Question about Toro Lawn Mower With Toro Power Tools
Mower will not stay running - will run as long as you pump primer
Toro 22" 6.75 HP recycler self propelled mower will start but die as soon as the primer fuel is consumed. If you continue to pump, it will stay running. I dismantled to carb. -- checked the float and needle. It all seems to be working properly. I blew air thru the ports and all seemed clear. Somehow it is not getting fuel. Any thoughts?
Thanks,
Bill
  • billnkog Nov 13, 2008
    This is the Toro "GTS".
    Brigadier General:
  • 6,966 Answers
Initially, pls check:
  • all the fuel hoses and the air return to the tank;
  • depending on the model, pls determine/check the fuel pump (if present);
  • again, depending on the model, pls determine/check the vacuum hose from the carb/intake manifold to the fuel gate valve (if present);
  • pls check if the tank, valves, filters are clean and free from residue;
  • some models have small screen filter that gets clogged and would normally be located between tank and valve.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
Posted on Nov 13, 2008
  • Louie  Role
    Louie Role Nov 15, 2008
    Hi again,
    Any development(s) so far?
  • 19,396 Answers
Check the fuel filter, the fuel pump, and the carburetor.
  • Ginko
    Ginko Nov 13, 2008
    If you already checked the float and needle, and cleaned the carb filter, then the carb is done.
    Just ensure that the carb setup is done properly, and that engine is not just chocking because of a bad carburator settings.
    Check that the fuel pump is working, and pumping with enough pressure, and also that fuel lines are clear and fuel filter is fine. Some model has a double fuel pump (one near to the secondary fuel tank line) in that case this will explain why the machine runs only with primary fuel.
  • Ginko
    Ginko Nov 13, 2008
    Check also that the fuel line from the fuel tank is not clogged, and that there is no oxide at the bottom of the fuel tank.
    Here you get schematics for a Toro GTS.
We have a toro recycler 6.5 self propelled mower,pull startno primer,and took gas line off there was a fuel filter in the line?If it is can we replace it?
yes you can replace the filter but while you are in there it is a good idea to replace the fuel line also. usually on push mowers they don't have a in line fuel filter.
Apr 26, 2016 | Toro Garden
Have a self-starting, self propelled toro lawn mower about 5 years old, I ran it out of gas by accident & now it won't start
It seems to be an obstruction in your fuel delivery system. Get a can of ether and a spray a short burst of it into the breather area near the carburetor, if the mower starts up and then stalls out, then you may need to get your carburetor serviced.
Dec 18, 2013 | Toro Lawn Boy Self Propelled CARB Walk...
Toro self propelled lawn mower dies after an hour
maybe u have to much oil in it or there mite be a stone in the carberator or petrol tank thats blocking the petrol ?
Aug 07, 2012 | Toro Garden
ENGINE KEEP'S DIEING, PUSH PRIMER BULB AND STARS, BUT THEN DIES, IF I CONTINUE TO PUSH PRIMER BULB IT KEEPS RUNNING, BUT STOPS AS SOON AS STOP.TROY-BILT SELF PROPELLED MOWER MODEL E189- BRIGGS&...
Carburator issue. If you have some mechanical abilty you can pull the carb off else take it to a shop. You probably left gas in it off season. Either the main jet is clogged or the float valve is stuck. Either way, remove the carb, tae off the bottom cover and clean everything out with gum out or a carb cleaner. reassemble and eveything should be fine.
Jun 14, 2010 | Troy Bilt 5.5hp Self Propelled Mower
I have a 22 in Recycler Lawn Mower. I haven't had it 1 year yet. It is supposed to be self propelled but that quit being self propelled today. thank you in advance donna
turn it over and check the drive belt. it's probably too loose or broken. don't ask me how to fix it, i'm here trying to find out why mine keeps dying.
May 19, 2010 | Toro Lawn Mower With Toro Power Tools
I have toro 6.5 super/recycler that stalls out after about 5-10 minutes after it starts up then it will not start for about 30 mins. i've changed the spark plug and cleaned the filter
Dont know if this is the same problem but it may help. I've recently bought a used Toro 6.5 recycler and have cut the lawn 3 times with it. This third time it began to stall out on me. If I hit the primer button several times it would start up but then die again. I thought I'd have to pull the carb and clean it, ut after looking at a few problem listings online I realized it was probably just some trash in the needle valve. I managed to get it running again by first pushing the primer pump 3-5 times, then pulling the cord to crank it, then while holding the contact bar in place with one hand to keep it running I reached down and pumped the prime button a few times before it cut out again- after one or two tries it apparently flushed the trash out and it ran fine again. Had the same problem later and fixed it the exact same way, then went on to finish the yard.
Sep 08, 2009 | Garden
Won't stay running
these carb /air filter housing gaskets were notorious for warping? there are 2 screws behind the air cleaner remove those and disconnect the throttle cable pull the black square housing off and replace the gasket with a rubber one from local mower shop?
Aug 27, 2009 | Poulan Pro 22" Self Propelled High Wheel...
Self propell toro mower will not "self propell."
Self propell toro mower will not "self propell", nor can i pull it backwards
Oct 03, 2008 | Toro Lawn Mower With Toro Power Tools
Toro Lawn Mower With Toro Power Tools Logo
184 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
lnbn1975
Mike Squire
Are you a Toro Garden Expert? Answer questions, earn points and help others
