The reverse button is not working, continues stitching forward
SOURCE: reverse sewing button stuck HELP!!
MOdel 6430 has the stitch length and buttonhole selector on the same knob. It is the one on the bottom right side of the machine. I believe you may have selected the buttonhole by pulling out on the large round knob. You need to turn the knob back to 0 zero and push in. This should return the machine to normal mode.Adjust your stitch length to 3 and try it. The reverse knob in the center should also stick out so that it becomes operational again.
sewman7
SOURCE: The Reverse stitch button
The feed mechanism needs to be oiled. Take off the bottom cover and look for any place where two parts move against each other. Some binds can be very difficult to remove. Try spraying everything with a light weight oil (I like Tri-Flow) and let them soak over night. Then manually try to move the feed dogs with your hand. Hopefully it will break loose.
SOURCE: model 385.15718500..machine only goes in reverse
Sounds like the reverse mechanism has jammed...either with lint or lack of use and oil/lint has frozen the mechanism.
Unplug the machine and remove the base. Clean all the lint with small brush and vacuum.
Try the reverse lever to see where the connecting rods are and identify the collar around the bottom shaft....try to move manually, use a little lubricant where the collar moves on the shaft.
In extreme cases it may take several applications over several days to rectify this, but as this is only 3 years old, should respond quickly
SOURCE: bought my Sears Kenmore model 1400 in 1971. it
It's not that hard to service it your self. Pop open the top with a screwdriver, clean dust and lint out with a cotton swap moistened with sewing machine oil. Turn the handwheel to see where parts move against each other and put a drop at each spot. Do the same thing underneath your machine. Your camstack might be sticking from no oil ever. Turn your pattern knob and see if each time parts connected to it are moving well. That lever might need oil too. I don't know how to fix a bobbin winder though. You could check the files at the Yahoo groups called VintageKenmore or OldKenmores (not the exact spelling but you can search on Kenmore).
SOURCE: sears model 13 kenmore won't sew forward
its not easy sewing left handed is it? i think that oil has got into the switch and you have lost forwards drive now,,give it a good wiggel about till it clears it out, if it was working ok the last time you used it its just got a bit sticky thats all,,,i hope you used a light oil?
