Question about Canon PIXMA MP600 all-In-One InkJet Printer
No paper feed Canon ink jet printer won't feed paper and Alarm light comes on. The message is Service Code 6000, which is not a code in my manual. Anyone know what I should try? I have tried loading and unloading, unplugging and replugging, resetting, and even turning it upside down and blowing out the dust. The problem doesn't go away. I cannot find a jam. Puzzled
  • Canon Master
  • 1,879 Answers
  • Canon Master
  • 19,396 Answers
Try first unplugging power cord for five minutes, sometimes this can reset the error code.
Posted on Nov 13, 2008
  • Canon Master
  • 13,433 Answers
If there is no jam then unfortunately, the issue you describe seems to indicate that your product requires repair service. If you feel your product might require service, a Canon Technical Support Representative will be happy to answer any questions you may have and explain the service options available to you. You can contact Canon through the email link or phone numbers listed below.
If your printer is no longer under warranty :
  • For toll-free technical support*, please call 1 (800) 828-4040 during regular business hours (currently Monday-Friday 10:00 a.m. - 10:00 p.m. EST, excluding holidays).
    *Pay for support is required on all units outside their original warranty, unless covered by a Canon Extended Service Plan. If it is determined that there is a hardware failure, you have the option to purchase a new or refurbished product from our current product line, which includes units with Canon?s new ChromaLife inks, PIXMA Technology, a limited manufacturer?s warranty, free next business day shipping and discounted pricing. If you elect to take this option, the pay for support charge will be canceled.
So we may better assist you, please make sure that you can access your Canon product and have the following information available when you call:
  • Product model name and serial number.
  • Computer's operating system; for example Windows XP.
  • Message displayed when the problem occurred.
  • Steps you've already done to try to solve the problem.
    President:
  • 624 Answers
The rollers and gears are wearing out, it will require service if you want it fixed but the price of a new printer would be much cheaper.
Turn on machine & alarm immediately comes on. Flashing check printer 6000.
Are the cartridges in working order. I had similar problem with another make of printer when printer lights kept flashing and one of the cartridges was defective.
Feb 26, 2014 | Canon PIXMA MP170 All-In-One InkJet...
Getting code 6000
Error code [6000] or light blinking 3 times.
1. Smearing or scratches on the LF encoder. Please clean the LF encoder.
2. Foreign material or paper debris in the LF drive. Please remove any foreign materials if encounter.
3. Check cable connection.
4. Replace LF encoder or Logic Board or Paper Feed Motor or Paper Feed Roller Unit
May 27, 2010 | Canon PIXMA MP620 All-In-One InkJet...
My pixma IP1980 ahs an error and the green at orange lights blink alternately. error code is 6000.. pleasehelpme...
Error code 6000 mean line feed error. Possible problems in:
- Timing sensor unit
- Timing **** disk film
- Feed roller assembly
- Platen unit
- Logic board assembly
- PAPER FEED MOTOR
Oct 06, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
Need trouble code for selphy ds810 trouble code is 6000 or where can i get all of them
Error 6000 is a paper feed error, something may be inside stopping the feed rollers from turning, otherwise it could be ink on the paper feed sensors. If you can't see something inside like a paper clip or something else that doesn't belong, I would reccomend shop repair.
Jun 22, 2009 | Canon SELPHY DS810 InkJet Photo Printer
Canon Pixma 210 series has an error code 6000, won't print or scan
Hope this helps
With thanks to a canon tech
Ok Well again I will repeat this answer with a titch more detail.
The 6A00 is a Canon generic code for paper path jam. Some where in the paper path a sensor is activated indicating paper jam so the printer will give off a 6A00 code. As a Canon tech, I usually find the code, almost 90% of the time, is related to the purge unit being jammed with something and not being able to move. Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like. And yes I have found all those things in a purge unit. The offending item needs to be removed or the purge unit needs replacement. A Pixma MP830 would still be under Canon warranty, get it into a shop and save yourself the hassel.
Incidently, the 6A00 error pertains to all Canon printers made in the last several years, its not just used in one model. And its always a paper path error or purge unit.
I forget myself so here goes, the purge unit, called a spittoon assembly in an HP, lexmark, and other inkjet printers, is where the print head assembly parks when not in use, also its other job is to clean and make sure the print head is clean and open for printing. That is why you'll find the print head assembly parked on top of it. It also has a an electrical pump to milk the print heads and test for ink flow.
Procedure to reset Printer canon MP145 and Canon MP160 with Error Code Message for Printer Canon MP145 and Canon MP160, you can find error code message the end of this post:
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding the Stop/ Reset button.
2) When the Power is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a service mode. (Waiting for menu selection)
4) When the on/off lights in green, press the Stop/Reset button the specified number of time(s) according to the function listed in the table below.(Each time the Stop/Reset button is pressed, the LED lights alternately in orange and green, starting with orange.)note: press 4 times for waste ink counter reset.
The number of the Reset
button pressing
LED Function Remarks
0 time Green Power off
1 time Orange Service pattern print
2 times Green EEPROM print
3 times Orange EEPROM reset
4 times Green Waste ink counter reset
5) Unplug cable power. (for MP145 / MP150)
6) Turn Off Power. (for MP160)
Error Code :
E2-2 = No paper (ASF)
E3-3 = Paper jam
E4 = No ink
E5-5 = The ink cartridges are not installed or a non-supported ink cartridge is installed, or the ink cartridges are not installed properly
E8 = Waste ink absorber full, or platen waste ink absorber full
E9 = The connected digital camera / video camera does not support Camera Direct Printing
E14 = The Ink cartridges whose destination are wrong
E15 = Ink cartridge is not installed E16 - Ink remaining is unknown
E16 -E19 = Failed to scan head alignment sheet
E22 = Carriage error
E23 = Paper feed error
E24 = Purge unit error
E25 = ASF(cam) sensor error
E26 = Internal temperature rise error
E27 = Waste ink absorber full or platen waste ink absorber full
E28 = Ink cartridge temperature rise error -
E29 = EEPROM error
E33 = Paper feed position error
E35 15 = USB Host VBUD overcurrent error - USB
E37 17 = Abnormal motor driver error
E40 20 = Other hardware error
E42 22 = Scanner error
May 22, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Error code 5010 and 5C20
on't know this error code, but this info might help
With thanks to a canon tech Ok Well again I will repeat this answer with a titch more detail.
button pressing
Error Code :
E3-3 = Paper jam
E4 = No ink
E29 = EEPROM error
May 14, 2009 | Canon PIXMA MP610 InkJet Printer
When the printer is turned on the following message occurs - 6000
The error code: 6000 is explained in the service manual as "Paper feed error".
It could be a sensor issue or something that's fallen down/into the printer that's jamming rollers or similar.
I'd check for any paper jams, foreign objects in the rear paper feed, etc..
Given that you have a MP540 I'm guessing it may still be in warranty so if that doesn't solve it I'd recommend taking it back to your retailer and getting it resolved.
Can I ask if this has done this since purchase or just started doing it?
Feb 19, 2009 | Canon PIXMA MP540 All-In-One InkJet...
Service error 6000
i have canon pixma ip1200, and I encountered the same problem with yours..SERVICE ERROR 6000, i tried to do a lot of things in my printer, i tried to Turn it on and off but it doesn't fix my problem, then I read that error came from, paper feed and roller..then i tried to pull and roll the soft plastic of the roller at the left side of the printer (if you're facing the printer, make sure the printer is off) then i notice that something's blocking the roller and then i turned the printer on and that's it..it works again, so far i've encountered the problem 2 times and i did the same procedure at the second time i encountered the problem.. I hope this will HELP you..;-)
Aug 03, 2007 | Canon PIXMA iP4200 InkJet Photo Printer
Canon PIXMA MP600 all-In-One InkJet Printer Logo
217 people viewed this question
old marine
old marine
