Question about iRiver H320 MP3 Player
My power supply port is broken, i have soldered it together several times but it just keeps breaking over and over again, i cant find any replacement boards for the iriver h320, other than that it works fantastic
    Problem Solver:
  • 5 Answers
Found a used not working player on ebay for $5.00 and just soldered the good power port where the bad power port was...
Posted on Nov 14, 2008
My sharp Aquos LCD TV LC37D44U while watching TV suddenly witched off. Both the power led light and the OPC led light together started to flash twice, and then only the OPC led light three times, then...
Your power supply board is dead, u know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Hope this help in solving the problem......
Jan 27, 2011 | Televison & Video
Turn tv on green light flashes several time thengoes off. then red light flashes several times then entire tv goes off . no picture from begining to end of this cycle
I hope this help in solving the problem....
Dec 29, 2010 | Televison & Video
LG 32" Plasma TV power-on problem
Your power supply board is dead, u know basic electronics’ and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
hope this helps...
Jul 02, 2010 | Panasonic TH-42PWD6UY 42 in. HD-Ready...
When I turn it on I get a constant beeep noise
Check the cable harness that flexes as the carriage moves left to right, on older models the wires could sometimes break..it might be as many as 2 or three of them broken.
Soldering back together is only a temporary fix as the soldered joint WILL break again due to the flexing action.
Only sure repair is to replace the complete carriage assbly with harness,
but its cheaper than buying a new machine.
Mar 02, 2010 | Nakajima AE-740 Typewriter
No picture only sound
Take a flashlight and shine it on the screen. Do you see the picture?
If you do then your backlight portion of the power supply is broken.
You will need someone who can disassemble the tv and take a look at the power supply. Look for obvious things like swollen or leaking capacitors or breaks on the soldering connections.
With the caps replaced and/or the board breaks fixed you should be running again.
Good luck and be careful.
Feb 12, 2010 | Polaroid FLM-3734B 37 in. LCD HDTV
Driver's door control panel doesn't work when door is open
Hi my name is Allen!
There is a ground wire that breaks between the door and the body, its inside of the rubber protector. If you peel the rubber from the door side you will find the ground wire broken.
NOTE: do not try to repair the wire at the break, because it will break again because of it bending at that location.
REPAIR: remove the kick panel trim and run a new wire from the inside out to the break, this will repair it for a long time. You must solder and heatshrink the wires together to keep moisture out of the repairs.
For further assistance contact me at FixYa!
Jan 19, 2009 | 2004 Jeep Grand Cherokee
Problems with Magellan Maestro? 4040 GPS power connection
this is a very common problem with these magellan 3140 and als the 3100,2000,2200t,2500,4000,4040 and the 4050most likely the power port is damaged and needs replaced.i have these power ports but often they just need re soldered..i can repair these magellan gps if you need help. if i cant fix it there is no charge.wmetz@comcast.net ...to open the case on a 4040 you must start on the power button side, otherwise youll break the unit
Dec 16, 2008 | Magellan Maestro 4040 GPS Receiver
Broken-off power connector
most likely the power port is damaged and needs replaced.i repair those magellan gps if you need help. if i cant fix it there isno charge. wmetz@comcast.netto open the case on a 4040 you must start on the power button side, otherwise youll break the unit
Nov 05, 2008 | Magellan Maestro 4040 GPS Receiver
Ice 2as01 is broken again
Resolder diodes D903 and D906 in the secondary of power supply. The diodes are the two mounted to a heatsink. These are the reason the 2AS01 goes out in the first place. The solder joints on these two diodes breaks loose. If you don't solder them, the 2AS01 will go out again.
Aug 04, 2008 | Dell UltraSharp 1800FP 18.1" LCD Flat...
Intermitent problem
yes, the coil's copper wire is broken and making connection just "by chance luck" of being close in proximity. I have actually soldered these breaks, and yes your's can be soldered if the break is clearly visible after sufficient disassembly of coil area. Remember to use emory cloth near the break ends to remove the factory winding varnish and to "tin" the copper ends before they are soldered together. Finish with a good epoxy to bind the repair to eliminate "floating" which may re-break the wires.
Jun 14, 2007 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
iRiver H320 MP3 Player Logo
35 people viewed this question
Top iRiver Audio Players & Recorders Experts
Steven Wander
Steven Wander
Mohamed Ismail
Mohamed Ismail
Are you an iRiver Audio Player and Recorder Expert? Answer questions, earn points and help others
