Question about Sony FD Trinitron WEGA KV-36FS120 36" TV
Clicking tv my tv also just clicks and doesn't power on. i'm wondering if there is a simple solution, or if someone came to fix Jonayuan's tv if the problem could be fixed. thanks
    Genius:
  • 1,139 Answers
Hello pak11,
The clicking sound, may be the shutdown circuit activating a kill relay. This is an indication that there is a problem in the HV section of your TV. This may be the horizontal output transistor or one of the other components in the HV section. I would suggest that you have a qualified TV technician examine the TV because the HV section is very dangerous and should be troubleshot and worked on by a person who is skilled in the area of TV repair. This problem may be as simple as replacing the Horizontal output transistor, however this task should only be done by a qualified TV technician.
I hope this helps,
Thank you,
Shuttle83
Posted on Nov 22, 2008
Samsung pn42c450b1d will not power on... clicks.. used to click like 5 times now clicks 2 times and goes into standby. ordered a y sustain from shop jimmy and it did not fix the issue. power board is
At first review of your problem the first thought occurred to me is that it may be a bad main/power supply...not familiar with new tv's but wondered if it was a simple as replacing a wire or something. You have said you replaced the main board. At first I didn't think that was necessary but apparently it's a fairly common course of action. That seems like a lot for a faulty power switch...but there's more to it than I realized. I found this excellent youtube video with some expert instructions on how to resolve, hosted by shopjimmy.com; you have referred to this source & I'd suggest it's about the best that's out there to find solution to your situation...seems something isn't switching over right & the tv clicks several times then goes into standby...thereby have to replace the faulty ??? I'd say capacitor but now adays the composite of the boards are alot different. This video link is the best solution. I hope it helps https://www.youtube.com/watch?v=n54IurMvr6o
Nov 25, 2014 | Samsung Televison & Video
Lg plasma not turning on
sounds like caps however if making clicking noise check the relay on power board
Nov 25, 2012 | LG Televison & Video
RCA D40W20 rear projection tv. Power supply problem. Pressing the power button causes the small green LED on that same button to illuminate for a short while. The LED then turns off. It does this about...
HI:
Check all the connections around the Flyback transformer, the click you are hearing are relays not ttransformer. You should have or someone check all the connections in the Horizontal circuits as well. Also there is a capacitor on this same board that may need replacing is a 2200uf 10volt capacitor replace it with same value but increase the voltage rating to 16 volts..
Sep 24, 2011 | RCA Televison & Video
The TV doesn't start, the RED led flashes a click sound is heard and then LED switches off. This goes on and on and on
The problems starts from the power unit, on this board, the voltages needed to operated TV normally dropped down very low.And one of the power resistor/ Integrated Circuit burned.
To fix this,you need to find someone who capable to repair this board or took it to service center.
Aug 23, 2011 | Grundig Xephia 42 in. EDTV-Ready Plasma TV
RCA 36695BC wont turn on
I'm afraid this failure is not just a fuse failure in your TV since you still can hear the relay clicking. This fix might not be a DIY.
Where can I send you additional info on what could be wrong with your TV?
Jul 24, 2008 | RCA F36695BC 36" TV
Problems with the mp3 Player
it is simple use the following code..
*#7370# or go to setting find restore sets orginal setting click ok then enter mobile code eg 12345 click ok.the ephone will restart and i hope after that your cell phone works properly...
Jul 01, 2008 | Nokia 6300 Cellular Phone
RCA tv Making a clicking noise
This is a power supply problem it may be as simple as a blown fuse or as complex as a malfunctioning IHVT (Integrated High Voltage Transformer). Is it worth fixing, only you can answer that I would estimate the cost from $100.00 - $500.00 at least.
Sep 03, 2007 | RCA D61W136D 61 in. TV/DVD Combo
Tv no start up, fuses ok.
Telling someone to get professional help would be the obvious response from a TV repairman who wants to charge someone at least half the cost of TV replacement to fix it. People get on here so the can try and avoid the high cost of tv repair. How about giving advice on how to fix it which is why the got on here to begin with.
Jul 28, 2006 | GE 27GT616 27" TV
Sony FD Trinitron WEGA KV-36FS120 36" TV Logo
54 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
