Question about SanDisk Sansa e250 MP3 Player
My volume wheel keeps freezing up. Please Help!
Every now and then my volume wheel is harder to move like there is some thing stuck in it. Blowing on it seems to help but only for a few seconds. Anybody got a permanent fix???
  • 8,596 Answers
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on May 26, 2008
Why is the wheel on the right hand side of my machine very stiff when turning
the "hand wheel" on a sewing machine is meant to only advance the mechanism far enough to thread and set the needle , the motor should be used to run the machine else wise , as its turning every thing inside the machine to keep all the functions in "TimE" as models increase in there complexity there hand wheels are harder to move as more stuff needs to be kept in "time" now , also on some models the bobbin winder is directly powered by the hand wheel , if its not in use it should be disengaged completely
Mar 02, 2016 | Sewing Machines
WHY MY TABLET FREEZE AND NOT MOVING
FIX Slow, Frozen, Android CRASHES! Cache/RAM TIPS ...
? 7:50
https://www.youtube.com/watch?v=bKt3UEBpD44
Aug 31, 2013 - Uploaded by p1nesap
And no, adding yet another app is NOT the answer! ... So if your Samsung Galaxy phone or Nexus tablet is ...
Android Tablet stuck on boot screen ! Bypass it in easy steps ...
? 4:36
https://www.youtube.com/watch?v=HErn0-GcQqE
Jan 4, 2014 - Uploaded by My Tablet Guru
1) Press the volume up or volume down or home button when thetablet start, this is hit and trial method and ...
Device keeps crashing, freezing, or restarting ' T-Mobile ...
Dec 29, 2015 | Tablets & eReaders
1999 silverado stuck in 4lo. fuses keep blowing. how do i get it back into 2whee
isolate the reason for the dead short that keeps blowing the fuse. Look for a broken wire under body on a actuator or a wire that has rubbed through on the transmission .
Apr 23, 2014 | 1999 Chevrolet Silverado 1500
Something's Stuck!
Can't you move the wheels around to jiggle it out? If you can't you will need to preform some surgery from the one wheel, just keep track of all the screws when disassembling it; that is a last resort
May 19, 2013 | RC Thunder Tumbler Rc Car
Key stuck in ignition of 1995 honda civic dx and stuck in acc mode
try moving the steering wheel lock to lock progressively harder, not trying to break it, and alot of the time that will help jiggle and release it.
Apr 19, 2013 | 1995 Honda Civic
Why is does my rear wheel cylinder keep blowing?
if the brakes over extend the cylinders will pop, make sure you have properly adjusted the brakes, also make sure the emergency brake cable is working and not stuck partway on which will hold the shoes away from the cylinder.
the shoes should be adjusted so that you spin the wheel and it turns twice and stops.
Oct 10, 2012 | 2000 Dodge Stratus
My iphone 3G is stuck on the main screen and I can't get the icons to open, can't get screens to move and it won't reboot
Plug the thing in and give it a full charge. Then try holding the home and power button until the apple logo appears and the spinning wheel starts moving.
If that don't worked, then your fu.k.d, in which you should take the thing back to the Apple store or call it in for service if you live in the sticks because you have some software glitch. Keep in mind that Apple won't do sh.t for you if you water damaged the unit.
The screen can also freeze if you water damaged the unit or dropped it.
Feb 10, 2010 | Apple iPhone 3G
My subwoofer fuse keeps blowing out , what might the problem be ?
There may be a loose wire inside that is moving from the bass and shorting out when it touches the wrong place inside. Check and see if that's what it is.
If not, try turning the Bass/Volume down some on the Subwoofer so it's not putting so much of a strain on the Amplifier.
Another thing you could try, but it's usually NOT recommended, is to use a fuse with a higher Amperage rating so it's a bit harder to blow.
I hope this helps :)
Best Regards,
James
Jul 29, 2009 | JVC SPPWA670 Subwoofer
Sansa e250R - Will pwr up but only freezes on screen that says..."Sansa Rhapsody"
instead of volume +, use REC - the correct button is located in the manual somewhere
Jul 28, 2008 | SanDisk Sansa e250 MP3 Player
Print Problem
Could be 2 things:
Either the 3rd digit of the number wheel is sticking or the solenoid for the 3rd digit is dirty, stuck or bad.
You can take the cover for the paper and see if the wheels are turning. Enter all 8888888888's and keep hitting +, this will make all of the wheels turn. If the 3rd digit isnt moving, then you can try to take a very small drop of light weight machine oil on a small flat tip screwdriver, and place a drop on both sides of the wheel that is sticking.
Enter all 8888888888's again, and keep hitting the + and see if it gets any better or starts to move.
If the wheel doesnt turn at all, then the solenoid might be stuck and it will be a lot harder to reach to service it.
Nov 18, 2006 | Monroe 7130 Calculator
SanDisk Sansa e250 MP3 Player Logo
47 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Mohamed Ismail
Mohamed Ismail
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
