The IPO should get its time from the VM Pro server. The time server should be
set to the IP address if the VM Pro pc. If there isnt a vmpro pc, you can set
it manually.
http://mfurrer.dyndns.org/?p=224
For IP Office systems without access to a time server, a number of methods to
manually set the system time exist. These are available in the IP Office 4.1+.
The following method is only supported on these phones: 2410, 2420, 4412, 4424,
4612, 4624, 4610, 4620, 4621, 5410, 5420, 5610, 5620, 5621, 6412, 6424. It is
supported on any analog, T3, T3 IP or wireless (IP DECT, 3600, 3700 Series)
phones.
Note: If the IP Office system that is still configured for automatic time
updates (on by default), any manually set time and date will be overridden on
the next automatic update. The use of automatic updates can be disabled by
setting the System ' System ' Time Server IP Address to 0.0.0.1.
Enabling a User Button for Time and Date
Select the user who can adjust the system time and date.
If necessary create a new user who can be used to log in and set the
time and date before logging out.
On the User ' Telephony tab, ensure that the option System Phone is
selected.
On the User ' Button Programming tab select and double-click on an available
button.
Select Emulation > Self-Administer as the action.
In the Action Data field enter 2.
Enter an appropriate label for the button.
Adding another button set to the Emulation > Time of Day action is
recommended as this will allow the user to view and confirm the systems current
time.
In the User tab, Change System Phone Rights to "Level2"
Send the updated configuration to the IP Office.
Using the Programmable Button
Press the programmed button. If the user has a Login Code enter it as
requested, and press Done
The options Date and Time are displayed.
To set the date press Date.
The current system date is displayed.
Enter the new date, using two digits for day and month. Use the * or #
keys to insert the / separators. The format for date enter matches the locale of
the IP Office system.
During entry the key labeled <<< can be used to backspace.
When the full date has been entered as required, press Next.
Press Done.
The phone will return to idle.
To set the time press Time.
The current system time is displayed.
Enter the new time using 24-hour clock format. Use the * or # keys to
insert the : separator.
When the full time has been entered as required, press Done.
This posting was the perfect solution to my problem !!
Ms. Simonetta
