Question about Lite On LVW-5006 DVD Recorder
Record a cd from a taperecorder to the LVW 5006 I own. Need hook
I have hooked up my LVW 5006 to the tv and it is working. I want to record from a tape recorder to a cd; and I forgot how I did it before. I need instruction as to where to plug in the tape recorder. I plugged it into the No. 11 plug in the front of the unit. Correct? not correct?
Then I got the menue on the tv-and nothing happened.
Please kindly walk me through the hook up and remote control instructions.
Thank you soooo much!
Maiti Schorr
  • iamdivinejus Nov 13, 2008
    Dear fixya,
    All can get is free advice and the three options offered were not what I needed.
    I guess I"ll have to figure it out myself.
    I neede emailed instruction since there were none when I bought the unit.
    Thanks so much
    MS
The LiteOn download page for manuals is http://us.liteonit.com/us/index.php?option=com_wrapper&Itemid=153  Category - video.  Model - LVW-5006.  User manuals available in English and French.
Posted on Dec 30, 2008
Manual for LVW-5005X CD/DVD need copy Have the Player need manual to hook up to TV
The user's manual is available from Lite-On as a .zip file. http://us.liteonit.com/us/index.php?option=com_wrapper&Itemid=153 Select Audio/Video and then your model number in the two drop down menus; then click Search.
The direct link is http://www.liteonit.com/DOWNLOADS/DC/LVW-5005X/user_manual/en_us/LVW-5005X_US_English.zip .
You will need to unzip the file to read the document. With Windows, right click on the file after downloading and select "Extract All".
I hope this helps.
Apr 30, 2011 | Computers & Internet
I have liteon lvw 5006, i am having problem with Ejecting the Disc.
good day sir...
your problem is on the ejecting motor,.The broken rubber that connected to the mechanism or on the motor itself...You have to do is....
first,Open the cover by removing all screws that holds the cover
secondly,Try to remove the lens assembly one set including the CD tray..by unscrew the lock of that mechanism...
thirdly,Try to see the ejecting motor if the rubber is okay and remove the motor to check the resistance weather it good or bad the reading is not more than 25 ohms or or try the actual testing using a 1.5v battery if the motor spin up that's good
fourthly,But when you found the trouble like on steps 2 and 3..replace immediately on the same type and ratings...its either motor or the rubber
And finally,if you found the defects re-assemble it and test it again...
Reminders;Pay attention to the alignment of the mechanism assembly to eject the DVD smoothly..
thank you and good luck.
Apr 11, 2011 | Lite On LVW-5006 DVD Recorder
Liteon dvd recorder won't play or record from disk or cable tv
You should be able to connect with the AV input, Y, Video R, W. Audio, they go to same color on DVD & TV.
Feb 18, 2010 | Lite On LVW-5005 DVD Recorder
How do i hook up my dvd recorder to my dvd player? where do i hook my cords to?
You need RCA cables to do this.These have red yellow and white cable ends.The yellow is for video the white is for the left speaker,red for the right speaker.Run the RCA cables from the output of you DVD player to the INPUT of your dvd recorder.Run another set of RCA cables from the output of your dvd recorder to the input of your TV.Most modern tv's have these inputs. These RCA cables can be purchased at Radio Shack or places like Walmarts.
Jan 10, 2010 | Lite On LVW-5005X DVD Recorder
Do i need remote
Yes you can't finalize without a remote.These units use a RM 51 remote.You can find one ebay or you can get a new one at Litetrekinternational.
Dec 21, 2008 | Lite On LVW-5006 DVD Recorder
Unlock code for a liteon lvw-5006
Go into 'Setup'
Move the cursor to 'Exit'
Press 2 9 6 0
Set the region you want or region free
Sep 22, 2008 | Televison & Video
Poor picture quality and sound problems on Lite-on LVW 5115GHC
have you tryed replaceing scart leads plus check if there in a priority order 2 like going form dvd 2 tv then tv 2 sat recever try going via sat recever then dvd then you tv if that dose not seem 2 solve you problen it might seen you might have dry solder point inside you dvd unit if so take bk where you buy it from and explane to then wat is happening hope helped
Aug 05, 2007 | Lite On LVW-5115GHC+ DVD Recorder
Lite On LVW-5006 DVD Recorder Logo
208 people viewed this question
Top Lite On Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Lite On Televison and Video Expert? Answer questions, earn points and help others
