Question about Casio Parts Cash Register PC Desktop
Output tape ink is fine in the X and Z mode, but . . . . . . .
No print shows on the tape and it does not feed in the REG mode.
  • 737 Answers
I've never had an issue with printing only in certain modes. If the feed button doesn't work either in certain modes, then I waould say you have either a damaged mode switch (under the key), or a faulty keyboard. If any liquid has been spilt on it, this sort of issue can arise.
Mark
Posted on Nov 14, 2008
When i refill toner it still show toner low.how sovle the problem
Good day.
First try to print a print status report. Here are the steps:
1.Push setup menu button, that would be the wrench icon. 2.Push the right button to navigate until you get to the Tools Menu 3.Tools Menu>Push button for Printer Status Report
This will give you the accurate ink levels on your printer. If it still shows low ink based on the printer status report, you have to reseat the ink cartridge and make sure the orange tape near the HP Logo on the ink cartridge has been peeled off.
If the report shows ink levels are fine, then that status report on the front panel is just a false report. Try powering off your printer and powering it back on again. As long as you don't have print quality issues, you should be fine.
Jun 20, 2011 | HP LaserJet CP1515n Printer
E004 Error INIT/FC
You need to finish the flag clear.
Turn key to PROGRAM mode. Turn power off at wall. Hold RECEIPT FEED down - keep your finger on it. Turn power on at wall. Wait 5 seconds, then let go of RECEIPT FEED. You should see "FFFFFFFFFF" on display. Press SUBTOTAL. Wait for print out. Turn back to REG mode (you may need to sign back on)
Feb 28, 2011 | Casio Parts Cash Register PC Desktop
My canon pixma ip1300 is showing service error 5100, not printing and yellow light blinks five times thanks in advance..........
Solution: Install the print head and ink tanks correctly iP3000 / i560
Seat the print head Below is the procedure for seating the print head and ink tanks:
  1. Power on the printer.
  2. Open the paper output tray and top cover.
    Note: Gently open the paper output tray while holding it.
  3. After confirming that the print head holder has moved to the center, open the inner cover.
  4. Remove the orange tape securing the print head lock lever, and raise the print head lock lever.
    Note: If the top cover is left open for more than 10 minutes, the print head holder will move to the right. If this occurs, close the top cover once and then re-open it.
  5. Remove the print head from its package and remove the orange protective cap.
    <1> Electrical Contacts and Print Head Face's Nozzle Area
    <2> Ink Supply Filters
    Note: To avoid any damage, do not touch the print head face's nozzle area, electrical contacts, and ink supply filters. After removing the protective cap, set the print head into the print head holder immediately. Do not re-attach the protective cap after it has been removed.
  6. Set the print head into the print head holder, and lower the print head lock lever until a click sound is made.
    Next, install the ink tanks.
  7. Remove the cyan ink tank (BCI-6C) from its package. Pull the orange tape in the direction of the arrow to remove the wrap film completely.
    Note: Remove the orange tape completely. If the orange tape is not completely removed, it may interfere with printing.
    <1> Removed correctly
    <2> Removed incorrectly
  8. Hold the ink tank as shown in the image below. Twist the orange protective cap in the direction of the arrow, and remove it.
    Note: Remove the protective cap while holding it, so that fingers will not be stained by the ink.
  9. Insert the ink tank into the slot at the right end, and push down on the PUSH mark on top of the ink tank until a click sound is made. Install the other ink tanks in the same manner.
  10. Close the inner cover and top cover.
    Note: Check that each ink tank is installed in the correct position:
    Properly installed:
    Improperly installed:
    <Left Image> The M ink tank is not fully seated.
    <Right Image> All ink tanks are not fully seated.
Dec 03, 2010 | Canon PIXMA iP1300 Printer
Bottom plate shows leaking ink
If the bottom plate shows leaking ink
1) Cause : Inside of the machine is dirty, printed paper may be smudged.
Action :
a) Press[ON/OFF] to turn on the machine, then remove any paper from the Autosheet Feeder and Cassette.
b) Press the Open Button to open the Paper Output Tray, and open up amd set the extension by pressing down the hollow on the front side.
c) Place the only one sheet of A4/ Letter-size plain paper in landscape, horizontally fol it in half.
d) Unfold the paper, and load the paper in the Auto Sheet Feeder with the inverted-V edge down.
e) Use right /left arrows to select <BOTTOM CLEANING< from the <MAINTENACE> and press<OK>.
The paper that is loaded in the machine will feed through the machine and be ejected.
If protrusions inside the machine are stained, wipe off the protrusions using a swab or the like.
Important: Before cleaning, be sure to turn off the machine.
3) Cause :Inapproprite media type is used.
* Check to see if the paper you are printing on is too thick or curled.
* Note that smudging may occur at the top and bootm edges of the paper when using Borderless Printing. Ensure that the paper you are using is compatible with Borderless printing.
Refer to the Printer Driver Guide.
Hope this helps. PLease rate my response.
Thanks
Have a good day.
2) Cause : Paper Feed Roller is dirty.
Action : Follow the steps to Clean the Paper Feed Rollers.
Cleaning the Paper Feed Rollers consumes time , so perform this procedure only when neccessary.
A) Press[ON/OFF] to turn on the machine, then remove any paper from the Autosheet Feeder and Cassette.
b) Use [Feed Switch] to select the paper source to clean.
c) Use right and left arrow keys to select <Roller Cleaning> from tbhe <Maintainnace> and press<ok>.
The Paper Feed Roller will rotate as it cleans.
d) Repeat steps c) 2 times.
e) Press the Open button to open the Paper Output Tray, and then open up and set the Paper Output Tray Extension completely by pressing down the hollow on the front side.
f) Load three or more sheets of A4/Letter-sized plain paper lengthways in the paper source you selected in step b.
g) Repeat step c) 3 times.
The paper that is loaded in the machine will feed tthrough the machineand be ejected
If there is not signes of imporvement after performing 3 times, contact the Canon Customer Care Center.
Nov 27, 2009 | Canon PIXMA MP530 All-In-One InkJet...
Cannot read #'s on cash reg. tape
Many times its not easy to seat the inker. Also these machines have 2 rubber type wheels that will harden if the inker is not changed often enough. Also some people use thermal paper in these machines and that is not good either. if you are using thermal paper try using standard 21/4" adding machine paper. The type wheels may also be filled with glonck. you also may have bad inker. if the are crumbly they wont work
Sep 21, 2009 | Casio Parts Cash Register PC Desktop
I had a paper jam and got the paper out but still shows E2
E2-2 = No paper (ASF)
E22 = Carriage error
E23 = Paper feed error
E24 = Purge unit error (bagian cleaning head)
E25 = ASF(cam) sensor error
E26 = Internal temperature rise error
E27 = ink absorber full or platen waste ink absorber full > reset dengan toolsnya
E28 = Ink cartridge temperature rise error -
E29 = EEPROM error
which error message exactly your printe show?
Sep 13, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Deskjet 990Cse
Are you sure the plastic tape has been removed from the cartridges?
Jun 06, 2009 | Apple HP DeskJet 990cse InkJet Printer
The ink tape return reel won't turn to take up the used ribbon
Try to turn the wheel manually and see if it turns properly. There must be a belt or gear assembly which turns both reels simultaneously. If its a belt, check to see if its broken.
Jun 04, 2009 | Intermec EasyCoder F4 Printer
Acts like it's printing, ink is good, but nothing prints out on paper.
Have you removed the tear off tape from top of cartridges, it lets the air in and ink flows.
May 28, 2009 | Epson Stylus CX6400 All-In-One InkJet...
Our Casio PCR-T265 will not print or feed in the REG mode but. .
Mark
Nov 13, 2008 | Casio Parts Cash Register PC Desktop
Casio Parts Cash Register PC Desktop Logo
Top Casio Retail Supplies Experts
Electroboy
Electroboy
jackcity
jackcity
Level 1 Expert
Are you a Casio Retail Supply Expert? Answer questions, earn points and help others
