Question about Electrical Supplies
Samsong syncmaster 920 nw
When I turn pc on, everything seems to be working as usual and after 4 or 5 minutes monitor goes blank. I turn monitor...
  • bagvananand Jan 09, 2009
    4 or 5 minutes is better, in my computer monitor turned on for only 2 secs, but monitor light is keep glowing. Again I have to turn off and on, then it willl be on for just 2 secs. If some one have solution for similar problem, please provide, that would be so helpful. Thanks.
    This monirtor is connected to DELL Dimenstion E520.
    Anand
  • Rafique Mannasaheb May 11, 2010
    This may be a backlite problem. You may have to replace the panel.
The problem is the power supply, but of the monitor. You need replace it. This is a common problem in some LCD screen as Samsung and Viewsonic.
Posted on Sep 05, 2009
  • 36 Answers
Replace the power supply to the pc if the fan is not working it could be overheating and causing it to shut down.
Posted on Feb 13, 2009
Monitor keeps showing "Check signal cable"
Well, at least you got it sorted out and everything is working fine now.
Apr 21, 2012 | Samsung SyncMaster 2493HM Monitor
Video
this is the problem with monitor only sir.
please claim your warranty
Jul 28, 2008 | Samsung SyncMaster 920NW Monitor
I have installed Windows 7 in my Pc with the monitor Sync Master 920 NW and the maximum resolution available 1280 X 768 when the max resolution of the monitor is 1440 x 1024.
Download the correct graphics driver.
If you have a Graphics card, download the driver from either Nvidia or ATI.
If your graphics chip is on the motherboard, download the driver from your manufacturers support page
Aug 05, 2010 | Samsung SyncMaster 920NW Monitor
My samsung syncmaster 920nw picuture goes blank after a period of a couple of minutes. If I turn the power off and then back on the picture re-appears but goes off again. It is not he pc since it works...
If you get a flashing screen which show your screen for few minutes and then goes blank it may be an issue with the Monitor.
Try to restart the computer and go to BIOS setup screen. If you experience the same issue in BIOS then the monitor needs a repair or replacement for sure.
Jul 19, 2010 | Samsung SyncMaster 920NW Monitor
Moritor turn off after 3 second
problem with power supply circuit or inverter and ccfl lamps..
May 17, 2010 | Samsung SyncMaster 920NW Monitor
Syncmaster 920 nw lcd monitor dispaly problem
sounds like your having pixel issues I would advice calling up samsung and checking there pixel policy if it is out of range they will need to replace it
Dec 16, 2009 | Samsung SyncMaster 931B 19" LCD Monitor
When monitor power button is pressed, a small white image appears and alternates briefly between an alalog and digital icon in black then the screen goes blank, no color.
My issue is similar.. however after trying a couple of times it will work. (yes everything is plugged in) It will function for a good 10 minutes before just powering off (blackout) screen.
If you attempt to turn it on after it blacking out, the blue led for the power button will blink a couple of times and it will remain off.
However if you wait 5-10 minutes and turn it back on, it will repeat itself...
I have it hooked up to a radeon X1650 graphics controller as a secondary digital controller, and its hooked up by VGA cable.
I also have two other displays besides this one (one primary and extended that dont have any issues whatsoever.. they continue to function while the syncmaster 193p takes its time snoozing.... please help.
Mar 17, 2009 | Samsung SyncMaster 193P 19" LCD Monitor
Samsung 204B random blank screen
I too have a dual monitor Samsung SyncMaster 204 setup. My monitors started flickering, then a week later had turn on problems like your describe. I found a fix on this fixya website and followed the fairly techie suggestion. It worked. I wrote up a .pdf set of instructions so others might also benefit. Hope this helps. Doug
Feb 07, 2009 | Samsung SyncMaster 204B 20.1" LCD Monitor
Acer AL1711 17" LCD Monitor goes blank without warning
The need to reboot your computer to get your monitor working places the blame totally in the computer. You have a virus, or the computer is overheating and shutting down for thermal reasons.
-CharlyV
Jan 26, 2008 | Acer AL1711 17" LCD Monitor
Electrical Supplies Logo
152 people viewed this question
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
