...
Motherboard dont see all installed ram after changing cpu's.
You might want to update the bios. Flash the bios on your new motherboard.
Aug 11, 2009 | ASUS Computers & Internet
How to upgrade acer aspire m1100 ram
It is actually pretty simple, just remove either screws or fasteners holding the case on. On that model it may even just be the side panel, which would be 2 screws/fasteners. Here is a video that explains the process. http://videos.howstuffworks.com/howstuffworks/26-how-to-install-ram-to-a-desktop-computer-video.htm Thanks,
Lee
Jul 09, 2009 | Acer Aspire M1100-U1402A Refurbished AMD...
Memory +cpu upgrade
No to the cpu you selected. Board would not support that cpu. The RAM you selected would probably work but for how long I couldn't say. With prices pretty low right now it would probably be better to purchase a new motherboard, cpu, & RAM. Hope this helps.
Jan 10, 2009 | MSI MS-6367 Athlon XP 266FSB MicroATX...
M7VIG-400 NOT POWERING ON
possible cause: 1.low supply of voltage try checking your Power Supply Unit(PSU). try to swap with a different good PSU. 2.Defective/burned Motherboard, check for any bloated Capacitors or burned chips...
Sep 09, 2007 | Biostar M7VIG-400 (M7VIG 400-COMBO4)...
ASUS K8V-MX Motherboard Logo
46 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
