Question about 1995-1997 Yukon Ignition Starter Alarm Switch
97 Yukon Kills Batteries!!!
Have had it to the auto electric folks twice, looked at tons of forums, stil can'y find the drain that seems only to occur when I turn my back for a week or so. Have made sure that the lights go off, glove box light switch was on once, so I added material to the shutoff post to make sure it went off when closed. The vehicle has remote start............once last summer I used the remote start, and when I tried to stop the vehicle, it would not die, even when I removed the keys completely. I had to remove the starter or fuel pump relay to kill the engine, and then replace it. I think that the battery drain problem happened following this event, but am not real sure. Last winter when the remote stert was used when the car was fully warm, the starter motor would keep turning after the engine started, and would run for about 15 seconds before finally stopping. Do I need a new starter, new fuel pump relay, NEW TRUCK...!!!
Any help greatly appreciated, I have killed 4 batteries and noe have to keep a charger on it all the time..........
Kind Regards
Ross
  • andyne50 Nov 13, 2008
    It won't happen overnight. The automatic charger only kicks on once in a while, as I have it under the hood, and connected to the battery. most of the time it reads "full". I measured the resting current the other day and I think it was around 30 ma.
    If I leave it for a week or more it will usually be dead.
    Is it possible that a faulty starter can have a current "leak"?
    Is it possible that I damaged the fuel pump relay by removing it when the vehicle was running?
    I will consider having the remote start removed, but would like to keep it if possible, it's cold here in the winter.
    Would a switch be a good thing to put on the battery, so I could remove all power from the vehicle at rest?
    Would that be harmful to the truck iin any way?
  • andyne50 Nov 16, 2008
    Thank you Paul...........
    Best regards
    Ross
    Guru:
  • 674 Answers
Hello
lets not just guess at this problem lets do some testing like the pro's
you will need a test light
you will need to have a fully charged battery
you need to disconnect the battery negitive
and use your test light to connect the neg cable to the batt.
now if you have a drain on your battery your test light will light.
now with this test light on we need to find the circuit that is causing your drain.
what i do first is to pull fuses untill the light goes off.
and then you know the circuit with the problem
once you know what curcuit is the problem let us know and we can help you further.
good luck
and remember a good mechanic will find the problem and replace the problem part
NOT replace parts hoping to fix the problem.
that is why we are here to help.
good luck and let me know how this works for you.
later paul
Posted on Nov 15, 2008
  • paul erickson
    paul erickson Nov 16, 2008
    how did you turn out with your battery drain?
    and about you switch on the battery.
    this isnt a good idea for the reason that you loose the memory.
    not only is this a pain in the **** for radio stations but the engine computer has to relaearn the many of its settings .
    when your done could you please rate my solution
    thanks
    paul
  • GMC Master
  • 19,396 Answers
From description, it looks like a faulty ignition coil.
Posted on Nov 13, 2008
  • Ginko
    Ginko Nov 13, 2008
    With all respect, I still think you need to replace the ignition cylinder, a short in the ignition cylinder can also drain the battery.
    See one on several testimonials here: Car Repair > 1999 gmc yukon, ignition switch will not turn,why ...
    Fuel pump and starter motor should be fine, have the ignition wirings tested, and eventually replace the ignition cylinder.
    President:
  • 1,450 Answers
This is an aftermarket remote start system? my advice would be to remove this and see what happens
  • TripleTauto
    TripleTauto Nov 13, 2008
    and it only goes dead after a week or now will go dead overnight?
  • TripleTauto
    TripleTauto Nov 14, 2008
    I have never seen a starter cause a drain. The fact that the remote start has given trouble before would make it the most likely suspect.Installing a battery disconnect would not harm the truck you would just have the aggrevation of clock and stuff resetting. there is also something called a battery saver that will cut off power if it sees too much drain on it. A lot of conversion vans have them with all the extra addons. One option would be to install a switch on the power supply to remote start system so you could cut off when not in use if this stops the drain issue then you will no it is this and can have system replaced
1994 Dodge B250 runs battery down overnight put meter between post and battery pulled all fuses no change black wire fuseable link disconnected kills voltage but van wont start then new battery
It would seem as though you have a drain somewhere in the electrical system.
A faulty alternator can cause a battery to drain - sometimes - within minutes. It's the rectifier pack - the diodes in the back of the alternator which burn out.
Charge your battery and when parked up, disconnect the connector at the rear of the alternator. If the vehicle cranks ok the next morning you have to suspect the alternator.
If the problem persists you then obviously have a current drain somewhere else. As you have removed the fuses and it made no difference .. this suggest that the drain could be in the instrument cluster/dashboard.
The best option is to visit an auto electrician. He'll be able to identify the cause of the drain within minutes
Apr 16, 2017 | Dodge Cars & Trucks
2006 GMC Yukon, 3/4 ton with tow package will not idle above 1200 rpms/10-15 mph
check ICS for correct operation
engine idle speed is 850 -950 rpms for auto and 750-850 for manual
at 1200 rpms you are not on the idle circuits but on power circuits
run the fault codes
Jan 15, 2017 | 2006 GMC Yukon
Car wont shut off,like it stays in auxillary mode and drains battery
folks... this is a normal feature.... as soon as you open the door, it kills it
Jul 07, 2012 | 2006 Pontiac G6
What is the battery life expectancy for the 2006 Buick Lucerne?
Battery life is a very complicated issue, there are TONS of factors. High temperature kills batteries, if the fluid goes low, that kills batteries. If you forget and leave lights on, and the battery goes totally dead, (totally dead, zippo, not anything) that kills batteries.
Alternator diodes that fail kills batteries. So 4 to 8 years is typical life IN ABSENCE of the above types of issues. My favorite battery is Interstate. They just work really well. Costco has great battery prices, bumpy for service... Really Dislike Sears die easy.
Oct 19, 2010 | 2006 Buick Lucerne
Intermittant dead battery problem since buying a 2005 GMC Yukon Denali XL in 2009 with 25,000 miles. I have replaced the battery twice and local GMC dealer replaced battery terminal once. I don't believe...
A technician will need to a parasitic drain test on the electrical system to determine where the battery drain is taking place. Sometimes the glovebox or vanity mirror lamps don't shut off and drain the battery.
Sep 27, 2010 | GMC Yukon Denali Cars & Trucks
Batteries are being drained. We barely use our camera and the batteries are being drained after only a few photos being taken. Camera is rarely used, maybe twice a day. At the most 5 pictures per day. ...
there seems to be a short if you have already tried replacing the batts then yes there is a short taking the power have it looked at by a lic pro
Jun 18, 2010 | GE A830 Digital Camera
Polar RS200 kills batteries
Got the same problem - changed battry in the RS200 twice, dead after about a week. Bought a "quality" battery, lastet fro 3 weeks, dead again.. :-(
This 4. time, after replacing battery again, I did try to Master Reset the RS200 (see www.polar.fi under support in forums) link: http://forum.polar.fi/showthread.php?t=14065 - but also TAKE CARE to reset to factory default!! You will loose all stored data!!
I am now only waiting (and running) to see how long the battery will last this time...
This might be the problem... give it a try?
Jun 02, 2010 | Polar RS200sd Running Computer Heart...
Battery Drain when parked.
First off, how old is the battery? It is possible it might be stratified and its just no longer holding a charge well. I've had batteries that are 2 or 3 years old and then they just go dead if I don't start them up every day or so. (Some batteries are just made better than others) If the battery is brand new, then check for some possible wiring shorts. Try looking at the engine running in the dark and try moving around the wiring harness to see if by chance you see any sparks or arcs of electricity. Other than that, you might have to have a qualified auto electric mechanic to check it out for any abnormal power drains.
Jul 30, 2009 | 1995 Dodge Ram 3500
Battery drain on Canon zr70mc
If you have the idiot proof switch on, it makes everything AUTOMATIC and drains the batteries fast. Open the LCD door and check if the switch is in the wrong position and change it. Go into the menu and set thing s the way you want them. The more Auto stuff you have on, the faster the battery goes. Are you using a light? Even using the LCD uses more power than the viewfinder. Also, batteries do go bad. It's best to run them all the way down and recharge, if you haven't been doing that, short life. I buy my batts on ebay. Instead of one for $150 I get 10 three hour batteries for that.
Sep 16, 2007 | Canon ZR70MC Mini DV Digital Camcorder
1995-1997  Yukon Ignition Starter Alarm Switch Logo
74 people viewed this question
Top GMC Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
alibaba69
Are you a GMC Vehicle Part and Accessory Expert? Answer questions, earn points and help others
