Question about Dell 946 All-In-One InkJet Printer
I do not know how to the put the paper into the printer
The computer is set up but i do not know how to put the paper in correctly
    Genius:
  • 1,605 Answers
1). fan the paper
2). there is a paper tray under neath the conrol panel. flip up the cover, pull out the extender.
insert the paper short side in (8 1/2 x 11)
3).squeeze the slide paper guides on the side of the paper tray rest against the edges of the paper.
4).puhs in the paper entender, lower the tray cover.
5). entend the paper exit tray stop on top of the paper tray tocatch the paper as it exits.
Posted on Nov 13, 2008
My Star TSP600 Thermal Printer is displaying a flashing Error light. Power light on, new roll of paper loaded correctly, self-test was ineffective - nothing printed. What's my next step?
i know you stated you put the paper in correctlyin the printer but if the thermal reactive side of the paper is not facing the print head the thermal paper won't print on the wrong side of the paper. it will load into the printer and seem ok but the heat on the wrong side of the paper will not react and show any writing. Can you try turning the paper over in the printer feed holder so the other side of the paper faces the print head and give it another test .
Jun 21, 2016 | Star Micronics TSP600 Thermal Printer
Universal paper size lexmark
Please check the paper size settings on the Printing Preferences option of the printer. To access this on your computer, to go Start > Devices and Printers (Printers folder) > right click the printer icon and then choose Printing Preferences. Set the Paper Size to the desired paper size. Please also make sure the paper guides on the printer is selected to the correct paper size.
Dec 15, 2012 | Lexmark E260dn Laser Printer
Bizhub c200 giving message put paper in bypass tray
Check your default paper settings in your setup menu. Also, check the paper size is set correctly on you paper trays for the type of paper that is in them. Make sure that the documents that you are printing are set to proper paper size that is in your printer. All the issues, will cause this condition plus some. But those are the easiest, let me know if it continues. Good Luck
Jun 04, 2012 | Minolta bizhub 200 All-In-One Printer
Printer starts to print but the paper jams as if it shifts to one side.
Check your printer settings
(start>control panel>printer>right click this printer>printer preferences>paper quality>choose correct paper and size>click ok or done and close)
to be sure it is set for the same size and type of paper that you are using.
If it is set correctly, then there may be a tiny piece of paper lodged somewhere, or perhaps s small object such as a staple or paperclip.
Look in all areas that you possibly can . You could also try blowing the areas out with a little computer blower/cleaning tool. Be very careful if you do this/and remove the cartridges first. DO NOT USE HEAT.
Make sure that you secure the paper in the machine with the sizing mechanisms as well and that you fan the paper before you put it in. Place it neatly and snugly in the tray.
If you cannot get it to work, try opening up the printer paper jam door and pushing the printer roller up until it clicks. this will reset the printer and may release debris.
You can also try printing on smaller paper to see if you can get any paper through correctly and help clear a small jam. Again be sure to adjust your printer settings to the size you are using.
As a last resort, if nothing else works, perhaps the printer is stuck on an old paper setting. You can reset the printer by turning it off and unplugging it from the computer, waiting a few minutes and then plugging it back in and turning it on. give it plenty of time to go through its normal start up cycle before you try to print again.
Dec 20, 2010 | Dell 924 Photo All-In-One Printer
Photo Paper keeps jamming
It's the top rollers, the paper is too slick to get through them. I'm using HP photo paper, in an HP printer. It needs to do a 180, but gets jammed right where it prints, so the paper never makes it to the ink. It's an engineering problem by HP. I suggest putting a rough surface on the top edge of the photo paper, something removable but rough enough for the printer to pull the photo paper through.
Jul 12, 2010 | HP Officejet 6310 All-In-One InkJet...
A3 prints - printing on A4 - Ricoh C4500. When users print to our Ricoh C4500 using RPCS the print comes out as a cut off A4 print, so it does not seem to be detecting the fact that it is needing to use...
Enter on the computer the follow path:
1. enter start menu
2. enter printers and faxes
3. enter by right click into properties
4. enter paper size settings
5. set the paper size for the tray or trays and press update then apply and ok
after thet it will work
Also see on the printer menu enter the same paper tray settings and set the trays by size but more important is to set the compute settings
Jul 08, 2009 | Ricoh Aficio SP C410DN Laser Printer
Keeps popping up "paper source setting not set properly"
I'm guessing (wildly) that the printer is an R2400 (although there's no guarantee of that it seems :) )...
Anyway, the problem is most likely to be in the printer driver settings used on your computer.
You need to go to:
- Start
- Printers & Faxes
- Locate your printer
- Right click on the printer and choose "printer preferences"
From here you need to ensure that all your settings for paper size, etc... are correct.
You also need to ensure that whatever you're actually printing has the correct page setup using the same paper size.
Hopefully that will correct your problem.
Feb 14, 2009 | Epson Stylus Photo R2400 InkJet Printer
Printer will not print, keeps rejecting paper saying it is too narrow. the paper is the correct size. i nee help immediately please
OK there is three places you have to check for correct papersize,-
1)In the settings on the machine
2)On the driver of the printer ,ON your computer -Start,Control panel,Printers and faxes,Right click on driver- Properties,Then you enter the correct paper size.
3)In the page setup in the program you are printing from.File, page setup,set the correct paper size.
Normaly the settings for 1and 2 you enter once and it stays there ,except if some one change it.
Every program have it's own paper size defauld settings.Check them before you print.
Let me Know
Nov 06, 2008 | HP Office Equipment & Supplies
Paper wont load
Please check the following items:
Check item 1:
The cable may not be securely connected between a printer and a computer, or be about to be unconnected.
Check that the cable is securely inserted into the ports of the printer and the computer respectively.
If a USB hub is used, connect the printer and the computer directly.
Check item 2:
Print jobs may be queued.
Delete the print jobs queued in the computer. How to delete the accumulated and queued documents in the computer (Windows)
Check item 3:
The computer settings may not be corrected.
Check the computer settings. How to confirm the computer settings (Windows)
Jan 14, 2008 | Canon PIXMA iP90 Mobile Printer
My printer display incorrect paper size and stop printing
Try checking that the paper size settings in your printer driver ar set to either 'AUTO' or to the paper size that is being fed thru the printer. Let me know?
Nov 22, 2007 | Canon imageCLASS D320 Digital Copier
Dell 946 All-In-One InkJet Printer Logo
77 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
