Question about Panasonic TH-42PD50U 42 in. Plasma EDTV
Panasonic 61LCX65 I saw you were giving out the instructions to replace lamp on this tv. Was wondering if I could get a copy sent to barryrod@bellsouth.net
  • Panasonic Master
  • 8,617 Answers
Send me a request to my privatae email and I will send them to you.
slinteriors@yahoo.com
Posted on Nov 15, 2008
My Panasonic multimedia projection tv -PT-61LCX65 needs a new lamp....where is the bulb located within the tv? How do I remove?
Hello, the lamp is located at the rear of the set. Unplug the tv before you start. There is a door secured by a screw, remove it to expose the lamp housing. There is a screw that secures the lamp, remove it, then you can gently grasp the handle and slowly pull it towards the rear of the set. To replace the lamp, gently slide the new lamp back in and secure it with the screw you pulled out. replace the lamp door cover, and replace the screw. plug the tv back in and turn it on, you should be fixed. Here's a link to a video on how to do it....https://www.youtube.com/watch?v=xvF36pepCOI.....tks
Jul 04, 2014 | Panasonic PT-61LCX65 61" Rear Projection...
When you trun on my panasonic PT-61LCX65 tv it makes no sounds the light blinks green. and then red and turns off. what is wrong. i have looked at the buble and it looks fine.
does the TV bring out sound even as the screen display is dark?
How long have you been using this TV and have you ever changed the lamp/bulb? Problem should be from the TV lamp/bulb.
Have the lamp replaced and hopefully, your screen should be perfect as before.
Let me know if you need directions in replacing the lamp, even though it is very simple replace.
Yours sincerely.
Elect_Comp.
May 15, 2011 | Panasonic PT-61LCX65 61" Rear Projection...
Panasonic PT-61LCX65 turned off while I was watching TV. Won't come back on. "Lamp" light blinks once every 5 seconds. Tried turning it on several times per the manual instructions--no change....
Tv projection lamp life are over. Wow 6 years with the original lamp,what u want it last for ever.Replaced the tv projection lamp,will solved the problems.
Feb 25, 2011 | Panasonic PT-61LCX65 61" Rear Projection...
I have replaced the bulb but still keep getting a Reset Notice
Hold Vol - on tv and TV/Video button on remote same time for 5 seconds. serv menu will come up. select lamp time and reset with vol- on remote to zero. Turn off tv to remove menu.
Nov 22, 2009 | Panasonic PT-61LCX65 61" Rear Projection...
I replaced my lamp on my PT-61LCX65 last year and
Depending on how much you watch this set the lamp could be out again, they don't have to look blown to be blown.
Sep 04, 2009 | Panasonic PT-61LCX65 61" Rear Projection...
Panasonic LCD Lamp Replacement
Here is the manual for your set, the instructions for replacing the lamp are on pages 66-67.
You can download the manual here.
http://www2.panasonic.com/consumer-electronics/support/Televisions/LCD-Projection-TVs/model.PT-61LCX65
To reset the lamp timer
For the full instructions and how to reset the lamp timer go to the following site
http://fixyourdlp.com/blog/wp-content/uploads/2007/09/panasonic-tyla1000-lamp-instructions.pdf
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. (Two Thumbs Up)
Please Note: If you cannot rate this post with the highest rating, then please do not leave any rating. I am doing this for free and I do not think that any rating other that the best is needed.
If you need further assistance please comment to this post and I will try to help you further.
Aug 21, 2009 | Panasonic PT-61LCX65 61" Rear Projection...
PT61LCX65 lamp timer
Hold the volume down button on the tv until the volume is at min. then continue to depress the volume down button on the TV. While depressing the volume down button the tv hold the pip or split button on your remote for approx 5 sec. You will see a box pop up that says lamp timer reset and gives instruction on how to exit.
Jun 02, 2008 | Panasonic PT-61LCX65 61" Rear Projection...
Most likely the lamp will correct this issue.
Apr 08, 2008 | Panasonic PT-61LCX65 61" Rear Projection...
Please send me the instruction on lamp replacement
sorry I dont have the instructions for panasonic. but it should be straight forward remove the back and the lamp housing should be right there.
Mar 14, 2008 | Panasonic PT-61LCX65 61" Rear Projection...
Panasonic pt-61lcx65
I have the same TV and just replaced the same lampTY-LA1000.
You have to reset the clock that times the lamp.Hold down the volume button(first you turn on the TV) while holding down the PiP button or the swap Button on the remote. that fixed mine.
Jan 11, 2008 | Panasonic PT-61LCX65 61" Rear Projection...
Panasonic TH-42PD50U 42 in. Plasma EDTV Logo
150 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
