Question about Zenith H20F50DT TV
Volume control On page 33, the manual says or I understand it to say that I can program the maximum level of the volume. I have pressed the adjust button for 8 seconds, etc. and I still can't figure it out. Can I do this. As we have it in our medical center, there are alot of people who are starting to complain that the volume is too load. We try to control this with communication, but we need to do something more proactive. Is there a way to program a maximum volume, if so, how????
4 Suggested Answers
darjr
  • 379 Answers
SOURCE: Volume control doesn't work on Grundig t 55-640
Some TV has a hotel mode, try checking in Menu maybe your TV is in Hotel mode thus preventing you to maximize the sound or volume.
Posted on Jun 01, 2009
buechler
  • 3 Answers
SOURCE: How do I unlock the volume control?
I found this solution to my similar problem:
http://www.fixya.com/support/t399335-zenith_tv_wont_unlock
(solution #3 ... hold down the menu button on the tv set itself until the menu goes away... then hit 9-8-7-6-ENTER on the remote to enter the [probably very dangerous] service menu... you can use the select button on the set itself to "scroll" through the semi-cryptic options... the min and max volume options were pretty clear)
Posted on Jul 24, 2009
gopakumarg43
  • 76001 Answers
SOURCE: No Volume. Mute is not on. Volume control is at
Hello
If there is no volume in your TV, and mute fuction si in off position, and the picture is ok. there are two possibilities. The first one is, speaker of your TV is damaged. The second one is audio output Ic in your TVs inner circut board failed.
You just open your TV taking after every prcautions when we take before working with an electrical equipment. Keep children away from you, and let an adult beside you. Plug out your TVs mains chord out of wall socket, and never use a matal chair or a chair fabricated with metal. Do wear a rubber or plastic shoes, and not try to work with bare foot.
At first be sure whether the speaker is out or not. It can be tested without opening your TV. I suggests these, keeping in mind that your TVs picture is Ok. If not the problem may differ. Keep your ear very near to the speaker side of your TV, and swith it on with mains supply, and listen there is any sound or just a "thumb" sound is heard from the speaker. If there is no "thumb" sound, surely the speaker is damaged. Replacing it with same type and impedence [ie 4 ohms, 8ohms, 16ohms etc, will be marked on its magnet], will solve your problem.
If there is no sign or any sound, or just a "Hum' sound is prodced, the audio output Ic of your TV is damaged, or it is not getting the proper supply voltage to the respective supply pin. If there is a "Hum' sound produced from speaker, it is clear that your TVs audio Ic gets voltage, but it has damaged.
To repace it, you just follow, the two wires to your TVs speaker. It will go to the main board of a sub board which audio Ic is fitted. Normally this Ic will be screwed into a metal heatsink to runout the heat generated from it while working. Just desoder it, unscrew and take it out. Go for the same type and number. "Insist on same type and number. never try to use any substitutions, as it may effect the quality of sound". Solder it to the point. That is all.
Wish you success
If you have any further doubts, report to Fixya. They will send me alerts. Ok
Posted on Oct 22, 2010
How do you turn the ringer on/off on aatt 993 2 line phone
If you mean the AT&T 993 two-line speakerphone, you can adjust the ringer volume for each line when the phone is not in use. To increase the ringer volume on the primary line (if set), press the Volume Up arrow. To decrease the ringer volume, press the down arrow. There are 8 different volume levels available for the ringer. The Volume Up/Down buttons are below the * and 0 keys.
To adjust the ringer volume on the secondary line, press that line button (between the Conference and Hold buttons) and then press the Volume Up or Down buttons as needed. (If you haven't programmed a primary line, press a Line button and adjust that line's ring volume before pressing the other Line button. Then adjust the volume for that Line.)
I hope this helps. These directions are shown on page 32 of the manual. AT&T currently has the manual here : https://att.vtp-media.com/ecp/documents/product_Product/227/UserManual/5596/993_manual_i14.pdf . To find this manual or other AT&T phone manuals, start here: https://telephones.att.com/product-support/manuals .
Mar 27, 2018 | Lands Phones
MY POWER MAX 5.8 SAYS THAT MY VOLUME IS OFF ON ONE HAND SET--HOW DO I TURN IT ON? THANKS EILEEN CARTER beileenc@bellsouth.net
There are different ways to adjust the ringer and speaker volume on your handset. Please see your owners manual for model specific instructions.
On most single handset units:
Ringer volume: Press the volume up or down arrow rapidly to change the ringer volume.
Speaker volume: When talking on the handset press the volume up and down arrow to increase or decrease the volume.
On other models:
Ringer volume
In standby mode, press the volume up key or volume
down key on the handset or base to select one of three
ringer volume (Off, Low, or High).
Earpiece and Speaker Volume
You can select from among of six volume levels on the
handset, and ten levels on the base. Pressing the
volume up key or volume down key on the handset or
base during a call will change the earpiece or speaker
volume. This setting will remain in effect after the
telephone call has ended.
If you press the volume up key when the earpiece is at
the maximum volume level, an error tone sounds.
The error tone also sounds if you press the volume down key at the lowest volume.
Sergio
Mar 13, 2008 | Lands Phones
Tip
DISH VIP612 Amplifier Control
DISH Solo DVR VIP612 Amplifier / Receiver Control
Would you like to program the Universal Remote that came with your Dish Solo DVR VIP 612 to control the volume of your receiver, tuner, or stereo instead of your TV's volume?
The first step in using the Universal Remote Control that came with your Dish Solo DVR VIP 612 to control the volume level of your receiver, tuner, or stereo is to program the remote to control your audio device using the AUX mode button.
Once your remote controls your audio device in AUX mode, you probably want to continue to control the volume of your stereo even if the remote is in SAT, TV or VCR mode.
To setup your Dish Solo DVR VIP 612 Universal Remote to control the volume of your stereo regardless of which mode it is in, follow these steps:
  1. Press and hold the AUX button until all the mode buttons are lit, and then let it go.
  2. Press the POUND (#) button.
  3. Press the PLUS side of the VOLUME button.
  4. Press 0.
  5. Press the POUND (#) button. The AUX button flashes three times to tell you the programming is complete.
  6. Confirm the VOLUME buttons are operating the tuner/amplifier's volume control by pressing SAT or TV, and then adjusting the volume. Your tuner/amplifier's volume should change rather than your TV's volume.
Your Dish Solo DVR VIP 612 Universal Remote is now setup to control the volume of your stereo regardless of which mode it is in
I hope that helps.
________________________________________________________________
DISH Solo DVR VIP612 Manual Download
DISH Solo DVR VIP612 Quick Reference Download
DISH Solo DVR VIP612 Remote Code Scan
DISH Solo DVR VIP612 Program TV VCR Remote Codes
DISH Solo DVR VIP612 Program AUX (Stereo/Receiver) Remote Codes
DISH Solo DVR VIP612 Amplifier Control
DISH Solo DVR VIP612 What Is Limited Mode
DISH Solo DVR VIP612 Change Limited Mode
on Jul 05, 2010 | Televison & Video
In my gr 33 the volume is very low. mistakenly i did a factory reset after that the volume is becomes very very low. Any solution for this problem?
There is probably both a global volume and individual program violume as well. One or both may have reset to a lower level and need to be turned up. It's also possible that the general output has a setting for line level or instrument level, which may be software controlled. Take a look through your manual to find these settings and adjust to suit.If all else fails, contact Roland Customer Service at this link for help.
Roland Company Contact Us Contact Us
Sep 15, 2016 | Roland Gr33 Guitar Synthesizer
Remove lock from volume setting
Limit the volume Listening to loud sounds for longer than a moment can be harmful to the listener. You can set the volume level of the player to suit your preferences: 1 From the main menu, select Settings > Sound settings > Volume limit > Settings. 2 Press Vol- or Vol+ to adjust the level. 3 Press to set. > When you set a volume limit, you can no longer exceed the set volume, even if you press the Vol+ button. To enable maximum volume again, set the volume limit back to maximum or turn off, select Settings > Sound settings > Volume limit > Off.
Thanks for rating Good luck
Dec 22, 2010 | Philips Audio Players & Recorders
My Slice phone no longer rings out loud or vibrates when a call comes in. How do I restore those settings?
Check out this link for a PDF manual for your phone. Just copy and paste into your browser.
http://safemanuals.com/user-guide-instructions-owner-manual/UTSTARCOM/PCS1400-_E
I got this info off of page 60 from your manual.
CUSTOMIZING YOUR PHONE VOLUME
Control the volume for Ringtone, Speakerphone, Headset, and Advanced settings.
Ringtone
Set ringtone volume and incoming call alert options:
1. Press [Menu], then press "Settings".
Press "Sounds", then press "Volume".
2. Press "Ringtone".
3. Press / to adjust the volume level. Press to select Vibrate when High is the volume level.
The volume settings available are:
• Silence all: All sounds are off.
• Vibrate : Phone will vibrate to alert you of incoming call or message.
• Off: Only the ringtone is muted.
• Ringtone mode: Low, Medium, High.
Tip • You can adjust the ringtone volume with the side keys.
Hope this helps. Let me know if I can help you with anything else.
JimmyC
Oct 05, 2009 | UTStarcom PCS1400 Cellular Phone
Subwoofer amplifier
Here's how I'd do it... connect the subwoofer pre-out to one of the unused analog inputs (CD or CD-R perhaps?). Turn on Zone 2 by pressing the MULTI-ZONE ON/OFF button. The MULTI-ZONE indicator will light.
Press CONTROL. (Zone 2 should display) Use the INPUT SELECTOR dial to select the source for the zone you have selected. In my example, CD or CD-R.
Of course, you'll need the sub hooked up to the Surround back speaker terminals.
Here's a link to the manual online:
Pioneer VSX-1018 Manual
Things to keep in mind:
The Surround Back setting must be set to ZONE 2. See page 41 of the manual.
The volume level going to the sub will probably need some tweaking. Check out page 7 to see how to manually adjust volume levels, or get it close by adjusting the Master Volume while in Zone 2 control.
I'm not sure if the auto setup function (with the included microphone) will work properly with this setup. And, of course, this is not a "suggested" setup by Pioneer, so please use caution when hooking everything up.
Apr 21, 2009 | Audio Players & Recorders
Adjusting TV Volume
Hi Joe,
If you do not have it available, you can access the user guide for this product at http://www.zenithservice.com.
Page 29 should be the beginning of instructions on using the installer remote. Reference the chart to find the menu line for start channel/volume. Depending on your set, this may be on line 10 or 11. You also may find options for minimum or maximum volume, as well as many other settings using this chart.
The next page gives specific information concerning this feature. The number you enter into this menu line determines the channel (with 0 being Aux and 255 turning the feature off). Volume is determined by actually setting the volume when on this menu line.
Hope this helps,
Jason,
Go Ahead. Use Us.
Jul 31, 2008 | Televison & Video
Multi-zone volume levels --not adjustable (too high!)
Press the reciever button on tyhe remote until it say Multi in the display. You can now adjust the multi zone volume level.
Jul 18, 2008 | Denon AVR-3802 Receiver
GN Netcom wireless headset volume adjustment
Transmit volume adjustment
Adjust the volume of transmitted sound according to personal preference.
To adjust the volume:
1. Make a telephone call and ask the person you are calling to assist
you.
2. Press the +/– buttons on the headset simultaneously for 2 seconds.
A beep will indicate when 2 seconds has passed.
3. Adjust the volume level by pressing the + or – button.
4. When the person you are speaking with fi nds the volume of your
voice appropriate, press the +/– buttons simultaneously for 2
seconds. This setting is now stored in the headset.
A Copy of the manual is avaliable at:
http://www.onedirect.es/files/GN%20Netcom-ES/GN%20Netcom%209120%20manual.pdf
You must have Adobe Reader to view it and the instructions are on page PDF page 3 or manual page 6. Adobe Reader is avaliable for download at:
http://www.adobe.com/products/acrobat/readstep2.html
May 21, 2008 | GN Netcom (9120-48) Wireless Headset
Zenith H20F50DT TV Logo
Top Zenith Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
