Question about HP Photosmart C3180 All-In-One InkJet Printer
Printer ok scanner not ok
I have installed the printer threw ADD a printer on my printer set up, but it won't include the scanner into it. Why, if it installed the printer why not the scanner too?
    Scholar:
  • 121 Answers
If you have added through the add printer wizard you have added jus the printer software.....try to install through the software cd that came with it....
Please dont forget to vote
Cheers!
Posted on Nov 13, 2008
I am having problems making my scanner work - I can't scan a document from the printer/scanner/fax/copier to my laptop
How is the all-in-one connected to your computer? What OS are you using? Did you install the full software, basic drivers or the OS drivers? Are you starting your scan from the computer or the buttons on the all-in-one? Is this a newly installed printer or one that has been used several times with this computer?
The Photosmart C7180 can be used with a USB connection, wired ethernet network, wireless network, bluetooth or PictBridge. For a Mac OS, only the USB connection will work.
If you need the drivers, see http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?cc=us&dlc=en&lc=en&product=1153754& and select your OS.
If you connected the all-in-one to the computer via a USB connection before installing the software, you may have an OS driver that does not include the scanner driver. Disconnect the USB cable then uninstall the driver. Then install the HP driver. If you do not install the full software, you will not be able to use the buttons on the scanner to launch a scan. You'll have to start the scan from the computer.
If you have the full software, the HP Solution Center is installed. This includes a monitoring program that should run when you start your computer. This listens for the press of a button on the scanner and launches the appropriate part of the HP software. However, you need to set the button destinations in this software first. I recommend manually scanning at least once to set the appropriate resolution and destination folder for your scans. Then in the Solution Center, click Settings, Scan Settings, Button Settings and then Front Panel Scan Buttons. Set these based on your default settings.
If this all-in-one has been working previously, check your connection. Scanning requires bi-directional communication with the computer and can fail even when the printer works. Try a new USB cable and a different port, if you are using that connection. If you are on a network connection, check that the firewall isn't blocking communication. (Temporarily disable the firewall to check.) In Windows, check the Devices and Printers (Win7's name) control panel and check if the scanner is a listed device. Right click on it and check the properties and status. (All-in-ones are often listed twice - as a printer and as a scanner.) HP offers a diagnostic program, http://h10025.www1.hp.com/ewfrf/wc/doclink?lc=en&cc=us&product=1153754&tmp_docname=c02114802 , to check for issues with the scanner.
Try manually scanning with another program than the HP software. Windows includes some options that will acquire scans. XP, Vista and Win7 all include Paint (File > Import from Camera or Scanner > New Scan). Windows7 (and some versions of Vista) include Windows Fax and Scan (click New Scan). If you have the Microsoft Live software, you also have Windows Photo Gallery (works like Paint).
If you are connect the all-in-one to a USB print server, the scanner probably won't work. Try a different type of connection.
If you are using the all-in-one on a network, make sure that the network is up and the printer has an IP address. I've seen routers lose their connection for various reasons. (Rebooting both the modem and router sometimes cures the problem.)
Please add more information on your specific scanner problem and I'll try to provide specific suggestions.
I hope this helps.
Apr 09, 2012 | HP Office Equipment & Supplies
Scanner locked
the noise is your scanner the light trying to move, you probally have the scanner lock on or the scanner rail needs a lube or moter is stuffed, but good chance scanner lock is on.
Waste toner... clean the bottle... dont just empty it... most machines try to see threw the container to see if it is empty... if it has dust on the sides it cant see threw so thinks it is full
Feb 07, 2012 | Samsung CLX 3160fn All-In-One Printer
Canon mx310 won't scan message reads "the
Please go to Control panel and choose add or remove programme.. kindly uninstall the program i.e. Your printer driver after all re-install the driver... thanks
Aug 22, 2011 | Canon PIXMA MX310 All-In-One Printer
Print spooler error in windows xp sp2 & sp3
Click on Start -> Run ->Type: services.msc and click OK, this will bring the services window up. Scroll down to print spooler, turn on then double click on the Print Spooler Service and set start up type to Automatic, then click OK. Restart PC. Now, you have to reinstall the software (if you can't find it, please tell me your model so I can search it for you) If this won't work, completely uninstall all the software and again, reinstall it. Click on Start -> Run ->Type: Control Panel in the dialog box and click OK. Click on add remove programs and uninstall the software for the printer.
Then check Under the Printer and Fax to see if it was uninstalled. If not then just delete it. Printer and Fax is located in Control Panel. Once it's completely uninstalled you have to reinstall the software for the printer.
May 12, 2011 | Computers & Internet
Epson sx405 all in one won`t print!
Please re-install the drivers, and follow the instructions as given, you will forge ahead
Mar 17, 2010 | Epson Stylus Multifunction Inkjet Printer/...
I hit scan on my machine and there is nothinbg responding on the computer screen. I am able to copy, print and fax. Help.
Your scanner is not properly installed. It is a separate part of the program. If you have (start - programs) the scanner as a program, bundled with your other printer proograms on screen, double (left) click on the scanner program, it should lead you to the install wizard. simply install the program. If not, try reinstalling your printer.software (use control panel - add/remove - uninstall all printer programs FIRST). Look at your software and make sure that the scanner software IS included.
Sep 01, 2009 | Brother MFC 210C All-In-One InkJet Printer
Scanner failure
ok that fine.if simple problem. firstly remove ur printer software from ur pc. for it go to control panel and click add/remove icon. then uninstall ur driver software. after that u should install ur printer software. then become ok
Jul 27, 2009 | HP Officejet 4110 All-In-One InkJet...
My pc is not recognizing the scanner
In your printer and fax folder you probably have more than one printer installed and your default printer is not the one you just installed, Select the printer you just installed and set it as your default and try again
Jun 19, 2009 | Uniden BCD996T Base Scanner
My machine displays on the LCD: "machine error 68"
First, I would recommend NOT trying to manually install this printer by using the add printer wizard in windows and selecting the the port and drivers to use. I would use the install cd to set this all up, it makes setting up this printer MUCH easier. If you are unable to use the install cd then get the IP address for the printer from your router admin page then with the printer "installed" go into the printer properties, go into the port, add a port, and instead of using a printer name just type the IP address for the printer in. Also for any networked printer make sure you don't have a firewall blocking it (this would include making sure that if the printer requires a port opened in the router that all requests for that port are routed to the IP address of the printer).
Jun 18, 2009 | Brother MFC-8820D Laser Flatbel...
Scanner driver or USB/Parallel
FIRST UNINSTALL THIS DRIVER.
from add remove programs
then download and install printer driver you have or do web search for new printer driver via the web" type in printer driver for
AL 1642CS. you must include operating system version windows xp 98 2000 etc...
Jan 12, 2008 | Sharp AL-1642CS Copier
HP Photosmart C3180 All-In-One InkJet Printer Logo
43 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
